Old Dec 22, 2012, 02:14 PM
pawelsky is online now
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Originally Posted by SJW2511 View Post
here we go, image attached
Seems if i plug gps gnd into left or right hand side of board the arduino starts to burn when you start it up
if i leave GND out it doesnt burn but then of course it doesnt work, as per the original problem lol
BTW im using an Arduino Pro mini so its not a nano as in the image
Can you make sure if the link between the Pro Mini 5v pin and UBEC/GPS is indeed gone?
I'm assuming you use the same lipo that powers the drone and you connect to the balance plug, right?
pawelsky is online now Find More Posts by pawelsky
Old Dec 22, 2012, 02:18 PM
SJW2511 is offline
Find More Posts by SJW2511
Joined Nov 2012
yeah im powering either using a lipo, or by the drones serial port
either the arduino starts burning when you boot up
link is deffo gone only thing in VCC is the receiver and the LLC
iv noticed its fine until the arduino finishes booting then the drones lights blink and it starts running the program, thats the point it starts to burn.
if you say, leave the rc controller switched off so it never boots it doesnt burn
odd that it burns when connected to the serial board GND isnt it? wouldnt thought that would place any load on the arduino
SJW2511 is offline Find More Posts by SJW2511
Old Dec 22, 2012, 02:28 PM
SJW2511 is offline
Joined Nov 2012
Just a thought, pins A0, and A1 are 5v live when the program kicks in
Do you think its sending that current round through the GPS then back into the GND thus creating a 5v extra circuit load on the board?
Do those pins need to be 5v? can they not be low voltage like the receiver pins, as its only sending data isnt it?
This would also explain why it doesnt work in SETUP because until you GND the GPS back to the board its not creating a circuit.
If we can use low voltage on those pins im certain it will be ok
Old Dec 22, 2012, 02:29 PM
pawelsky's Avatar
Poland
Joined Jan 2012
Have you checked both VCCs (the one next to A3 and the one where FTDI connects)?
have you tried powering the whole Arduino from UBEC as suggested earlier (see http://www.rcgroups.com/forums/showp...stcount=3155)?
After checking the above I'm running out of ideas and the last thing to try would be to go through photos of your setup to make sure we are not missing something.
Old Dec 22, 2012, 02:32 PM
Fioulmaster is offline
Find More Posts by Fioulmaster
France, PCh, Poitiers
Joined Oct 2011
I think you have a problem in your schematic.
The nano is powered by ubec (5v on VCC) and by drone (12v on raw).
Fioulmaster is offline Find More Posts by Fioulmaster
Old Dec 22, 2012, 02:41 PM
SJW2511 is offline
Joined Nov 2012
cant be the 5v from the ubec is only going to the GPS
what do we think about this?
it makes sense to me, in setup test they are only running something like 0.5v
Old Dec 22, 2012, 02:49 PM
SJW2511 is offline
Joined Nov 2012
Iv just put those 330ohm resistor on both the TX and RX lines and its not burning as much now, and still works in setup, its still getting quite hot though so i think maybe even more resistance?
what would be a suitable resistor do we think to add more resistance?
Old Dec 22, 2012, 03:58 PM
SJW2511 is offline
Joined Nov 2012
Ok I think iv got it running at a satisfactory temp, at least for testing purposes.
