Old Nov 14, 2012, 12:32 PM
SJW2511 is offline
Find More Posts by SJW2511
Joined Nov 2012
I have an update regarding my original altitude problem. IT WORKS!
I have just been out in the night sky, and travelled to 461 feet :lol: (brave)
Flew spot on and the original stopping at 100m is cured, many thanks to all that helped, heres the finished mod shrink wrapped and in the drone
SJW2511 is offline Find More Posts by SJW2511
Old Nov 15, 2012, 02:57 AM
pawelsky is offline
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Well done! Make sure you leave easy access to the USB port to be able to update the mod in future.
pawelsky is offline Find More Posts by pawelsky
Old Nov 15, 2012, 03:44 PM
tonyh0905 is offline
Find More Posts by tonyh0905
tonyh0905's Avatar
United Kingdom, Wales, Cardiff
Joined Mar 2012
Nice job!...did you range check your setup? If so what sort result did you get?...Only asking because there was such a huge difference in my results on the EU and US power setting on the Dx6i.
tonyh0905 is offline Find More Posts by tonyh0905
Old Nov 15, 2012, 03:45 PM
SJW2511 is offline
Joined Nov 2012
i set it straight to US based on your advice so no direct comparisons, not had chance to properly range test yet as its dark every day when i get home lol, il have proper results at the weekend
Old Nov 15, 2012, 03:58 PM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
After being unable to get a Pro Mini Mod to work with a Level Shifter, I've built a completely new one with a both a New Shifter and a new Pro Mini and I still can't get the Mod to work on a v1 Drone using the Level Shifter. The old Mod works fine with resistors, but I gave up on it and started again with completely new components.
I actually have two sets of Drone wires connected to the Same Mod now (to avoid having to keep removing and resoldering between the two types) and when connected to the Drone via resistors it fires up every time. When using the Level Shifter it won't work, although I do sometimes get the Arduino flashing at 12hz but with RED motor LEDs, so it won't fly.
Tested the Level Shifter every which way with help from happul3 over PM and it's doing exactly what it should do.
Checked the wiring again and again and there is nothing else I can see to check.
As the connection diagram shows 3.3v for the v1 and 1.8v for the v2 when using the Level Shifter and I only get 2.5v and 1.6v am I actually suffering from an undervoltage problem?
What voltages should I be getting at Tx and Rx at the Drone end when connected via Resistors and via the Level Shifter using both a Nano and a Mini Pro?
Can anyone who has got either/both test and let me know what they get between each of them and GND?
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Nov 15, 2012, 08:16 PM
Gordon2 is offline
Find More Posts by Gordon2
Joined Nov 2012
Proximity of Arduino (minipro) and RC Receiver (Spektrum AR8000)
I am getting ready to commit this mod to my Drone 2.. and one option I am considering has the Arduino and Level Shifter mounted right on top of the RC receiver in front of the battery tray.
Has anyone an idea if there will be an interference with this arrangement? Has anyone any experience of intermittent or unexplained problems that might be related to have the processor board and receiver too close?
Advantage of this arrangement is that wires are for the most part as short as possible and the electronics are as far as possible from the (noisy) motors. Disadvantage would be any unwanted stray interference between the receiver and Arduino.
thanks in advance
Gordon2 is offline Find More Posts by Gordon2
Old Nov 15, 2012, 10:04 PM
happul3 is offline
Find More Posts by happul3
Joined Aug 2012
thanks in advance
I have arduino and receiver as close as they can possibly can be and it works just fine. I don't think arduino@16MHz would be capable of creating interference for 2.4GHz band. By the way, drone's motors are brushless, hence no arcing there and no interference either.
happul3 is offline Find More Posts by happul3
Old Nov 16, 2012, 07:32 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
I have receiver (Turnigy) basically glued to Nano (see here: http://www.rcgroups.com/forums/showp...postcount=2732) and observe no problems at all.
Old Nov 16, 2012, 08:12 AM
Gordon2 is offline
Joined Nov 2012
OK! Two reports that it works is good for me.. so thats my plan.
Thanks!
Old Nov 16, 2012, 08:46 AM
Joined Jun 2012
Originally Posted by obelix662000 View Post
I built 2 mods with Pro Mini and Level shifter exactly as described in the wiring diagram. Both are fine with Ardrone v2 , no special care.
OK, thanks. That's confusing. Any chance you could PM me a photo with your wiring, as this is beyond baffling?
It's clear the Nano and Pro Mini are different because I only get 4.63v from a Nano, but 5.01v from the Pro Mini at VCC>GND (powered through USB), but is that enough to explain the problems I'm having?
The new Nano has turned up, so I'll wire that to the Drone's 12v/GND and measure what's at VCC and what's going back through Tx and Rx with Resistors or another new Level Shifter.
Old Nov 16, 2012, 12:30 PM
Joined Jun 2012
I guess all this Mod testing has finally taken it's toll on my poor v1 Drone.
Still flies, still works with a Mod (with resistors), but when I telnet in with no Mod plugged in - just standard - I now see this, which is what I saw last time I was testing with a Level Shifter Mod before it dropped the connection.
BusyBox v1.14.0 (2011-12-13 10:35:27 CET) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# ls
x▐╚ΘΘ┴P∙╧╝Θ░╚]?!u≈│n{+▀⌡$JU≥╝╙▼╙Θ}:■#■↓.═φ6╢5▓ΓM
bin
data
dev
etc
factory
firmware
home
lib
licenses
mnt
oΣ╚■ε
proc
root
sbin
sys
tmp
update
usr
var
╤φ8╨
░√G∙╢ְ*_,7d╛o┴■ΦbΓ█╦∩]┴╖W
α▼■■α■≥ⁿ╚■εΦε^ΦΩ■■■Ω┐α
α
≡■■■■ⁿⁿⁿ■∙?■■■▲╢⌐m A]X
■≡└ⁿ■■ⁿ■└ⁿ■stty
Should I be worried and anything I can do about it, like reflashing the firmware?
One other thing that has changed: instead of seeing ardrone_020801 as the wireless access point, I now see: ardrone_v1.7.11 and I didn't rename it.
Old Nov 16, 2012, 12:51 PM
tonyh0905's Avatar
Joined Mar 2012
I installed an app called NAVAnDrone which renamed my drone to exactly the same...ardrone_v1.7.11.
Have you installed any new drone apps?
Old Nov 16, 2012, 12:54 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
# ls
bin
data
dev
etc
factory
firmware
home
lib
licenses
mnt
oΣ╚■ε
proc
root
sbin
sys
tmp
update
usr
var
╤φ8╨
α
■≡└ⁿ■■ⁿ■└ⁿ■stty
Looks like you have a corrupted file system. This is pretty bad, try reloading the whole drone (with ardrone_update....plf). If it does not fix it you might have to send it in...
miru is offline Find More Posts by miru
Old Nov 16, 2012, 12:55 PM
Joined Jun 2012
No, just been trying to get this Mod to work with a Level Shifter. Last thing before that was changing the Baud rate in the sketch as per Miru's recent instructions - no obvious difference; worked fine - but don't know if that's a side effect .i.e it was better as Miru had it originally.
Old Nov 16, 2012, 01:01 PM
Joined Jun 2012
So reflashing 1.7.11 might fix it? I don't want to go higher. I'll go down first, then come back up again. I think I need to do 1.3.1 to make sure everything gets 'wiped' properly.
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
