Old Nov 16, 2012, 01:31 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Originally Posted by Brandigan View Post
So reflashing 1.7.11 might fix it? I don't want to go higher. I'll go down first, then come back up again. I think I need to do 1.3.1 to make sure everything gets 'wiped' properly.
Just keep in mind the mod needs at least 1.4 better 1.7 or 1.10 .
miru is offline Find More Posts by miru
Old Nov 16, 2012, 02:56 PM
pawelsky is online now
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
SETUP mode on Android device
After doing some experiments with the LCD display as a SETUP device I've realized it is not worth it and decided to use my Android phone.
I've bought a 9$ BT to serial adapter and after a bit of configuration and downloading a free BlueTerm application - voila - we have SETUP mode on Android phone (see attached pictures).
That could be useful if you experience some problems with the mod in the field and you don't have a PC with a serial connection nearby.
Next step - iOS device, but this will most likely require a Jailbreak
pawelsky is online now Find More Posts by pawelsky
Old Nov 16, 2012, 04:49 PM
Fioulmaster is offline
Find More Posts by Fioulmaster
France, PCh, Poitiers
Joined Oct 2011
Originally Posted by pawelsky View Post
After doing some experiments with the LCD display as a SETUP device I've released it is not worth it and decided to use my Android phone.
Cool!!!
I've got a jailbreaked iphone (3GS). So I wait your next step.
Fioulmaster is offline Find More Posts by Fioulmaster
Old Nov 17, 2012, 04:24 AM
pawelsky's Avatar
Poland
Joined Jan 2012
Originally Posted by Fioulmaster View Post
Cool!!!
May not be that easy, can't find any app that would give me access to raw data from SPP
Old Nov 17, 2012, 11:19 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Yes, no problem. Didn't have much time to spend, but going down to 1.1.3 (was typo before when I said 1.3.3, I skipped that one) fixed the file error right away.
Had some fun upgrading from there, as I'd forgotten put used /data, not /data/video for ftp way back then, so was wondering where on earth ardrone_update.plf had got to.
I then did 1.4.6, 1.5.1, 1.7.11, as they're fairly big and contained the most actual changes, not fiddly little bug fixes.
Some interesting side effects of all this:
1) renaming of the drone to ardone_v1.7.11 is unexplained, but might have been a default 'fix' when the corruption happened.
2) at2so.arm was still in /data/video when I'd finished (I'd put it there before the first downgrade when the files were corrupted, but it was still working happily with a Resistor Mod.
3) It now connects to the iPhone much faster. It used to spin for quite a while in Settings>Wifi before, now the tick is there in seconds.
4) It's reset the flight time length, so now I have a 'new' drone with only 2 minutes flight on it.
5) Video is now smooth and non-glitchy on the iPhone. Previously some apps were a bit fussy and would occasionally break up when the drone was moved quickly, but now they're all fast and smooth no matter how fast I wave the Drone about. (Drone Control/Drone Ace/FlightRecord/FreeFlight)
So, it's basically had a bit of a spring clean and is better for it.
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Nov 17, 2012, 11:49 AM
miru is offline
Vista, CA
Joined Feb 2008
Originally Posted by dante1 View Post
I am using a Fastrax UP501 GPS module
which uses the MT3329 chipset. When connecting to the FTDI, should I see the RX and TX led flash? I changed the voltage on the breakout to 3.3volts and it is detected in Windows7.
I just tried a UP501, the data jumps like on all the others, but it has a really fast TTFF (< 30 sec) even without the backup battery.
Old Nov 17, 2012, 01:22 PM
Joined Jun 2012
Miru, before I commit to making another Level Shifter Mod, could you please provide the voltages I should be getting on Tx and Rx Drone side > GND with a Nano, Pro Mini, with Resistors and a Level Shifter (v1 and v2) because if I'm doing something wrong, I'd rather not have to buy another mainboard for my v2 after I've plugged it in again?
I assume you must have made/tested all 6 variations, so should have access to that data and it would be useful for others as well as me to avoid frying boards.
Setup can't tell me enough, I've just tested my replacement Nano with only the Receiver connected and Hyperterminal is all go as usual, but as that's all internal, I need to use a multimeter.
Old Nov 17, 2012, 01:59 PM
KiwiTarantula is offline
Find More Posts by KiwiTarantula
The Netherlands, UT, Utrecht
Joined Nov 2012
Has anyone tried using a Spektrum DX5e remote? In theory, will it work with a 6 channel RX?
Did you ever find out the answer to this? I'm curious as well...
KiwiTarantula is offline Find More Posts by KiwiTarantula
Old Nov 17, 2012, 06:25 PM
miru is offline
Vista, CA
Joined Feb 2008
Here are some numbers I measured today with a ProMini, the Sparkfun level shifter wired for D2 and the whole thing connected to a D2.
VCC on ProMini 4.94V used to power the LLC
Arduino TX 4.94V -> LLC -> Drone RX 1.677V
Drone TX 1.776V -> LLC -> Arduino 4.90V
I don't have the other setups any more, since I am experimenting with a different FET (BSL806N) and a 1.8V(D2) or 3.3V(D1) LDO to do the level shift.
