Old Sep 18, 2012, 07:46 AM
pawelsky is offline
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Originally Posted by Andresc4 View Post
after a crash, I'm getting Ultrasonic error on screen
i check both boards, and i found a missing element, and i need to know how to replace it... i don't know if its a resistor or a cap, seems to be a resistor, but i need to know the value, can anybody help me with this ?
( between where it say Q7 and Q4 there are 5 smd resistor/caps,,, from the top to the bottom the 2nd one ) . Without this the sonar its not working and the mod is not working neither
That probably won't help you much but here is pretty detailed picture of the board (you may need to create an account and log in on ardrone-flyers to see it)
http://www.ardrone-flyers.com/forum/...1057&mode=view
It looks like a capacitor same as the one below (4th from the top).
pawelsky is offline Find More Posts by pawelsky
Old Sep 18, 2012, 11:16 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Originally Posted by tonyh0905 View Post
It would be nice though, if you find your flight data is lower than ground level as reported by Google Earth to be able to make an adjustment.
Added to log converter (it is called "Altitude correction").
http://mirumod.tk/tools/log_converter.php
Please note I may have to remove it in future if that eats too much of my webserver's monthly transfer limits.
Old Sep 18, 2012, 11:29 AM
tonyh0905 is offline
Find More Posts by tonyh0905
tonyh0905's Avatar
United Kingdom, Wales, Cardiff
Joined Mar 2012
http://mirumod.hopto.org/tools/log_converter.php
Fantastic job!
Thanks again for all your efforts.
I will try not to be too greedy, by converting every flight I make (no promises tho )
tonyh0905 is offline Find More Posts by tonyh0905
Old Sep 18, 2012, 11:34 AM
RHTizzy is offline
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
Ooh that would be a pity assuming you're not talking about just the altitude correction function. Otherwise, is there any trick to the conversion, ie field mapping and such that could be used in an external standalone tool or excel conversion?
I personally prefer the RTH function over the logging feature and have instead been adapting Miru's 018 sketch to incorporate the auto gps config. It's been years ('80's assembly zilog z80) since I actually did any real programming other than scripting, but it's fun to see what's evolved since then and trying to wrap my head around Miru's brilliant brainchild
RHTizzy is offline Find More Posts by RHTizzy
Old Sep 18, 2012, 11:38 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
No, it is just for the altitude correction which (since this is a bit of a trial and error) could generate unnecessary traffic.
I'm thinking about a windows commandline tool that will do the conversion locally on a PC.
Old Sep 18, 2012, 12:36 PM
rjrobbin is offline
Find More Posts by rjrobbin
United States, OH, Powell
Joined Dec 2006
flip
I have the mode set to 'w'...two flashes on the led. that should allow anamimation.
not sure how to get the thing to flip...it works on the iPhone.
thanks
rjrobbin is offline Find More Posts by rjrobbin
Old Sep 18, 2012, 12:57 PM
Viaggiatore is offline
Find More Posts by Viaggiatore
Italy, Emilia-Romagna, Predappio
Joined Aug 2012
FW 2.2.6 & 0.18 working good
Just to say I joined the club, tested FW 2.2.6 & 0.18 and everything seems fine.
Thanks Dante! ;-)
G.
Viaggiatore is offline Find More Posts by Viaggiatore
Old Sep 18, 2012, 01:34 PM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
thanks
See Q&A#3 at http://mirumod.tk/faq/faq.php#q3
Try practising in SETUP first (you should see ANIx diplayed when animation is triggered succesfully)
Old Sep 18, 2012, 02:34 PM
rjrobbin is offline
Joined Dec 2006
See Q&A#3 at http://mirumod.hopto.org/faq/faq.php
thanks...I kept trying fm1 to fm2 back to fm1....no animation.
Old Sep 18, 2012, 03:29 PM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Actually you should do the opposite: FM2-FM1-FM2 then quickly followed by AIL/ELE stick movement (diferent direction selects different animation). You can also hold the AIL/ELE stick while flipping flight modes (this will do an in-flight animation)
Old Sep 18, 2012, 04:17 PM
dante1 is offline
Find More Posts by dante1
XR-4Drone.com
dante1's Avatar
Canada, QC, Montreal
Joined May 2011
Thanks Dante! ;-)
G.
No Problem glad everything worked out for you.
Next step GPS
dante1 is offline Find More Posts by dante1
Old Sep 18, 2012, 05:09 PM
vectorcharlie is offline
Find More Posts by vectorcharlie
Joined Sep 2012
GPS device orientation
Hi guys!! Yesterday flew with GPS. Just awesome! Very happy indeed.
One question: Does the orientation of the actual GPS device affects? Mine is facing to the left, but have seen that most of them are facing (The ceramic square) to the sky... Is there a difference?
vectorcharlie is offline Find More Posts by vectorcharlie
Old Sep 19, 2012, 02:03 AM
Joined Aug 2012
Compass aided flight mode?
The only thing I'm really missing is the absolute control... would it be possible to implement a compass corrected flight mode? i.e. the one which is implemented in the very good app ARDrone flight by Meavy Dev:
"Compass corrected take-off - forward set at take-off adjusted by device compass
In this mode, moving forward flies the drone in the direction you are facing, and it uses your device compass to know if you turn round after taking off. This is like third person mode, so forward/back/left/right are all relative to the direction you are currently facing, with forward flying away from you."
I used it a lot, take off with camera facing away from me, and then it is like absolute control.
Nonsense?
Thanks!
G.
Old Sep 19, 2012, 02:16 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
For best GPS signal reception better to have it flat.
Old Sep 19, 2012, 02:39 AM
Joined Aug 2012
Uhm, I guess you still need an android or whatever device with a compass. So no way to have a sort of absolute piloting?
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
