United States, VA, Centreville
Joined Oct 2012
Miru,
I checked and double checked the level shifter. A Pro Mini works in the identical circuit on the breadboard - the level shifter is wired correctly. I have done a quick experiment with a sketch running loop-back serial where I connected a 5 Volt Sparkfun FT232R directly to the RX and TX on the Nano and the Nano is powered externally with 5 Volts (No USB cable connected to the Nano). Same problem. Here there is no level shifter to add doubt. The RX input line is exhibiting "strong" pull-up behavior. The Nano was ONLY connected to power and the RX/TX lines (not on my MiruMod breadboard). The same test sketch runs perfectly on the Pro Mini connected to the FT232R and the same external power supply. When I disconnect the RX line from the Nano (mounted on the MiruMod breadboard and connected to the Drone via cable) and monitor the output from the level shifter HV side, I see serial data at the appropriate voltage levels and it decodes at 38,400 baud. Further confirmation the level shifter is fine. I remain convinced there is a problem with the Nano (two of them!). I wrote to Gravitech with extensive testing details. I hope to hear from them if they have seen the problem before. Thanks for the input. George |
Joined Aug 2012
Edit: I can see that you've already done the test and nano is to blame... |
Joined Oct 2012
Should have said I checked both sides of the level shifter. My scope is quad input with 16 channels of logic decoding. The drone side RX and TX (LV) track fine. No matter what state the Drone to Nano LV side is in, when connected to the Nano RX on the HV side, RX is always high (with next to zero noise on the line) on the Nano. When the RX line is disconnected from the Nano, the HV signal tracks the LV.
On the LV side, the swing is about 1.7 volts and the HV side is just under 5 if I remember correctly (forgot to write it down). Looking at the Nano TX line, there is a very, very small amount of noise (insignificant to the standards). On the RX pin on the Nano, there is almost none (thus why I said "strong" pull-up). Thanks again, George |
Vista, CA
Joined Feb 2008
Joined Nov 2012
has anyone experienced this problem?
using the AR6115e Spektrum receiver, about 50% of the time when you switch the drone on, at the point it loads the code to the drone and normally the motor lights flash red green to indicate its ready, the arduino red led will stay solid and wont complete. I have to power the drone on/off a few times then it works. Very strange, using an arduino nano, tried two nanos and two receivers of the same type, any ideas? |
Vista, CA
Joined Feb 2008
Joined Nov 2012
cheked them all, and remade the whole thing twice, same thing on both, weird thing it works, but about 50% of the time
on my AR600 based unit its fine all the time, i didhowever use thinner grade wires in these ones as they were more flexible, cant see it being that though works 100% fine when checking in hyperterminal |
| Thread Tools | |
| Mini-HowTo RC Controlled AR.Drone w/o WiFi! | nosaari | Multirotor Talk | 113 | May 13, 2011 02:26 PM |
| For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 4 | Apr 16, 2011 09:42 PM |
| Discussion Wifi Boosted AR.Drone | Fallengod | Multirotor Talk | 7 | Feb 12, 2011 10:52 AM |
| Discussion And yet another AR drone Arial Video project | taudronis | Multirotor Talk | 17 | Dec 07, 2010 11:04 AM |
| Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad | Hoverup | Aircraft - Electric - Helis (FS/W) | 0 | Oct 12, 2010 03:54 PM |