And it all looks ok in SETUP, gets a proper GPS log etc
However next problem, when trying on the drone, it doesnt seem to be writing the log correctly and i dont get blinking arduino light when I press down on the throttle
here is a sample from the log P00.txt on the USB stick
0: BOOT pilot 0.19 20120911 (60)
0: dfmw 20303
0: T80,date,time,lat,lon,alt,fix,sat,hdop,seq
0: T81,ena,mod,dtm,velr,vela,tgtr,tgta,hdng,mhdn,ohdn ,pstr,psta,prol,pptc,pgas,pyaw,seq
0: LINK,"state"
0: LOG,<filename>,<error>
0: CFG,"var","val"
0: MVEL,[m/s]
0: MYAW,[deg/s]
0: HOME,lat,lon,alt,trad
0: T81,0,0,0.000,,,,,0,0,0,,,,,,,1
50: LINK,ok
50: T81,0,0,0.000,,,,,0,0,0,,,,,,,2
245: CFG,"custom:session_id","-all"
331: CFG,"custom:session_id","00000001"
463: CFG,"custom:application_id","5ba841e9"
521: T81,0,0,0.000,,,,,0,0,0,,,,,,,3
596: CFG,"customrofile_id","6fb0c592"
800: CFG,"custom:session_desc","mirumod"
932: CFG,"video:codec_fps","25"
1041: T81,0,0,0.000,,,,,0,0,0,,,,,,,4
1044: CFG,"video:video_codec","129"
1198: CFG,"video:max_bitrate","1500"
1331: CFG,"detect:detect_type","3"
1464: CFG,"control:control_level","0"
1560: T81,0,0,0.000,,,,,0,0,0,,,,,,,5
1563: CFG,"general:navdata_demo","1"
1624: VBAT,79
1698: CFG,"general:navdata_options","0x6500001"
1832: CFG,"controlutdoor","1"
1964: CFG,"control:flight_without_shell","1"
2089: T81,0,0,0.000,,,,,359,359,0,,,,,,,6
2092: CFG,"control:euler_angle_max","0.35"
2093: MVEL,12.0
2229: CFG,"control:control_vz_max","2000"
2362: CFG,"control:control_yaw","3.5"
2362: MYAW,200.5
2496: CFG,"control:altitude_max","1000000"
2612: T81,0,0,0.000,,,,,359,359,0,,,,,,,7
2616: CFG,"video:video_on_usb","1"
3137: T81,0,0,0.000,,,,,359,359,0,,,,,,,8
3657: T81,0,0,0.000,,,,,359,359,0,,,,,,,9
4176: T81,0,0,0.000,,,,,359,359,0,,,,,,,10
4698: T81,0,0,0.000,,,,,359,359,0,,,,,,,11
5214: T81,0,0,0.000,,,,,359,359,0,,,,,,,12
5734: T81,0,0,0.000,,,,,359,359,0,,,,,,,13
6254: T81,0,0,0.000,,,,,359,359,0,,,,,,,14
6772: T81,0,0,0.000,,,,,359,359,0,,,,,,,15
7292: T81,0,0,0.000,,,,,359,359,0,,,,,,,16
7811: T81,0,0,0.000,,,,,359,359,0,,,,,,,17
8330: T81,0,0,0.000,,,,,359,359,0,,,,,,,18
8849: T81,0,0,0.000,,,,,359,359,0,,,,,,,19
9369: T81,0,0,0.000,,,,,359,359,0,,,,,,,20
9888: T81,0,0,0.000,,,,,359,359,0,,,,,,,21
10407: T81,0,0,0.000,,,,,359,359,0,,,,,,,22
10930: T81,0,0,0.000,,,,,359,359,0,,,,,,,23
11446: T81,0,0,0.000,,,,,359,359,0,,,,,,,24
11965: T81,0,0,0.000,,,,,359,359,0,,,,,,,25
12484: T81,0,0,0.000,,,,,359,359,0,,,,,,,26
13003: T81,0,0,0.000,,,,,359,359,0,,,,,,,27
13523: T81,0,0,0.000,,,,,359,359,0,,,,,,,28
14042: T81,0,0,0.000,,,,,359,359,0,,,,,,,29
14561: T81,0,0,0.000,,,,,359,359,0,,,,,,,30
15080: T81,0,0,0.000,,,,,359,359,0,,,,,,,31
15600: T81,0,0,0.000,,,,,359,359,0,,,,,,,32
16119: T81,0,0,0.000,,,,,359,359,0,,,,,,,33
16638: T81,0,0,0.000,,,,,359,359,0,,,,,,,34
