Old Feb 20, 2013, 03:30 AM
pawelsky is online now
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Originally Posted by realbob View Post
I tought Spektrum had exclusive bandwith which is not used by other kind of devices?
No they both operate within the same 2.4GHz range so interference is possible.
pawelsky is online now Find More Posts by pawelsky
Old Feb 20, 2013, 05:31 AM
NDT_UTS_LU is offline
Find More Posts by NDT_UTS_LU
China, Jiangsu, Suzhou
Joined Jan 2013
Originally Posted by pawelsky View Post
Barometer is not needed to fly high, you can do it without it.
P.S. rx2atp-reconf19-bmp085-v094 is an experimental version of the skech done by happul3 so you should be rather careful with that (not because it is done by happul3, but because it is experimental of course ). My advice - wait until barometer support is included in miru's official release or PM happul3 to guide you on usage of his experimental version.
thaks very much pawelsky .
NDT_UTS_LU is offline Find More Posts by NDT_UTS_LU
Old Feb 21, 2013, 02:32 PM
dante1 is offline
Find More Posts by dante1
XR-4Drone.com
dante1's Avatar
Canada, QC, Montreal
Joined May 2011
Terminal emulator for Mac
Does anyone know what program I can use for SETUP mode on a Mac? I tried ZTerm and it worked twice and now I can't get to work. Is there an easier program? Or maybe the setting I need to use?
THanks,
Dante1
dante1 is offline Find More Posts by dante1
Old Feb 21, 2013, 02:50 PM
pawelsky's Avatar
Poland
Joined Jan 2012
THanks,
Dante1
Use the built in terminal app
http://www.tigoe.net/pcomp/resources...r/000749.shtml
Old Feb 22, 2013, 07:53 AM
Viaggiatore is offline
Find More Posts by Viaggiatore
Italy, Emilia-Romagna, Predappio
Joined Aug 2012
You can also use MacWise, workin great for me
Viaggiatore is offline Find More Posts by Viaggiatore
Old Feb 22, 2013, 08:03 AM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
Thank you and long time no see.
Old Feb 22, 2013, 11:09 AM
Joined Aug 2012
I'm now fighting with an Arducopter rig ;-)
Old Feb 25, 2013, 04:59 PM
pawelsky's Avatar
Poland
Joined Jan 2012
Captcha for MiruLLC orders
FYI I know that nobody likes Captcha, but to keep bots away I had to add it to the MiruLLC order page.
Old Feb 25, 2013, 05:08 PM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
Those darn bots!!!
Old Feb 27, 2013, 09:28 PM
realbob is online now
Find More Posts by realbob
Crash and crash!
realbob's Avatar
Joined Oct 2010
HI, I have Miru mod with an Arduino Nano. I tried to upload modified file in sketch and had some issues. I used the online configurator and for altitude it put 1000000 instead of 0 in altitude settings. I corrected this but still have issues. I tried to put back unmodified file, same issue....
I start the drone as usual with FM2. But no response from the drone. I put FM1, then lights flashes and I can trim, emergency... Put FM2 or FM3, nothing happens. How come FM2 is now disabled??? Any hint?
realbob is online now Find More Posts by realbob
Old Feb 27, 2013, 09:34 PM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
Did you select the LAND and FM_x switch setup in the sketch configurator?
Old Feb 27, 2013, 09:38 PM
Crash and crash!
realbob's Avatar
Joined Oct 2010
Used One 3 position switch ex: DX7.....
Maybe file is not created correctly. Can you show me good line about this 3 position switch in the file?
This should be ok?
#define S_LAND S_AUX1
#define S_FMOD S_AUX1
Old Feb 27, 2013, 10:54 PM
ror1 is online now
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
where did you get the sketch?
did you do the setup using USB serial port?
ror1 is online now Find More Posts by ror1
Old Feb 28, 2013, 01:53 AM
pawelsky's Avatar
Poland
Joined Jan 2012
Do not change the 1000000 value - it is there to workaround 100m altitude limit bug in sketch. If you change that to 0 your altitude will be actually limited to 100m.
If you can trim in FM1 it means you have you 3-pos switch setup incorrectly on DX7 and your LAND/FM1/FM2 positions mixed up as triming can only be done in LAND. Fix that in SETUP mode first.
EDIT: Also make sure your throttle stick is centered when launching.
Old Feb 28, 2013, 05:02 AM
Crash and crash!
realbob's Avatar
Joined Oct 2010
Got it on mirus site and used USB interface.
Hum... what do you mean? FIx that in setup?
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