If I recall your numbers right, you had a fairly low VCC from your Nano. Investigate that by powering it from VIN with 12V and measuring VCC. Something must be pulling a lot of current.
Old Nov 18, 2012, 04:15 AM
Joined Jun 2012
Thanks, I appreciate you taking the time. Any chance you could perhaps temporarily break the LV>RX0 Chan2 link on the Pro Mini and check what it would give for a D1 (powered by USB, obviously - don't want to fry your D2 too )?
Could you also confirm that the Chan1 LV>RX0 link is in place for a D1?
I'm not plugging anything into my D2 until I can get a Shifter Mod working on the D1, as that just doesn't start up when it's wrong rather than frying the mainboard again. The D2 board was 100 in the UK, not $100. If the D1 does die, its board is cheaper.
Yes I did have lower VCC with my previous Nano (4.63v) and now have similar (4.66v) with the new one. Two different Pro Minis always give 5.01v.
I did wonder if it was the receiver I'm using with that particular setup, so if you think that's worth investigating, I'll swap it with another and see if it changes. Might explain why that one had (unresolved) intermittent startup problems.
I've ordered some long, thin nosed tweezers to use as a heatshunt on the two GNDs on the new, new Level Shifter before I solder anything to it, as my existing heatshunt has too much of a spade end to be useful - in case I'm frying them.
Old Nov 18, 2012, 09:19 AM
miru is offline
Vista, CA
Joined Feb 2008
If you power a Nano mod by USB, the voltage regulator on the Nano is bypassed and power is derived from USB power through a diode. This might be the cause of your low voltage reading on a Nano if you don't power the mod with 12V. On a ProMini this diode does not exist. If you power a ProMini mod from USB (through the FTDI) you get whatever the FTDI board is sending on the VCC pin, which, most likely, is USB power.
The LLC is wired such, that it uses the two series resistors (channel 1) to make the low voltage reference LV for the FETs. Since both resistor values are the same, LV is 1/2 HV (5V/2=2.5V), the configuration you want to use for a Drone 1. If you install the link between LV<->RXO(channel 2) the channel 2 bottom resistor of the channel 2 series circuit is parall to the bottom resistor of channel 1, which makes LV 1/3 HV (5V/3=1.67V), the configuration for a drone 2.
No (see above)
Old Nov 18, 2012, 11:42 AM
Joined Jun 2012
OK, will power both from Drone and measure after they've regulated the 12v then, rather than worry about what they get from USB.
No (see above)
Sorry, didn't make myself clear and probably used wrong terminology. I meant: is this wiring correct for the Drone 1?
Old Nov 18, 2012, 12:08 PM
happul3 is offline
Find More Posts by happul3
Joined Aug 2012
Miru, could you share some details about interface between arduino code and companion program? I am interested specifically in controlling drone motor LEDs. My barometric stabilization addition to your mod seem to be working ok, but I would like to add visual indication of stabilization kicking in, at least for testing and choosing appropriate parameters for it (only simple proportional is implemented atm). Motor LEDs would be ideal as indicators, but I can't deduce how to control them from your code (RX=L parameteres?). Thanks a bunch!
happul3 is offline Find More Posts by happul3
Old Nov 18, 2012, 12:24 PM
miru is offline
Vista, CA
Joined Feb 2008
Sorry, didn't make myself clear. I meant: is this wiring correct for the Drone 1?
Yes
Old Nov 18, 2012, 12:48 PM
miru is offline
Vista, CA
Joined Feb 2008
RX=L,<type>,<frequency>,<duration> will be sent on to the drone as ATLED=<seq>,<type>,<frequency>,<duration> by the companion program. The <seq> is generated by the companion program, the rest is passed on as is. On the drone the motor leds can not be addressed individually, you have to provide the 3 parameters of the LED command. <type> is one of these:
Code:
 *  0 BLINK_GREEN_RED
 *  1 BLINK_GREEN
 *  2 BLINK_RED
 *  3 BLINK_ORANGE
 *  4 SNAKE_GREEN_RED
 *  5 FIRE
 *  6 STANDARD
 *  7 RED
 *  8 GREEN
 *  9 RED_SNAKE
 * 10 BLANK
 * 11 RIGHT_MISSILE
 * 12 LEFT_MISSILE
 * 13 DOUBLE_MISSILE
 * 14 FRONT_LEFT_GREEN_OTHERS_RED
 * 15 FRONT_RIGHT_GREEN_OTHERS_RED
 * 16 REAR_RIGHT_GREEN_OTHERS_RED
 * 17 REAR_LEFT_GREEN_OTHERS_RED
 * 18 LEFT_GREEN_RIGHT_RED
 * 19 LEFT_RED_RIGHT_GREEN
 * 20 BLINK_STANDARD
Check the SDK for additions/deletions. <frequency> is the frequency of the pattern in HZ, you have to send an integer (e.g. 5Hz would be 1084227584) and <duration> is the duration of the pattern in seconds, 0 meaning forever or until something else comes up.
Don't shoot me, I did not design this...
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
