hi y'all.. new happy owner this parrot AR drone.(scored it pretty cheap at BB a price error
![]() ). would like to do this TX mod..i have futaba 9c and T9x..also spektrum dx7... i'm familliar with the ardrino pro mini, have quad and tricopter on multi wii...there is 3600+ post here.. reading all i can..eyes and brain getting lazy.. ![]() understand the code is "rx2at" (code for the ardrino)and "at2so"(to read the code in the drone).. ..pls correct me if wrong..also..are these the latest code..rx2at and at2so.. or please direct me to the latest codes.. thanks in advance..
Joined Jun 2012
What conditions cause the sketch to hand over control to the Drone to Land? Is a Low battery (after VLBA LEDs have been ignored) treated the same way as flicking the 'Land' switch or a Tx/Rx range/fault error beyond allowable time? I can't work out what the code at line 1142-???? is doing with the sticks when FMS_LAND is signalled, but if it was possible to have controlled, steerable, semi-automatic landing it would be very useful. Anyway, I'm repeating myself, so I guess we wait and see.
"Too much angle" emergency in recent firmwares
FYI While going through the release notes for latest Drone firmwares I've found an interesting improvement
Joined Aug 2012
Joined Jun 2012
The Sketch could do much the same and not hand over control to the drone until a few metres above the ground - when you don't need steering any more - and let it kill the motors etc. Until then, it could allow some steering - in the case of 'Land by switch' - and in the case of 'Land by loss of Tx signal', allow TS_UP to regain control when back in range. 'Land by Emergency low battery': unless you can stop the firmware elbowing in and taking over, can't be changed. But if the Sketch can tell the firmware not to worry until the battery is at 1%, but does the Low battery landing itself at 10% (or whatever the point the firmware takes over currently), then it could handle that too. Not saying it's trivial - although the main loop with extra flags to flash LEDs, reduce steering angles to 'avoid trees only' levels to avoid people trying to continue doing tricks etc. and delay handing over to the firmware until 2 meters above the ground, would just about cover it - but it would be useful. If nothing else, it could also help complement GPS RTH, when you see it's following a nice straight line into a tree - unless waypoints are going to be implemented soon. |
Is the connector the only difference between Drone 1 and 2 versions, or you also need to change some other components?
| Thread Tools | |
| Mini-HowTo RC Controlled AR.Drone w/o WiFi! | nosaari | Multirotor Talk | 113 | May 13, 2011 02:26 PM |
| For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 4 | Apr 16, 2011 09:42 PM |
| Discussion Wifi Boosted AR.Drone | Fallengod | Multirotor Talk | 7 | Feb 12, 2011 10:52 AM |
| Discussion And yet another AR drone Arial Video project | taudronis | Multirotor Talk | 17 | Dec 07, 2010 11:04 AM |
| Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad | Hoverup | Aircraft - Electric - Helis (FS/W) | 0 | Oct 12, 2010 03:54 PM |
