Old Nov 18, 2012, 02:06 PM
happul3 is offline
Find More Posts by happul3
Joined Aug 2012
Originally Posted by miru View Post
Check the SDK for additions/deletions. <frequency> is the frequency of the pattern in HZ, you have to send an integer (e.g. 5Hz would be 1084227584) and <duration> is the duration of the pattern in seconds, 0 meaning forever or until something else comes up.
Don't shoot me, I did not design this...
That's very helpful, thank you. Is frequency parameter ignored when steady pattern is specified (for example, #6 - standard)?
happul3 is offline Find More Posts by happul3
Old Nov 18, 2012, 02:19 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
I don't know, can't hurt to try. The integer number is generated the following way:
Code:
union { float f; int i; } f;
f.f = 5.0;
printf("f.f=%.1f i=%d\n",f.f,f.i);
miru is offline Find More Posts by miru
Old Nov 18, 2012, 02:48 PM
pawelsky is offline
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
You may find this useful
http://gauth.fr/2011/09/control-the-ar-drone-leds/
pawelsky is offline Find More Posts by pawelsky
Old Nov 18, 2012, 06:15 PM
happul3 is offline
Joined Aug 2012
Originally Posted by pawelsky View Post
Thank you Miru and Pawelsky - visual indication works nicely. It confirms that barometric altitude stabilization is working for drone 1.
If anyone wants, I can provide modified Miru's sketch v19 that includes altitude stabilization functionality for drone 1. It'll also require as little as $10 worth of hardware: bmp085 module and level shifter (some bmp085 modules sold on ebay include level shifter on the same board - that'd make it even easier, but I realized it too late).
Old Nov 18, 2012, 06:35 PM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Nice, can you share some more details how it works and some wiring diagrams?
P.S. I guess that one will be OK?
P.P.S. I've also found this which is a barometer and compass on one small board. Assuming miru can use that compass for his RTH implementation that would be a nice addition to Drone 1 sensors.
Old Nov 18, 2012, 08:20 PM
happul3 is offline
Joined Aug 2012
Yes, this module seems perfect. It will have to be wired exactly as shown in the second diagram in that listing: 5V - VCC; GND - GND; SCL - A5; SDA - A4. No additional wiring is needed.
BMP085 takes 25.5 ms to acquire pressure sample in highest accuracy mode which works well with 30 Hz mod's loop frequency. So, in a nutshell, at each cycle of main loop (I've included pressure measurements in setup code as well), code reads acquired pressure and starts new acquisition (periodically, temperature is read as well to improve accuracy of pressure calculation). Actual acquisition process happens in the background. So the process of getting samples from bmp085 does not consume any significant cpu time.
The pressure samples are averaged (16 of them, 0.5 sec worth) to reduce noise, and average values are used to add input to throttle channel. The additional input added as follows: sio_sid(',',gl.rxs.chn[S_GAZ].val + throttle_correction);
Basically, once the throttle stick if throttle stick is untouched for 4 seconds, the pressure reading is stored and any subsequent deviations from that pressure will result in throttle_correction value that is proportional to that deviation. Once the throttle stick is touched, stabilization process and reference pressure are cancelled and code waits for another period of 4 sec with untouched throttle.
I did not really spent much time yet to optimize various adjustable parameters: averaging, delay to start stabilization, proportionality coefficient between pressure and stick input, etc.
I tried to preserve the original mod as much as possible, but had to make one large change. The bmp085-related code does not fit in small remaining memory so I had to cut off the arm code and rely on preinstalled at2so.arm. Other than that there are almost no changes, only additional code inserted.
Last edited by happul3; Dec 02, 2012 at 11:05 AM. Reason: bug was found in the code that was originally attached to this post
Old Nov 19, 2012, 02:50 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Thanks for detailed explanation.
Will the one with compass also work without modifications in sketch (I'm not expert in I2C)? I may go for that one to be future' proof
It will have to be wired exactly as shown in the second diagram in that listing: 5V - VCC; GND - GND; SCL - A3; SDA - A2. No additional wiring is needed
On the diagram it is wired to A4/A5, could you please confirm that it needs to be A4/A5 or A2/A3?
Old Nov 19, 2012, 08:04 AM
happul3 is offline
Joined Aug 2012
As far as I know, additional device such as compass on i2c bus should not be a problem. It will not interact with the bus until its address is explicitly called. So, yes, my guess is the module with compass will work without modifications to the code or wiring.
