Espritmodel.com Heli Air
Old Dec 12, 2012, 03:35 PM
MiruMod supporter
pawelsky's Avatar
Polska
Joined Jan 2012
Originally Posted by Fioulmaster View Post
Cool!
Did you tested in flight?
Nothing to configure the module?
Is it possible that you do a mini-tutorial for this module?
No, too cold to fly outdoors in my area. Did not have to configure anything, just connected and got the BMP readings as expected. For the HMC I guess I'll need to do some calibration. I guess it is too early for tutorials yet.
pawelsky is offline Find More Posts by pawelsky
Old Dec 12, 2012, 03:55 PM
Joined Oct 2011
Ok, i Will buy it at the end of month.
Fioulmaster is offline Find More Posts by Fioulmaster
Old Dec 13, 2012, 10:32 AM
Joined Jul 2011
You need to disconnect the cable that goes from the mod to a socket at the bottom of the Drone.
Thank you. Sorry for late reply.
I started making the mod. I am still confused about that. After i unplug it,is the GPS signal still transfer back to my PC through ARDrone wifi?
solarprism is offline Find More Posts by solarprism
Old Dec 13, 2012, 11:13 AM
MiruMod supporter
pawelsky's Avatar
Polska
Joined Jan 2012
No, GPS is connected to the mod, so if you unplug the mod from the Drone it can't transfer the data.
Old Dec 13, 2012, 01:59 PM
Joined Nov 2012
Not sure if this is the correct place to post this, but here goes: it is known that the Drone 1 has more power and greater lift capacity than the Drone 2. The assumption is that this is due to firmware that limits the Drone 2 to 80% power to maintain a power reserve for flip recovery. If this is true how would one go about hacking the firmware to boost motor power?
VytasandRio is offline Find More Posts by VytasandRio
Old Dec 14, 2012, 12:54 AM
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
Miru will surely be able to give more pros for this shifter, but I can see at least 4
1) proper reference voltage for the IO levels coming from the regulator (either 1.8V or 3.3V) which I guess shall make it more stable
2) drone plug can be soldered directly to it, so it can serve as plug. This also limits the chances of getting wires wrong.
3) if you prefer keep it on Arduino's side - it fits nicely the GND/VIN/TX/RX pins. Again, less chances to have wiring wrong.
4) the diode is built in.
Oke thanks, that sounds sweet and I'd definitely order one or two then
RHTizzy is offline Find More Posts by RHTizzy
Old Dec 14, 2012, 06:59 AM
Joined Jun 2012
Any links to where this is documented? Have people measured the maximum lifting capacity of both? What props were they using?
I read that the D2 props had a steeper profile than the old D1 props, for better recovery after flips. Apparently, putting old style D1 props on a D2 and it won't flip nearly as well. Don't know if that's true though. Could be just packaging.
Can't buy the old D1 props any more, probably to avoid that problem (if true), as this online listing explains:
"These Propellors are now for both Parrot AR.Drone models 1.0 and 2.0. The Parrot AR.Drone 1.0 propellors have now been discontinued so please use these for your AR.Drone 1.0 and 2.0."
Brandigan is offline Find More Posts by Brandigan
Old Dec 14, 2012, 02:51 PM
United States, OH, Powell
Joined Dec 2006
Flipping the Drone 2 requires that the battery be above 50% ( I think that is the number ). Using supplied batteries seems to be able to do flips during the first two minutes of flight. I bought some 1300 Mah 45-90 C nano-tech batteries from Hobby King...besides giving me over 10 minutes of flying time...I am able to flip the drone well past the 5 min mark.
rjrobbin is offline Find More Posts by rjrobbin
Old Dec 14, 2012, 04:02 PM
Vista, CA
Joined Feb 2008
Originally Posted by SJW2511 View Post
so just hyperterminal then?
but you think it should be ready to go out the box anyway?
Yes, at least that is what my UP501 did.
miru is offline Find More Posts by miru
Old Dec 14, 2012, 04:06 PM
Vista, CA
Joined Feb 2008
Originally Posted by dante1 View Post
Hey Miru, do you by any chance have the proper bootloader for the Arduino Nano? I checked a couple of my arduino nano and they have a CC lock bit and from another supply lockbit is CF. I contacted my supplier and he said that there was nothing wrong with the lockbit.
According to the processor datasheet lock bits CC inhibit further programming of the flash and eerom. You want them to be CF (bit 1,0 NOT programmed). I use the bootloader from the Arduino IDE.
Old Dec 14, 2012, 04:08 PM
Vista, CA
Joined Feb 2008
5) uses a MOSFET that can reliably deal with the 1.8V.
Old Dec 14, 2012, 04:14 PM
Vista, CA
Joined Feb 2008
Cool!
I wait your full return to click "BUY".
MIRU?! Do you think it will be possible to use this module on a D1 in the near future with the GPS?
It is independent of the GPS. I am working on integrating it as well as the HMC5883 magnetometer. Happul3 got the barometer working and uses it to stabilize altitude if you leave the throttle stick alone for 4 seconds. Unfortunately it takes a lot of code space to deal with these extra sensors, which means the ccompanion program would have to be installed on the drone...
Old Dec 14, 2012, 04:18 PM
Joined Nov 2012
RE: gps again, i hooked it straight into the arduino pro mini, and a chip on it got very hot, im assuming that is whats meant when it states the pro mini cannot handle the load.
could i wire the gps 5v and gnd into the LLC would that handle it?
SJW2511 is offline Find More Posts by SJW2511
Old Dec 14, 2012, 04:43 PM
Joined Oct 2011
Ok. Thanks for the response.
Old Dec 14, 2012, 04:48 PM
Joined Oct 2011
You must use a UBEC with pro-mini for power the gps.
See here for more infos.
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 113 May 13, 2011 02:26 PM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
