Old Sep 29, 2012, 11:05 AM
pawelsky is offline
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Originally Posted by Viaggiatore View Post
This thing is going to drive me crazy! Actually now I'm not able anymore to see the GPS in test mode (but it worked! MiruMod was able to reconfigure it..).
So I soldered again A0 and A1, nothing!
I'm feeding the GPS with external 5v. I'm using the very same cable that I use to test the GPS with my PC (working fine here).
Now, whatever I try, in test mode no GPS at all is recognized... if I swap TX w RX (but in wrong position) MiruMod sees something (I see gps 57600) but nothing else.
I've the fear that my Nano has a broken AO A1... is there a way I can test it? If of course this could be the culprit.
G.
Do you have Arduino's and GPS's GNDs connected? Maybe show us a photo of your GPS wiring.
pawelsky is offline Find More Posts by pawelsky
Old Sep 29, 2012, 11:33 AM
Viaggiatore is offline
Find More Posts by Viaggiatore
Italy, Emilia-Romagna, Predappio
Joined Aug 2012
NO! Because I'm taking the 5v from an external source GPS GND is not connected to Arduino. Arduino and GPS are connected just with TX-RX.
So I just connect GND (any Arduino GND) to GPS GND as well? Do I need it?
Viaggiatore is offline Find More Posts by Viaggiatore
Old Sep 29, 2012, 11:57 AM
Fioulmaster is offline
Find More Posts by Fioulmaster
France, PCh, Poitiers
Joined Oct 2011
GPS compatibility?
Hi friends! Good job for gps.
The addition of GPS tempt me well and I saw this model. Is it compatible with the Mod? I suppose Yes. Should put a resistance on the GPS rx line
On the RTH desactivated in rev0.19, what are the problems encountered with the drone1 (this is what I have).
Thank you in advance for your answers.
Fioulmaster is offline Find More Posts by Fioulmaster
Old Sep 29, 2012, 04:33 PM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Yes
Old Sep 29, 2012, 04:46 PM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Seems to have all that is needed, so most likely yes.
If you power it with 5V no, if you power it with 3.3V I would say yes.
You just don't have RTH with 0.19. But you do have logging (which can then be converted and viewed in GoogleEarth)
Old Sep 29, 2012, 05:41 PM
tonyh0905 is online now
Find More Posts by tonyh0905
tonyh0905's Avatar
United Kingdom, Wales, Cardiff
Joined Mar 2012
I also fly a drone 1.0 with rev.0.19 and I have no problems.
The RTH in rev.0.18 worked, but was too unreliable, so Miru left it out of 0.19 until the bugs were sorted out
tonyh0905 is online now Find More Posts by tonyh0905
Old Sep 29, 2012, 05:56 PM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Can I swap outputs D2-D7 around to the channel order of my specific Rx for slightly neater wiring?
I'd like them to be:
* D2 PD.2 IN RX AUX1 channel
* D3 PD.3 IN RX GEAR channel
* D4 PD.4 IN RX RUDD channel
* D6 PD.5 IN RX THRO channel < moved from 7
* D7 PD.6 IN RX ELEV channel < moved along one
* D5 PD.7 IN RX AILE channel < moved along one
But all I can find is this:
#define S_AILE 0
#define S_ELEV 1
#define S_THRO 2
#define S_RUDD 3
#define S_AUX1 4
#define S_GEAR 5
#define S_NCHN 6
Can I swap these about or is it set in at2so.c? Where can I get the source for this to have a look around if I have to recompile?
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Sep 29, 2012, 06:03 PM
Joined Oct 2011
Ok. Thanks a lot for infos.
Your site (mirumod.hopto.org)is very good. Good job
Thanks too Tonyh0905.
Old Sep 29, 2012, 09:10 PM
perp1exed is offline
Find More Posts by perp1exed
Joined Sep 2012
Originally Posted by tonyh0905 View Post
I'm using a drone 1.0 so I didn't need to use the level converter.
I can't give you blow by blow instructions, but I've included a couple of photos of my mod whilst under construction.
As far as having to use special cabling goes, I hope not!! I pulled apart an old computer case and got all my cables from that
The diagrams are pretty clear, so get stuck in, and have a go! If you come across any specific problems, there is usually someone on this forum that can help out.
Good luck
Thanks that helps!
perp1exed is offline Find More Posts by perp1exed
Old Sep 29, 2012, 09:16 PM
Joined Sep 2012
Let's start with RX.
RXs have 3 pin connectors for each channel. One pin is SIGNAL, one (middle) pin is +, one pin is - (or GND). They should be labeled on the RX or in the instruction manual.
You need to connect SIGNAL pins to Arduino's D7 to D2 pins accordingly (you may need to rewire it later depending on the order of channels in your TX, so don't make cables too short)
You need to connect one (doesn't matter which one, they are all connected) of the RX+ pins to Arduino's 5V pin
You need to connect one (doesn't matter which one, they are all connected) of the RX- pins to Arduinos's GND pin (there are two such pins, pick the one you like)
That's it RX connected!
Thank you very much!
And thanks to all of you - I look forward to sharing my Drone adventures with you
P.S. for some reason my drone disconnected power whilst in mid flight (it was a little windy but not particularly bad) at around 15-20 feet. Dropped like a log and hit concrete. Central Cross broken :S
I'm wondering if the motors cut power because it tilted too far?! Although I could not see as much - is there any way to adjust the tilt cut off settings?
Also, is this GPS device compatible for 2.0 mod?
http://www.robotshop.com/productinfo...408&lang=en-US
thanks again - luckily I was able to get it exchanged for a new one :P
Old Sep 29, 2012, 09:26 PM
Joined Sep 2012
Good luck
Is that a 1.0 mod?
What is that board with all the pins sticking out?
I thought you only needed either an 8-pin for 1.0 mod or 10-pin for 2.0??
thanks.
Old Sep 29, 2012, 09:38 PM
Joined Sep 2012
So in the diagram, the "Receiver" is what is already inside the drone?
thanks!
Old Sep 30, 2012, 04:03 AM
Joined Aug 2012
Yes
Working great now! Thank you very much paw!
G.
Old Sep 30, 2012, 04:28 AM
Joined Aug 2012
Where do you place the GPS unit?
I was thinking to place it like in the picture. Thinking to drill the hull to house the GPS. Seems to me a nice place because it won't give me problems in removing the hull.
What do you think?
G.
Old Sep 30, 2012, 06:16 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
#define S_AILE 0
#define S_ELEV 1
#define S_THRO 2
#define S_RUDD 3
#define S_AUX1 4
#define S_GEAR 5
#define S_NCHN 6
NO! That is not a right place to do it.
If you cannot change the order of channels in your TX then look for
gl.rxs.chn[S_THRO].msk = _BV(7);
gl.rxs.chn[S_AILE].msk = _BV(6);
gl.rxs.chn[S_ELEV].msk = _BV(5);
gl.rxs.chn[S_RUDD].msk = _BV(4);
gl.rxs.chn[S_GEAR].msk = _BV(3);
gl.rxs.chn[S_AUX1].msk = _BV(2);
in lines 1803-1080 (v019) and change the pin assignment there
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