17157: T81,0,0,0.000,,,,,359,359,0,,,,,,,35
17677: T81,0,0,0.000,,,,,359,359,0,,,,,,,36
18001: VBAT,78
18196: T81,0,0,0.000,,,,,359,359,0,,,,,,,37
18715: T81,0,0,0.000,,,,,359,359,0,,,,,,,38
19236: T81,0,0,0.000,,,,,359,359,0,,,,,,,39
19754: T81,0,0,0.000,,,,,358,358,0,,,,,,,40
20014: VBAT,79
20273: T81,0,0,0.000,,,,,358,358,0,,,,,,,41
20792: T81,0,0,0.000,,,,,358,358,0,,,,,,,42
21052: VBAT,78
21311: T81,0,0,0.000,,,,,354,354,0,,,,,,,43
21831: T81,0,0,0.000,,,,,350,350,0,,,,,,,44
22350: T81,0,0,0.000,,,,,350,350,0,,,,,,,45
22869: T81,0,0,0.000,,,,,347,347,0,,,,,,,46
23388: T81,0,0,0.000,,,,,347,347,0,,,,,,,47
23908: T81,0,0,0.000,,,,,345,345,0,,,,,,,48
24427: T81,0,0,0.000,,,,,344,344,0,,,,,,,49
24947: T81,0,0,0.000,,,,,344,344,0,,,,,,,50
25466: T81,0,0,0.000,,,,,344,344,0,,,,,,,51
25985: T81,0,0,0.000,,,,,344,344,0,,,,,,,52
26050: VBAT,79
26504: T81,0,0,0.000,,,,,344,344,0,,,,,,,53
27024: T81,0,0,0.000,,,,,344,344,0,,,,,,,54
27543: T81,0,0,0.000,,,,,344,344,0,,,,,,,55
28062: VBAT,78
28062: T81,0,0,0.000,,,,,344,344,0,,,,,,,56
28581: T81,0,0,0.000,,,,,344,344,0,,,,,,,57
29101: T81,0,0,0.000,,,,,344,344,0,,,,,,,58
29620: T81,0,0,0.000,,,,,344,344,0,,,,,,,59
30140: T81,0,0,0.000,,,,,344,344,0,,,,,,,60
30140: LOG,/data/video/usb1/P00.txt,"No such file or directory"
30140: LOG,/data/video/usb/P00.txt,ok
30658: T81,0,0,0.000,,,,,344,344,0,,,,,,,61
31178: T81,0,0,0.000,,,,,344,344,0,,,,,,,62
31697: T81,0,0,0.000,,,,,344,344,0,,,,,,,63
32217: T81,0,0,0.000,,,,,344,344,0,,,,,,,64
32735: T81,0,0,0.000,,,,,344,344,0,,,,,,,65
33255: T81,0,0,0.000,,,,,344,344,0,,,,,,,66
33775: T81,0,0,0.000,,,,,344,344,0,,,,,,,67
34294: T81,0,0,0.000,,,,,344,344,0,,,,,,,68
34813: T81,0,0,0.000,,,,,344,344,0,,,,,,,69
35332: T81,0,0,0.000,,,,,344,344,0,,,,,,,70
35851: T81,0,0,0.000,,,,,344,344,0,,,,,,,71
36370: T81,0,0,0.000,,,,,344,344,0,,,,,,,72
36890: T81,0,0,0.000,,,,,344,344,0,,,,,,,73
37409: T81,0,0,0.000,,,,,344,344,0,,,,,,,74
37928: T81,0,0,0.000,,,,,344,344,0,,,,,,,75
38448: T81,0,0,0.000,,,,,344,344,0,,,,,,,76
38967: T81,0,0,0.000,,,,,343,343,0,,,,,,,77
39486: T81,0,0,0.000,,,,,343,343,0,,,,,,,78
40006: T81,0,0,0.000,,,,,343,343,0,,,,,,,79
40525: T81,0,0,0.000,,,,,343,343,0,,,,,,,80
41044: T81,0,0,0.000,,,,,343,343,0,,,,,,,81
41564: T81,0,0,0.000,,,,,343,343,0,,,,,,,82
42084: T81,0,0,0.000,,,,,343,343,0,,,,,,,83
42602: T81,0,0,0.000,,,,,343,343,0,,,,,,,84
43121: T81,0,0,0.000,,,,,343,343,0,,,,,,,85
43641: T81,0,0,0.000,,,,,343,343,0,,,,,,,86
44160: T81,0,0,0.000,,,,,343,343,0,,,,,,,87
44679: T81,0,0,0.000,,,,,343,343,0,,,,,,,88
45200: T81,0,0,0.000,,,,,343,343,0,,,,,,,89
45718: T81,0,0,0.000,,,,,343,343,0,,,,,,,90
46237: T81,0,0,0.000,,,,,343,343,0,,,,,,,91
46756: T81,0,0,0.000,,,,,343,343,0,,,,,,,92
47276: T81,0,0,0.000,,,,,343,343,0,,,,,,,93
47796: T81,0,0,0.000,,,,,343,343,0,,,,,,,94
