Old Sep 03, 2012, 08:39 AM
pawelsky is online now
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Originally Posted by dante1 View Post
Hey Vectorcharlie,
I don't see the diode on the VIN. Did you forget to put it or is it along the wire?
Just an observation.
Dante1
Note, that diode is only necessary if you want to connect the mod to PC without disconnecting from drone.
pawelsky is online now Find More Posts by pawelsky
Old Sep 03, 2012, 08:56 AM
dante1 is offline
Find More Posts by dante1
XR-4Drone.com
dante1's Avatar
Canada, QC, Montreal
Joined May 2011
I see. I put on anyway. You never know when you might need it
dante1 is offline Find More Posts by dante1
Old Sep 03, 2012, 09:05 AM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
Issue with Drone2
Hey Pawelsky,
I made a drone 2 kit for a friend and he tells me that when he changes battery...he is getting a delayed response from the sticks.
He tells me that when he changes battery, he has to turn off the TX, wait for Drone 2 to boot, hit the reset button on the Drone 2, wait 10 seconds and turn on the TX. He says that most of the time it works but sometimes the drone 2 has a delayed response and can't control his drone.
Do you know what that could be?
Dante1
Arduino Nano v3.0
Old Sep 03, 2012, 09:27 AM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Hey Pawelsky,
Dante1
Arduino Nano v3.0
If your friend is flying CONFIG 1 or 2, he needs to wait until the video has been processed (motor lights blinking) before he changes battery, otherwise the drone will do it when it comes back up on the new battery. Alternatively, you can turn off the 'auto record start' in the 'sketch'.
miru is offline Find More Posts by miru
Old Sep 03, 2012, 10:05 AM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
Thanks, I will let him know.
Old Sep 03, 2012, 10:20 AM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
Is this "auto record start"?
Red numbers need to be changed to "0"?
* videorecord: 0 - disable, 1 - enable (NOOP on Drone 1 or Drone 2 without USB stick)
* outdoor,no_shell,max_euler,max_vz,max_yaw,max_alt, anim,rvid */
const char cfg1[] PROGMEM = "1,1,0.35,1500,3.5,0,1,1"; /* S standard */
const char cfg2[] PROGMEM = "1,1,0.52,2000,6.1,0,1,1"; /* W wild (max) */
const char cfg3[] PROGMEM = "0,0,0.21,700,1.75,2,0,0"; /* N normal */
const char cfg4[] PROGMEM = "0,0,0.10,700,1.50,2,0,0"; /* E easy */
Old Sep 03, 2012, 10:30 AM
pawelsky's Avatar
Poland
Joined Jan 2012
Yes, you can also use Sketch Configurator: http://mirumod.tk/tools/sketch_configurator.php
Old Sep 03, 2012, 12:30 PM
vectorcharlie is offline
Find More Posts by vectorcharlie
Joined Sep 2012
I'm affraid the wiring is OK
Thanks for checking Pawelsy! Live and learn
vectorcharlie is offline Find More Posts by vectorcharlie
Old Sep 03, 2012, 12:32 PM
Joined Sep 2012
Originally Posted by RockCopters View Post
Can you check for a bad soldered connector on the drone's mainboard?
Heard that it is possible, that the SMD connector can come loose by the time.
I will check it Rock, anyway, I have to learn how to unmount the Main board. I was already thinking on checking it and maybe soldering directly the lines.
Old Sep 03, 2012, 12:34 PM
Joined Sep 2012
Hey Vectorcharlie,
Dante1
Thanks Dante. I haven't put it, as I am not doing any testing of the Arduino usb and the serial connected to the drone at the same time. But I will do it once I assemble everythng (And making it work )
Thanks!
Old Sep 04, 2012, 11:57 AM
TZZDC1241 is offline
Find More Posts by TZZDC1241
United States, CO, Breckenridge
Joined Feb 2012
Now that there's a new awesome firmware (for once) for the drone, 2.2.6.. Anything that can be updated software wise on the mod to better fly this drone or will the standard stuff work just as well?
TZZDC1241 is offline Find More Posts by TZZDC1241
Old Sep 04, 2012, 01:23 PM
pawelsky's Avatar
Poland
Joined Jan 2012
FW Manager for AR.Drone 2.0
Author of a very useful free iOS tool for switching between AR.Drone v1.0 firmwares - FW Manager - has started a poll on his website, asking whether people would be interested in a version for AR.Drone v2.0 as well.
http://www.powerflightapp.com/index....=1:fwmanager20
Since this is a very handy piece of software that was only missing the AR.Drone v2.0 support I believe it is worth saying YES! Parrot likes to surprise us sometimes with some 'unexpected' updates, so it is always good to be able to return to previous versions (FWM gives access to historic versions as well).
To vote you have to select your option (I hope it will be "Yes") on the left and click "ABSTIMMEN" (meaning "Vote" in German)
P.S. For those who don't know FW manager yet here is the iTunes link - http://itunes.apple.com/us/app/firmw...426009871?mt=8 (despite some negative comments - it does work)
Old Sep 04, 2012, 05:35 PM
tonyh0905 is online now
Find More Posts by tonyh0905
tonyh0905's Avatar
United Kingdom, Wales, Cardiff
Joined Mar 2012
I don't own an idev, but I happy to give a yes vote if it's handy for others
tonyh0905 is online now Find More Posts by tonyh0905
Old Sep 04, 2012, 05:57 PM
miru is offline
Vista, CA
Joined Feb 2008
It does work with the new rev 0.19, don't think there are any issues with rev 0.18.
Old Sep 04, 2012, 11:55 PM
Ant_30 is offline
Find More Posts by Ant_30
Joined Sep 2012
It works ok, but I can not get my Drone 2 to do any flips so does this part not work or am I doing something wrong?
Ant_30 is offline Find More Posts by Ant_30
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
