Old Dec 16, 2012, 11:06 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Originally Posted by dante1 View Post
Just bridged the two pins and with a fine tip... easy as pie.
Attachment 5376957
And did it fix your problem?
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Dec 16, 2012, 11:18 AM
dante1 is offline
Find More Posts by dante1
XR-4Drone.com
dante1's Avatar
Canada, QC, Montreal
Joined May 2011
Don't really have time to test it out. And don't have a kit that is giving me this issue at the moment.
dante1 is offline Find More Posts by dante1
Old Dec 16, 2012, 01:08 PM
pawelsky is offline
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Originally Posted by miru View Post
Pin 25 (right next to 26) should be on GND so this can be fixed without major effort.
Yes, that fix is described in the thread I mentioned, the question is - will it fix the problem. gtsullivan seems to use 3.1 version (that is supposed to have this issue solved already) and still reporting the booting problem.
pawelsky is offline Find More Posts by pawelsky
Old Dec 16, 2012, 05:55 PM
SJW2511 is offline
Find More Posts by SJW2511
Joined Nov 2012
With the gps mod I believe it's possible to log your flight path data, where does it get written to for me to retrieve?
SJW2511 is offline Find More Posts by SJW2511
Old Dec 16, 2012, 06:04 PM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
USB or /data/video - details here http://mirumod.tk/sw/drs019.php (6th and 7th bullet)
Old Dec 17, 2012, 03:26 AM
SJW2511 is offline
Joined Nov 2012
Thank you assume the data folder on Drone is accessible via ftp?
Old Dec 17, 2012, 03:51 AM
grazuk is offline
Find More Posts by grazuk
Joined Jun 2012
Just got a BMP085 board, one which can use 3.3 or 5v , so hooked it upto the 5v line on my Arduino nano and ran into the same problem as Pawelsky had at first , and was getting no reading, tried adding the pull up code that happul3 posted to his modded Miru code and still nothing. So added a couple of pull up resitors to between the 5vline on the Arduino nano to both the sda and sdl line and still could not get it to work. I started off with a couple of 4.7k resistors, but swapped them out for 2.2k ones and tried again and on setup it was working with updated readings now.
So was all raring to go and went outside and drone and mod stated up and was ready to take off and all of a sudden I noticed the Arduino nano led and the motor leds all suddenly went out.
Tried unplugging battery and plugging back in and nothing part from a brief flash of led on Arduino nano and the drone motors led.
So my Navi board seems to have failed again, I did check the wiring and connections from the mod to the ar done and no shorts etc, and nothing to do with any of the mods, just that my board failed again.
No main LED on the main navi board so its pretty much dead.
I have replaced a ic on this board before, but it seems a different one died this time and had to order the part from the USA, so will trying to replace the chip first before I buy a expensive Navi board.
Thanks to all the pro's on here working on this , I think its awesome the work people are putting in on the mods for the standard drone. Lookng forward to playing again when I get mine back up and running.
Keep up the great work and once again thanks to all.
grazuk is offline Find More Posts by grazuk
Old Dec 17, 2012, 04:17 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Yes, that is the default home directory when you connect via FTP
Old Dec 18, 2012, 01:55 AM
SJW2511 is offline
Joined Nov 2012
can you do return to home using gps? im using rev19 software, iv read parts which suggest its been disabled yet was working in rev18, if it has been disabled where can i renable it in the code? for testing purposes mainly
Old Dec 18, 2012, 09:48 AM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
You can't enable it in rev 0.19.
miru is offline Find More Posts by miru
Old Dec 18, 2012, 09:58 AM
SJW2511 is offline
Joined Nov 2012
Ah ok, where is it disabled? in the pilot file or the sketch?
just wondering if i could use a rev 18 pilot file and rename it
Old Dec 18, 2012, 10:01 AM
miru is offline
Vista, CA
Joined Feb 2008
It's in the pilot file.
Old Dec 18, 2012, 10:03 AM
SJW2511 is offline
Joined Nov 2012
Would using a rev 18 pilot and rename it pilot19 etc work
Old Dec 18, 2012, 10:07 AM
miru is offline
Vista, CA
Joined Feb 2008
The paste screen for generation of my LLC does work (http://www.rcgroups.com/forums/showp...postcount=3701).
Here are pictures of my newest version of the mod on a drone 1. BTW this uses a cheap Chinese Nano, with lockbits set to CC (no effect). This version uses only 2 wires! Not much that can go wrong.
Old Dec 18, 2012, 10:10 AM
miru is offline
Vista, CA
Joined Feb 2008
No, sketch, companion and pilot are paired in the sense that they need to know each other's datastructures and paradigms to communicate.
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
