Vista, CA
Joined Feb 2008
Laurent and Genie360, what do you think about this....
When on ground (GEAR down) RUDD left -> FTRIM/LED/COMWDG (would be like arming the ESC for a tail motor) RUDD right -> EMERGENCY reset When airborne these actions are disabled. If you need to pull the plug in the air you would have to switch GEAR to land and hit RUDD right to turn the motors off. This way a 5 channel receiver could do it. I would use the RUDD channel because the stick is spring loaded. miru |
United States, FL, Daytona Beach
Joined Apr 2011
_ Oh and I did a few more tests with the nano... so far everything works great. It does seem to have that infamous pitch roll problem over grass though. |
Vista, CA
Joined Feb 2008
I have seen this behaviour once, unfortunately on an 'unlogged' flight. I think the altitude sensor is going bananas and draws a lot of processing resources to these events. This in turn will make the COMWATCHDOG fire, which explains why one can not pitch or roll the drone anymore. If you land and use FTRIM/LED/COMWDG it flies fine afterwards... There is nothing in this mod that will improve this behaviour. I saw in earlier network dumps that FreeFlight changed CONFIG=..,"control_level:,"4" or "5" depending if you going outdoor or not (could have been flight with/without shell as well). The new FreeFlight sets this to "0"... One would have to experiment to figure out if there are control levels that don't listen too much to the altitude sensor. miru |
Joined Apr 2011
yeah I did the land, FTRIM/LED/COMWDG procedure and it seemed to sort it out. I took off again and flew around without a problem for a while then it got all confused again. It was funny though because the second time it happened I had it pitched all the way forward maxing out the speed.... so when it decided to jump into hover mode it pitched back so hard it did a complete back-flip! It was perfect... landed the right way up like it was all part of the plan. My buddy thought it was the best thing ever haha. couldn't do it again if I tried
Vista, CA
Joined Feb 2008
I will finish up the software tonight (rev 0.03) and publish tomorrow if the test flight turns out ok. miru |
Vista, CA
Joined Feb 2008
miru |
Joined Nov 2010
- I2C barometer MS5607B to provide the altitude (an extension to the ultrasonic on AR.Drone) - I2C magnetic compass HMC5883L to provide the direction for navigation - TTL serial GPS to provide positions There are open source for those sensors with Arduino on the Web. The goal is to let AR.Drone Auto-Return in case of out of control by RC/WiFi-Phone, and fix the “Flyaway”. My solution is to have two levels of PID control: - Inner loop of PID by existing AR.Drone’s program.elf - Outer loop of PID by an on-drone app developed The problem I’m facing: AR.Drone may not handle AT commands well when out of ultrasonic range (just as you said, AR.Drone is mad in this case -- Does not know where it is and how high). So it needs to inject PWM commands into /dev/ttyPA1 to control motors directly. What is the PWM protocol used by AR.Drone? I have dumped some data from /dev/ttyPA1, but still no clue. |
Joined Nov 2010
https://projects.ardrone.org/attachm...oper_Guide.pdf |
France - Brest
Joined Oct 2007
Hello,
And, as we say Around me, "cerise sur le gâteau" (cherry on the cake), could you add an option, to use or not the second switch AUX1 to enable or disable auto-hoovering... I'm a bit stubborn, I know ![]() As you say, it's a bit like idle-up for Heli sounds smart to me, to have this feeling to put on the TURBO with my AR.Drone... ![]() For your info, on my AR.Drone with MHeeli Mod (yellowJacket), I have no emergency switch, I know, it's not so good... So, your implementation with the Gear and rudder stick is quite nice. By the way, it's quite fun to sleep while you all brainstorm on the subject... It's my turn now, the sun is on at home... ![]() Bye. Laurent D |
Some pictures of the wiring would be a massive help for us noobs
Vista, CA
Joined Feb 2008
Genie360, what kind of switch is on your radio? miru |
Joined Feb 2011
![]() Brilliant work miru, keep it up! Question myself how long it will take until you get an job offer from parrot!
| Thread Tools | |
| Mini-HowTo RC Controlled AR.Drone w/o WiFi! | nosaari | Multirotor Talk | 113 | May 13, 2011 02:26 PM |
| For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 4 | Apr 16, 2011 09:42 PM |
| Discussion Wifi Boosted AR.Drone | Fallengod | Multirotor Talk | 7 | Feb 12, 2011 10:52 AM |
| Discussion And yet another AR drone Arial Video project | taudronis | Multirotor Talk | 17 | Dec 07, 2010 11:04 AM |
| Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad | Hoverup | Aircraft - Electric - Helis (FS/W) | 0 | Oct 12, 2010 03:54 PM |
