Old Jan 30, 2013, 07:49 AM
floete is offline
Find More Posts by floete
United States, NC, Kure Beach
Joined Dec 1996
Originally Posted by dante1 View Post
Instead of putting a wire through the pin holes. Why not solder a small wire to bridge the two points from the underside? That way, you can still use the mod.
after failing at the update procedure, i took a single strand of wire and put the ends into the appropriate holes, then I plugged the mod in and it fit easily despite the jumper wire. plugged in the drive, it started flashing. rebinded, etc., and started the bird up. once i hit the on switch, the drive stopped flashing, and did not start flashing again once i stopped the motors ... which must be the way it's supposed to work, because, finally, videos were saved to the drive and i could view em on my pc. bueno.
thanks to all who helped me through all my various foozles and fumbles!!!
i know i should update my firmware but at this point i'm going to leave well enough alone.
floete is offline Find More Posts by floete
Old Jan 30, 2013, 07:58 AM
gta18 is offline
Find More Posts by gta18
gta18's Avatar
LA
Joined Mar 2004
@miru, is there still program space to integrate a DSM2 sattelite receiver for the arduino, so we can get rid of the big receiver.
gta18 is offline Find More Posts by gta18
Old Jan 30, 2013, 08:54 AM
pawelsky is offline
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Is the new Turnigy 9XR the same as having the 9X with er9x code on it?
From the functionality POV I believe yes, but I did not have 9XR in my hands. From what I've heard there are complaints from the er9x team, that the community developed FW was put into 9XR without giving any credit for the hard work) so it seems it is the exact same FW.
From HW POV for sure the advantage of 9XR is a built in programmer. The disadvantage (but for some that could actually be the opposite) is that it comes without the TX module so you have to buy it separately.
What is the advantage of having the er9x in your opinion?
Too many to count them all - starting from a full configurability and ending with the option to switch the annoying button press buzzer sound off You even have a PC program to edit/view/simulate the whole configuration.
pawelsky is offline Find More Posts by pawelsky
Old Jan 31, 2013, 11:19 AM
gta18 is offline
gta18's Avatar
LA
Joined Mar 2004
Anyone has a link for the latest ardrone 2 fw? later than 2.2.29
Old Jan 31, 2013, 11:36 AM
dante1 is offline
Find More Posts by dante1
XR-4Drone.com
dante1's Avatar
Canada, QC, Montreal
Joined May 2011
Try here
http://www14.zippyshare.com/v/54903479/file.html
Google is your friend
dante1 is offline Find More Posts by dante1
Old Jan 31, 2013, 11:38 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
I don't think there is 2.2.29 version. I guess you meant 2.2.9.
The latest one is 2.3.3 and it is a part of the FreeFlight 2.2.7 on iOS.
Old Jan 31, 2013, 11:41 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Try here
That is not the latest version. 2.3.3 is.
BTW 2.2.9 is lower than 2.2.29 (assuming there was such version)
Old Jan 31, 2013, 12:08 PM
gta18 is offline
gta18's Avatar
LA
Joined Mar 2004
Pawelsky, do you have 2.3.3?
Old Jan 31, 2013, 12:37 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
The satellite receiver I looked at communicates at 115200 baud, a bad baudrate for a 16Mhz Arduino (3% error). BTW do you know how to bind a satellite receiver by itself?
miru is offline Find More Posts by miru
Old Jan 31, 2013, 01:02 PM
gta18 is offline
gta18's Avatar
LA
Joined Mar 2004
Not yet, am looking it up though. I think i saw one in the multiwii thread but cant seem to find it again.
Old Jan 31, 2013, 01:12 PM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
er9x model file
For those using Turnigy 9x receiver with er9x firmware, here is a model configuration file (zipped) that can be used in eePe.
Features of this config
1) THR on CH1, AIL on CH2, ELE on CH3, RUD on CH4 (config for 9X8Cv2 8CH receiver that comes with the TX)
2) GEAR on CH5, 3-pos F.MODE switch on CH6 (N=LAND, 1=FM1, 2=FM2)
3) spring loaded TRN switch does FM2->FM1 switch (works only when in FM2, so you won't accidentally launch the Drone). That can be used to switch to FM3 mode or trigger animation easily or just switch to FM1 for a moment so the drone can stabilize.
4) THR.CUT switch triggers immediate emergency (Drone falls of the sky) regardless of the position of other switches (normally you would have to do LAND followed by THR right which takes precious time)
5) when ELE D/R switch is on 1, PIT.TRIM knob limits the max value for THR channel (between 0% and 100%) useful e.g. to adjust to changing wind
6) same with RUD D/R switch and HOV.PIT knob for RUD channel
7) same with AIL D/R switch and HOV.THR knob for AIL/ELE channels
8) timer counts down from 10:00 when on FM1/FM2/FM3 (stops when on LAND) - useful to know the real time of the flight
I think that is pretty much it.
Old Jan 31, 2013, 02:02 PM
gta18 is offline
gta18's Avatar
LA
Joined Mar 2004
Found it here. http://reviews.openpilot.org/browse/...b4ce759c2e4bee
Old Jan 31, 2013, 02:14 PM
dirkdirk is offline
Find More Posts by dirkdirk
Germany, HE
Joined May 2012
Hi,
first of all thank you Miru for the awesome idea with the rc-mod.
i'm really new to the topic about arduino and programming.
But....today i finished my ar.drone 1 conversion to Spektrum.
Its completely solder free (except the "usb" plug for the drone and the 4k7 resistor) everything is just plugged in.
Flies really great, but when i use my iPad simultaneously for recording, the red leds of the drone are beginning, after a few seconds, to flashing and the drone goes down. Moreover i think the agility is much better without the running app.
Flying without the freeflight app is no problem.
Someone got a idea how to fix this?
P.s. Sorry about my bad english..German is my first language.
dirkdirk is offline Find More Posts by dirkdirk
Old Jan 31, 2013, 02:15 PM
SJW2511 is offline
Find More Posts by SJW2511
Joined Nov 2012
Guys having a strange problem with my GPS modules
Its not writing a log file every time, in fact probably more often it doesnt write anything then it does.
Happening on more than one different one iv tested, everything else is ok, it writes video ok, and I get flashing arduino light when holding down on the throttle to indicate comms with the gps
Am I missing something I have to do at boot to get it to make a log?
I only have the pilot019.arm file on my usb stick
SJW2511 is offline Find More Posts by SJW2511
Old Jan 31, 2013, 02:21 PM
miru is offline
Vista, CA
Joined Feb 2008
Originally Posted by dirkdirk View Post
Hi,
The video feed from the drone to the iPad, takes some horsepower, actually a drone 1 is pretty much maxed out, when you watch the front camera. The lights flashing could be the battery going down.
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
