Old Nov 07, 2012, 09:07 AM
Joined Nov 2012
Ordered those two things
Anyone know where I can source a plug suitable to wire to and use for the serial port on the bottom of the drone? or at least the type so i can do a generic search?
SJW2511 is offline Find More Posts by SJW2511
Old Nov 07, 2012, 09:25 AM
MiruMod supporter
pawelsky's Avatar
Polska
Joined Jan 2012
Two things?
You have all the part numbers on the HW page
pawelsky is offline Find More Posts by pawelsky
Old Nov 07, 2012, 09:27 AM
Joined Nov 2012
Indeed, cheers
Old Nov 07, 2012, 09:32 AM
MiruMod supporter
pawelsky's Avatar
Polska
Joined Jan 2012
Indeed, cheers
What is the second thing you ordered? Hope not FTDI which is not needed when you use nano.
Old Nov 07, 2012, 09:40 AM
Joined Nov 2012
Nah the logic converter board
Still would be open to suggestions for the serial plug for Drone 2 as the one in the H/W page is based in USA and is £12 postage, so any supplier in uk
Old Nov 07, 2012, 09:42 AM
MiruMod supporter
pawelsky's Avatar
Polska
Joined Jan 2012
I see.
Check the the Manufacturer Part No on Mouser page, google for a supplier in UK
Old Nov 07, 2012, 10:04 AM
Joined Nov 2012
For reference iv ordered this from RS in UK
http://uk.rs-online.com/web/p/pcb-headers/7644711/
seems to match pin pitch etc, will soon find out i guess
Old Nov 07, 2012, 11:26 AM
MiruMod supporter
pawelsky's Avatar
Polska
Joined Jan 2012
Looks ok
Old Nov 07, 2012, 11:46 AM
Joined Nov 2012
Might actually do a proper step by step with pics for idiots like me to follow for doing this on drone 2 IF im successful with it all lol
Old Nov 07, 2012, 04:07 PM
United Kingdom, Wales, Barry
Joined Mar 2012
Wow
Wow, I turn my back for a day, and the post grows by 5 pages
My thoughts on what I've just read:
Of the 4 config choices I have now, I only use 2.....just sayin!
MacGyver puts together a nice build of the MiruMod, but they're bloody expensive, and as for customer support, you can forget it. My introduction to this forum was when my new MacGyver mod kept auto landing for no apparent reason, and Mike stopped answering my emails. We bounced the problem around here for a few days until Miru came up with a solution, which he implemented in rev.0.14+.
SJW, Building your own mod is the best way to go if you can get over the intimidation factor. Familiarize yourself with the parts and the wiring diagrams on Pawelsky's site, and have a go. I can post photo's of my mod during construction if you think they will help. I like the high altitude flights, as you know, and I get a kick out of knowing it's only possible because of a piece of hardware I built with my own two hands.
If you haven't ordered the Spektrum RX yet, I can highly recommend the Orange RX from Hobbyking. They're really cheap (around 8 quid), and very reliable.
http://www.ebay.co.uk/itm/OrangeRX-R...9072%26ps%3D54
Setting up the Dx6i is easy enough, but I strongly recommend changing the power setting from the EU setting to the US one. I was having some range problems which this seemed to cure (thanks P.)
Good luck
tonyh0905 is offline Find More Posts by tonyh0905
Old Nov 08, 2012, 07:38 AM
Joined Jun 2012
Going to guess: Standard and Wild.
Both the 'wrong' Hull type (weight =inertia/momentum, presumably) and whether you are Indoors or Outdoors (wind compensation on V2 Drone) affects performance, which is only why I'd asked for the option to toggle the flags fairly easily. Still fingers crossed it's somewhere on the Todo list.
But completely objectively: people other than me should test fly using an iDevice and see how differently it handles starting and stopping with various combinations of Indoor/Outdoor/No Hulls, with/without heavier batteries+Mod weight and a GoPro etc. and how affected by wind - or lack of it - given 'correct' and 'wrong' values for Hull Type and Indoor/Outdoor Control flags set in FreeFlight it actually is.
Brandigan is offline Find More Posts by Brandigan
Old Nov 08, 2012, 07:49 AM
MiruMod supporter
pawelsky's Avatar
Polska
Joined Jan 2012
Brandigan, you've made your point many times, please stop bugging everyone that thinks differently. Let miru decide and be patient.
Pretty please. Peace
Old Nov 08, 2012, 08:04 AM
Joined Jun 2012
I'm sorry, that was not my intention. As you'd quite sensibly asked for other opinions to avoid miru spending time on what might be a 'niche' option and as the feature isn't there yet, the only current way of seeing if it would have an effect would be to test using an iDevice, otherwise it's just guesswork.
But no more about it from me.
Old Nov 08, 2012, 10:07 AM
XR-4Drone.com
Joined May 2011
Telneting
When I telnet into my AR DRONE, what do I need to look for to see if the companion program is loading?
I have tried everything under the sun to pin point why my arduino nano starts blinking and then goes solid. I get no response from my DX6i remote. But in SETUP mode, everything works fine.
Is it possible that the serial connector is fried?
Dante1
dante1 is offline Find More Posts by dante1
Old Nov 08, 2012, 11:07 AM
Vista, CA
Joined Feb 2008
Dante1
When you telnet into the drone in this state (LED solid), you can check a couple of things.
Do a 'ls -l /tmp' . You should see one of the files 'at2so.arm.gz' or 'at2so.arm'. If you see the first, the upload is still in progress, a very unlikely event since it is fairly fast and hard to catch. But if you see it the Arduino sent everything it will send and the receiving program (dd) is still expecting data or the 'unzip' did not work because of a corrupted file. If you see 'at2so.arm' the upload and the 'unzip' worked. If that is the case, do a 'ps' command and find out if 'at2so' is running (would be in process list). If so, 'at2so' is waiting for data from the Arduino and the Arduino did not see the start character from 'at2so'. If you get this far, most likely there is something wrong with the data path from the drone to the Arduino.
miru is offline Find More Posts by miru
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 113 May 13, 2011 02:26 PM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