48315: T81,0,0,0.000,,,,,343,343,0,,,,,,,95
48834: T81,0,0,0.000,,,,,343,343,0,,,,,,,96
49354: T81,0,0,0.000,,,,,343,343,0,,,,,,,97
49872: T81,0,0,0.000,,,,,343,343,0,,,,,,,98
50392: T81,0,0,0.000,,,,,343,343,0,,,,,,,99
50911: T81,0,0,0.000,,,,,343,343,0,,,,,,,100
51430: T81,0,0,0.000,,,,,343,343,0,,,,,,,101
51950: T81,0,0,0.000,,,,,343,343,0,,,,,,,102
52469: T81,0,0,0.000,,,,,343,343,0,,,,,,,103
52989: T81,0,0,0.000,,,,,343,343,0,,,,,,,104
53508: T81,0,0,0.000,,,,,343,343,0,,,,,,,105
54027: T81,0,0,0.000,,,,,344,344,0,,,,,,,106
54546: T81,0,0,0.000,,,,,345,345,0,,,,,,,107
55066: T81,0,0,0.000,,,,,345,345,0,,,,,,,108
55585: T81,0,0,0.000,,,,,345,345,0,,,,,,,109
56104: T81,0,0,0.000,,,,,345,345,0,,,,,,,110
56624: T81,0,0,0.000,,,,,345,345,0,,,,,,,111
57143: T81,0,0,0.000,,,,,345,345,0,,,,,,,112
57662: T81,0,0,0.000,,,,,345,345,0,,,,,,,113
58182: T81,0,0,0.000,,,,,345,345,0,,,,,,,114
58701: T81,0,0,0.000,,,,,345,345,0,,,,,,,115
59220: T81,0,0,0.000,,,,,345,345,0,,,,,,,116
59739: T81,0,0,0.000,,,,,345,345,0,,,,,,,117
60259: T81,0,0,0.000,,,,,345,345,0,,,,,,,118
60778: T81,0,0,0.000,,,,,345,345,0,,,,,,,119
61297: T81,0,0,0.000,,,,,345,345,0,,,,,,,120
61816: T81,0,0,0.000,,,,,345,345,0,,,,,,,121
62336: T81,0,0,0.000,,,,,345,345,0,,,,,,,122
62856: T81,0,0,0.000,,,,,345,345,0,,,,,,,123
63375: T81,0,0,0.000,,,,,345,345,0,,,,,,,124
63894: T81,0,0,0.000,,,,,345,345,0,,,,,,,125
64413: T81,0,0,0.000,,,,,345,345,0,,,,,,,126
64933: T81,0,0,0.000,,,,,345,345,0,,,,,,,127
65452: T81,0,0,0.000,,,,,345,345,0,,,,,,,128
65971: T81,0,0,0.000,,,,,345,345,0,,,,,,,129
66491: T81,0,0,0.000,,,,,345,345,0,,,,,,,130
67010: T81,0,0,0.000,,,,,345,345,0,,,,,,,131
67529: T81,0,0,0.000,,,,,345,345,0,,,,,,,132
68049: T81,0,0,0.000,,,,,345,345,0,,,,,,,133
68568: T81,0,0,0.000,,,,,345,345,0,,,,,,,134
69088: T81,0,0,0.000,,,,,345,345,0,,,,,,,135
69607: T81,0,0,0.000,,,,,345,345,0,,,,,,,136
70127: T81,0,0,0.000,,,,,345,345,0,,,,,,,137
70646: T81,0,0,0.000,,,,,345,345,0,,,,,,,138
71166: T81,0,0,0.000,,,,,345,345,0,,,,,,,139
71684: T81,0,0,0.000,,,,,345,345,0,,,,,,,140
72204: T81,0,0,0.000,,,,,345,345,0,,,,,,,141
72723: T81,0,0,0.000,,,,,345,345,0,,,,,,,142
73242: T81,0,0,0.000,,,,,345,345,0,,,,,,,143
73761: T81,0,0,0.000,,,,,345,345,0,,,,,,,144
74281: T81,0,0,0.000,,,,,345,345,0,,,,,,,145
74800: T81,0,0,0.000,,,,,345,345,0,,,,,,,146
75319: T81,0,0,0.000,,,,,345,345,0,,,,,,,147
75839: T81,0,0,0.000,,,,,345,345,0,,,,,,,148
76358: T81,0,0,0.000,,,,,345,345,0,,,,,,,149
76878: T81,0,0,0.000,,,,,345,345,0,,,,,,,150
77397: T81,0,0,0.000,,,,,345,345,0,,,,,,,151
77917: T81,0,0,0.000,,,,,345,345,0,,,,,,,152
78436: T81,0,0,0.000,,,,,345,345,0,,,,,,,153
78956: T81,0,0,0.000,,,,,345,345,0,,,,,,,154
79474: T81,0,0,0.000,,,,,345,345,0,,,,,,,155
79994: T81,0,0,0.000,,,,,345,345,0,,,,,,,156