And it will be quite easy to introduce modifications to the sketch to communicate with compass using the same low level functions.
Sorry, it was a typo on my part. It most definitely is A4/A5 and I've edited original post to reflect that. The diagram in the ebay listing is correct.
Old Nov 19, 2012, 08:51 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Yes
OK, thanks.
I must be missing something here, so apologies if I'm being an idiot. Won't be the first or last time...
Communication to the Drone is through GND>Tx and GND>Rx, right?
To see what voltage is going to the D1 Drone, I measure GND>TX and GND>RX on both the Nano and Pro Mini?
Annotation on the Level Shifter diagram says "3.3v I/O No Wire AR.Drone 1.0"
On the non LLS Rev 0.13 diagram there is a 'must have' 4.7k resistor which limits current, but still sends 5v through GND>Tx and Rx.
So if the D1 wants/needs 3.3v for I/O on the LLS Mod (and actually only gets 2.5v), is it OK for it to be getting 5v with the Rev 0.13 Resistor Mod?
Follow up question. My Pro Mini is this one: http://www.ebay.co.uk/itm/230795578198 which is adjustable for 3.3v/5v output (defaults to 5v). No idea which outputs though.
If I set it to 3.3v will my D1 be happier with the Rev 0.13 version Mod?
Also, if I'm only outputting 3.3v in the first place, what connections might I need on the Level Shifter with a Pro Mini and a D2?
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Nov 19, 2012, 09:16 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Ordered both (so I'll have a spare just in case). Will try them out once they arrive and share results.
Old Nov 19, 2012, 09:53 AM
obelix662000 is offline
Find More Posts by obelix662000
Joined Oct 2011
Output depends on Vcc (1.8-6V for this processor). If you select 5V option it will give ~4.5V output at the pins, if power option is 3.3V you will get around 2.7V at the pins. For 5v selection of Vcc you should use schematic as it shown for regular Arduino Pro.
obelix662000 is offline Find More Posts by obelix662000
Old Nov 19, 2012, 09:56 AM
miru is offline
Vista, CA
Joined Feb 2008
OK, thanks.
According to the datasheet for the Atmega 328p you can not run the processor at 16 Mhz with a 3.3V VCC. Unless the ProMini you found runs the processor at 5V AND does 3.3V I/O (which I seriously don't believe) you will need to run it at 5V, which makes the board no different from a regular ProMini as far as the mod is concerned.
The mod with the resistor in the Arduino TX -> Drone RX line is limiting the current that flows between the output of the Arduino and the clamped input of the drone. The drone input clamps to VCC (3.3V) of the drone, if you don't limit the current the Arduino drives into this input (it can deliver up to 40mA), you will eventually fry the input clamp on the drone and render the receiver of the tty port useless ($100 mistake). If you use a 4.7K resistor, the maximum current the clamp has to 'swallow' is (5-3.3)/4.7K=0.36mA, a current small enough for the clamp to handle.
Old Nov 19, 2012, 10:58 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
One more question: Do you cover the sensor somehow to protect it from the extra air pressure generated by propellers, or you just hide it under Drone's hull?
Old Nov 19, 2012, 10:59 AM
Joined Jun 2012
Well, you'll understand the schematic on the listing better than me, and it is listed as "Enhanced". What do you think is likely to happen if I set the Output to 3.3v?
I'll make the change and measure what comes out of it.
There's an 8Mhz adjustable version here too: http://www.ebay.co.uk/itm/221031162267
I see on the Spec for the one I have it has 150mA Max output (not 40mA). Is one resistor enough? It's working at the moment, but the word 'eventually' caught my attention. I can't afford any more costly mistakes.
So... with the LLS and a D1, as the voltage is less than 3.3v max clamp value (5/2=2.5v) there is no current issue?
Is that similar on the D2? 1.8v clamp? Voltage lower than 1.8v (5/3=1.66v through LLS) so no excessive current flowing through it?
Old Nov 19, 2012, 11:26 AM
miru is offline
Vista, CA
Joined Feb 2008
The schematic on the ebay listing does not show the voltage regultor ... there is no telling what they do.
You want a 16 Mhz clock on the processor to run the mod.
The 150mA is for the power regulator, the processor can only do 40mA on an output pin.
Sorry, I am exhausted and am giving up on you. You need to brush up your understanding of electronic circuits and study the schematics of the LLC to answer the questions yourself.
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
