Old Feb 05, 2013, 10:23 AM
dante1 is offline
Find More Posts by dante1
XR-4Drone.com
dante1's Avatar
Canada, QC, Montreal
Joined May 2011
Originally Posted by pawelsky View Post
It does not hurt however to changed to the right values.
Based on your recommendations awhile back, that is exactly what i did and it worked.
dante1 is offline Find More Posts by dante1
Old Feb 07, 2013, 03:48 PM
pawelsky is online now
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Ultrasonic sensor fix
One more thing to try before replacing the whole navboard
http://www.ardrone-flyers.com/forum/...hp?f=13&t=5063
pawelsky is online now Find More Posts by pawelsky
Old Feb 07, 2013, 05:38 PM
pawelsky's Avatar
Poland
Joined Jan 2012
Barometer/magnetometer for AR.Drone 1.0
Some of you probably noticed that already, but I've added a sub-page describing the barometer/magnetometer connection for AR.Drone 1.0 (thanks to happul3 for the idea).
http://mirumod.tk/hw/baromag/baromag.php
It opens new possibilities and will certainly help with the RTH on Drone 1.0
Old Feb 07, 2013, 07:44 PM
gta18 is offline
Find More Posts by gta18
gta18's Avatar
LA
Joined Mar 2004
Got my mod board back together with the MIRULLC finally. DRONE 2 running on 2.1.18 and mod on v018. Tested the stick inputs on the setup mode.
Plugged into the drone and telneted to drone to verify at2so.arm is a running process. Tx is on Land mode and sticks are all centered during startup.(did all of this about ten times)
The drone does not respond to stick inputs i.e. trim/estp. no blinking lights from the drone, the red light on the nano is solid after the green/yellow blink from the drone. I even tried changing the CFGs using the stick. with no luck...
what else can I try?
thanks
gta18 is offline Find More Posts by gta18
Old Feb 07, 2013, 08:03 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Plugged into the drone and telneted to drone to verify a2tso is a running process. Tx is on Land mode and sticks are all centered during startup.(did all of this about ten times)
The drone does not respond to stick inputs i.e. trim/estp. no blinking lights. I even tried changing the CFGs. with no luck...
thanks
If SETUP mode works, power down, unplug jumper and describe what happens when you power up the drone...
It should go like this: (this is not the normal start procedure, but easier to debug)
1) TX off
2) plug battery in
3) drone comes alive and boots, the Arduino LED should blink once a second
4) wait for drone to turn on green motor lights
5) turn on TX
6) RX LED should turn on
7) Arduino LED might blink some more 4 times/second but then goes dimm and then solid on. When it is dimm, it uploads the companion program, when it turns solid, it waits for the companion program to start.
8) drone flashes motor lights orange, companion program has started
9) drone flashes motor lights green, companion program has set configuration
10) Arduino LED should be blinking at 12HZ, everything is ready.
miru is offline Find More Posts by miru
Old Feb 07, 2013, 08:26 PM
gta18 is offline
gta18's Avatar
LA
Joined Mar 2004
1) TX off
2) plug battery in
5) turn on TX
Miru,
Mine gets to step 8. and stays there with a solid bright red on the arduino. I also checked that pilot.arm and at2so.arm is in the /tmp when I telnet.
Old Feb 08, 2013, 05:17 AM
pawelsky's Avatar
Poland
Joined Jan 2012
Miru,
Just out of interest - what is the fuses value in the SETUP mode?
Old Feb 08, 2013, 06:14 AM
gta18 is offline
gta18's Avatar
LA
Joined Mar 2004
Pawelsky, fuses are DA-FF-FD-CF cpusg 1E950F
dcnt=2663
Old Feb 08, 2013, 07:42 AM
SJW2511 is offline
Find More Posts by SJW2511
Joined Nov 2012
What llc are you using?
SJW2511 is offline Find More Posts by SJW2511
Old Feb 08, 2013, 08:06 AM
gta18 is offline
gta18's Avatar
LA
Joined Mar 2004
MIRULLc
Old Feb 08, 2013, 08:13 AM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
Yes, I did notice. Great work. I will certainly get me one to try it out. But not anytime soon. Just got hit with alot of snow...again.
Old Feb 08, 2013, 09:28 AM
SJW2511 is offline
Joined Nov 2012
MIRULLc
damn doesnt look like the mirullc cures that problem then
Old Feb 08, 2013, 09:41 AM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
MIRULLc
Did you try another Arduino Nano?
Old Feb 08, 2013, 10:02 AM
gta18 is offline
gta18's Avatar
LA
Joined Mar 2004
this is my 2nd one.
Old Feb 08, 2013, 10:03 AM
gta18 is offline
gta18's Avatar
LA
Joined Mar 2004
Was there another issue like this before?
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