80513: T81,0,0,0.000,,,,,345,345,0,,,,,,,157
81032: T81,0,0,0.000,,,,,345,345,0,,,,,,,158
81552: T81,0,0,0.000,,,,,345,345,0,,,,,,,159
82071: T81,0,0,0.000,,,,,345,345,0,,,,,,,160
82591: T81,0,0,0.000,,,,,345,345,0,,,,,,,161
83110: T81,0,0,0.000,,,,,345,345,0,,,,,,,162
83629: T81,0,0,0.000,,,,,345,345,0,,,,,,,163
84150: T81,0,0,0.000,,,,,345,345,0,,,,,,,164
84668: T81,0,0,0.000,,,,,345,345,0,,,,,,,165
85187: T81,0,0,0.000,,,,,345,345,0,,,,,,,166
85252: VBAT,77
85707: T81,0,0,0.000,,,,,345,345,0,,,,,,,167
86227: T81,0,0,0.000,,,,,345,345,0,,,,,,,168
86745: T81,0,0,0.000,,,,,345,345,0,,,,,,,169
87265: T81,0,0,0.000,,,,,345,345,0,,,,,,,170
87784: T81,0,0,0.000,,,,,345,345,0,,,,,,,171
88303: T81,0,0,0.000,,,,,345,345,0,,,,,,,172
88823: T81,0,0,0.000,,,,,345,345,0,,,,,,,173
89277: VBAT,78
89342: T81,0,0,0.000,,,,,345,345,0,,,,,,,174
89861: T81,0,0,0.000,,,,,345,345,0,,,,,,,175
90381: T81,0,0,0.000,,,,,345,345,0,,,,,,,176
90900: T81,0,0,0.000,,,,,345,345,0,,,,,,,177
91419: T81,0,0,0.000,,,,,345,345,0,,,,,,,178
91939: T81,0,0,0.000,,,,,345,345,0,,,,,,,179
92458: T81,0,0,0.000,,,,,345,345,0,,,,,,,180
92979: T81,0,0,0.000,,,,,345,345,0,,,,,,,181
93302: VBAT,77
93497: T81,0,0,0.000,,,,,345,345,0,,,,,,,182
94016: T81,0,0,0.000,,,,,345,345,0,,,,,,,183
94536: T81,0,0,0.000,,,,,345,345,0,,,,,,,184
95055: T81,0,0,0.000,,,,,345,345,0,,,,,,,185
95574: T81,0,0,0.000,,,,,345,345,0,,,,,,,186
96093: T81,0,0,0.000,,,,,345,345,0,,,,,,,187
96613: T81,0,0,0.000,,,,,345,345,0,,,,,,,188
97133: T81,0,0,0.000,,,,,345,345,0,,,,,,,189
97327: VBAT,78
97651: T81,0,0,0.000,,,,,345,345,0,,,,,,,190
98171: T81,0,0,0.000,,,,,345,345,0,,,,,,,191
98694: T81,0,0,0.000,,,,,345,345,0,,,,,,,192
99210: T81,0,0,0.000,,,,,345,345,0,,,,,,,193
99729: T81,0,0,0.000,,,,,345,345,0,,,,,,,194
100249: T81,0,0,0.000,,,,,345,345,0,,,,,,,195
100768: T81,0,0,0.000,,,,,345,345,0,,,,,,,196
101287: T81,0,0,0.000,,,,,345,345,0,,,,,,,197
101807: T81,0,0,0.000,,,,,345,345,0,,,,,,,198
102326: T81,0,0,0.000,,,,,345,345,0,,,,,,,199
102845: T81,0,0,0.000,,,,,345,345,0,,,,,,,200
103365: VBAT,77
103365: T81,0,0,0.000,,,,,345,345,0,,,,,,,201
103884: T81,0,0,0.000,,,,,345,345,0,,,,,,,202
104403: T81,0,0,0.000,,,,,345,345,0,,,,,,,203
104923: T81,0,0,0.000,,,,,345,345,0,,,,,,,204
105442: T81,0,0,0.000,,,,,345,345,0,,,,,,,205
105962: T81,0,0,0.000,,,,,345,345,0,,,,,,,206
106481: T81,0,0,0.000,,,,,345,345,0,,,,,,,207
107001: T81,0,0,0.000,,,,,345,345,0,,,,,,,208
107325: VBAT,78
107520: T81,0,0,0.000,,,,,345,345,0,,,,,,,209
108039: T81,0,0,0.000,,,,,345,345,0,,,,,,,210
108558: T81,0,0,0.000,,,,,345,345,0,,,,,,,211
109078: T81,0,0,0.000,,,,,345,345,0,,,,,,,212
109597: T81,0,0,0.000,,,,,345,345,0,,,,,,,213
110118: T81,0,0,0.000,,,,,345,345,0,,,,,,,214
110636: T81,0,0,0.000,,,,,345,345,0,,,,,,,215
111155: T81,0,0,0.000,,,,,345,345,0,,,,,,,216
111675: T81,0,0,0.000,,,,,345,345,0,,,,,,,217
112195: T81,0,0,0.000,,,,,345,345,0,,,,,,,218
112714: T81,0,0,0.000,,,,,345,345,0,,,,,,,219
113233: T81,0,0,0.000,,,,,345,345,0,,,,,,,220
113752: T81,0,0,0.000,,,,,345,345,0,,,,,,,221
114272: T81,0,0,0.000,,,,,345,345,0,,,,,,,222
114792: T81,0,0,0.000,,,,,345,345,0,,,,,,,223
115314: T81,0,0,0.000,,,,,345,345,0,,,,,,,224
115830: T81,0,0,0.000,,,,,345,345,0,,,,,,,225
116349: T81,0,0,0.000,,,,,345,345,0,,,,,,,226
116869: T81,0,0,0.000,,,,,345,345,0,,,,,,,227
117388: T81,0,0,0.000,,,,,345,345,0,,,,,,,228
117908: T81,0,0,0.000,,,,,345,345,0,,,,,,,229
118427: T81,0,0,0.000,,,,,345,345,0,,,,,,,230
118947: T81,0,0,0.000,,,,,345,345,0,,,,,,,231
119466: T81,0,0,0.000,,,,,345,345,0,,,,,,,232
119986: T81,0,0,0.000,,,,,345,345,0,,,,,,,233
120505: T81,0,0,0.000,,,,,345,345,0,,,,,,,234
121025: T81,0,0,0.000,,,,,345,345,0,,,,,,,235
121544: T81,0,0,0.000,,,,,345,345,0,,,,,,,236
122064: T81,0,0,0.000,,,,,345,345,0,,,,,,,237
122388: VBAT,77
122583: T81,0,0,0.000,,,,,345,345,0,,,,,,,238
123103: T81,0,0,0.000,,,,,345,345,0,,,,,,,239
123427: VBAT,78
123622: T81,0,0,0.000,,,,,345,345,0,,,,,,,240
124141: T81,0,0,0.000,,,,,345,345,0,,,,,,,241
124401: VBAT,77
124660: T81,0,0,0.000,,,,,345,345,0,,,,,,,242
125180: T81,0,0,0.000,,,,,345,345,0,,,,,,,243
125699: T81,0,0,0.000,,,,,345,345,0,,,,,,,244
126219: T81,0,0,0.000,,,,,345,345,0,,,,,,,245
126738: T81,0,0,0.000,,,,,345,345,0,,,,,,,246
127257: T81,0,0,0.000,,,,,345,345,0,,,,,,,247
127777: T81,0,0,0.000,,,,,345,345,0,,,,,,,248
128296: T81,0,0,0.000,,,,,345,345,0,,,,,,,249
128816: T81,0,0,0.000,,,,,345,345,0,,,,,,,250
129335: T81,0,0,0.000,,,,,345,345,0,,,,,,,251
129855: T81,0,0,0.000,,,,,345,345,0,,,,,,,252
130374: T81,0,0,0.000,,,,,345,345,0,,,,,,,253
130894: T81,0,0,0.000,,,,,345,345,0,,,,,,,254
131413: T81,0,0,0.000,,,,,345,345,0,,,,,,,255
131932: T81,0,0,0.000,,,,,345,345,0,,,,,,,256
132452: T81,0,0,0.000,,,,,345,345,0,,,,,,,257
132971: T81,0,0,0.000,,,,,345,345,0,,,,,,,258
133491: T81,0,0,0.000,,,,,345,345,0,,,,,,,259
134010: T81,0,0,0.000,,,,,345,345,0,,,,,,,260
134529: T81,0,0,0.000,,,,,345,345,0,,,,,,,261
135049: T81,0,0,0.000,,,,,345,345,0,,,,,,,262
135568: T81,0,0,0.000,,,,,345,345,0,,,,,,,263
136089: T81,0,0,0.000,,,,,345,345,0,,
no gps data right?
and theres no way for me to monitor in setup whilst its plugged into drone is there
PS. I havent actually flown the drone, is that something I need to do for it to log? its just sat there powered on in my window with a gps fix and USB stick inserted yet no gps data in log
Old Dec 22, 2012, 05:51 PM
pawelsky's Avatar
Poland
Joined Jan 2012
No blinking means no data from GPS
Old Dec 22, 2012, 05:59 PM
SJW2511 is offline
Joined Nov 2012
I know lol but why. Surely a0 and a1 should not be outputting 5v when mod connected to Drone? When in setup test with ftdi they don't even output a volt. Why are they 5v lives when all they are doing is sending data?
They are the same with all my mods too. But only 5v when plugged into Drone. There must be a way of making them behave like they do in setup test
Old Dec 22, 2012, 06:10 PM
pawelsky's Avatar
Poland
Joined Jan 2012
I've asked you to check/try a couple of things (http://www.rcgroups.com/forums/showp...postcount=3859). It is really hard to help you if you do not follow instructions...
Old Dec 22, 2012, 06:16 PM
SJW2511 is offline
Joined Nov 2012
Well iv not tried powering the whole lot from a ubec because it's not really an option if I have to do that I will have to forget gps as the people I have made for don't have ubecs
Iv checked the vccs
There wasn't anything else was there
Something, and I don't know if it's something in the miru code.? Is making a0 and a1 run at 5v live. They only become 5v at the point the program starts running and the Drone is ready to launch.
They are even 5v on ones iv made with nothing else attached
Are they meant to be 5v? I would have thought they should operate at similar thresholds to the receivers lines
Old Dec 22, 2012, 06:25 PM
pawelsky's Avatar
Poland
Joined Jan 2012
Well iv not tried powering the whole lot from a ubec because it's not really an option if I have to do that I will have to forget gps as the people I have made for don't have ubecs.
Without UBEC you can forget about GPS working with proMini anyway.
Iv checked the vccs
I've asked for photos of the setup.
Old Dec 22, 2012, 06:31 PM
SJW2511 is offline
Joined Nov 2012
Can get photos tomorrow.
The idea was to supply the gps/ubec as a package to people who wanted gps, to power the unit would require complete rewiring of there kits
Do you have any comments about a0 and a1 running at 5v if its meant to be like that then at least i can forget about it, but it seems strange to me and I'm sure it's what's causing my overheating problem and possibly why it won't get gps data in practical tests
Thanks for your help anyway so far buddy it is appreciated
Old Dec 22, 2012, 07:03 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
A0 is TXo for GPS, the idle state is 5V. A1 is RXi for GPS, it is pulled up to 5V by the processor's internal pullup. If you don't use a GPS don't connect anything to these pins. If you ground anyone of them it could explain the heating up of your Arduino. Also, did you ever measure how much current your RX draws?
miru is offline Find More Posts by miru
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 05:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 10:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 11:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 12:04 PM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 04:54 PM
