Old Jul 19, 2012, 02:17 PM
drone_droid is offline
Find More Posts by drone_droid
drone_droid's Avatar
Joined Jun 2012
Originally Posted by Exploding Fist View Post
To be fair it's designed for people who don't know how to do stuff like that. Otherwise they'd just make their own.
He's on these forums, so you could always try sending him a message. He had a bunch of spare centering levers for the 9x and mailed me one at his expense, so he's an extremely generous guy -> ssgtmacgyver
Thank you this is nice to know.
drone_droid is offline Find More Posts by drone_droid
Old Jul 20, 2012, 08:27 AM
pawelsky is offline
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
MiruMod + GPS
In case someone is interested in a very simple way of installing the mod on the AR.Drone I'm sharing pictures on my setup. Basically I use 2 black plastic cable ties, that wrap around the velcro straps in the battery compartment of the Drone. No need to cut any holes, etc. it is fully P&P and can be easily removed.
The GPS module can of course be easilly detached if not needed.
In case someone wonders what are the pins next to USB port used for, these are connected to 2 spare channels (7&8 of the receiver) and can be used e.g. to connect servos for camera pan&tilt or some switches. There is also a connector to attach external power (if Nano's regulator cannot cope) and one pin to power it from Nano (if the power requirements are not too big). These pins can also be used for binding the receiver and after disconnecting the 12v pin from the drone, also for powering Nano itself from external power source.
On the opposite side yo can also see the setup pins.
PROS of this setup:
- easy to install/remove
- additional functions (such as extra channels, and power options)
- all components located close to the Drone's center of mass (so flight characteristic should not be affected)
- fits nicely under the hull - no need to drill holes in it
CONS:
- can't see Arduino/GPS leds with hood on
EDIT: you can connect external LED (with resistor) to pin 13 to solve that problem, also as of rev019 (thanks miru) after moving the throttle stick down while in LAND it will also show the GPS state.
pawelsky is offline Find More Posts by pawelsky
Old Jul 20, 2012, 03:35 PM
RHTizzy is online now
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
PROS of this setup:
CONS:
Now that's nice and compact, I wish I could get mine looking that neat. Do you still get a good fix with the gps under the hood like that or do you fly with the hood off?
RHTizzy is online now Find More Posts by RHTizzy
Old Jul 20, 2012, 03:57 PM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Can't tell for sure until the v0.19 with logging enabled is out but so far I could only measure signal levels while connected to PC and did not see any significant difference with or without the hood.
Old Jul 20, 2012, 06:24 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
PROS of this setup:
CONS:
The output driving the Arduino LED is D13. Maybe it should show the GPS status when one moves the throttle all the way down?
miru is offline Find More Posts by miru
Old Jul 21, 2012, 04:02 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Interesting idea.
Old Jul 21, 2012, 06:57 AM
Fioulmaster is offline
Find More Posts by Fioulmaster
France, PCh, Poitiers
Joined Oct 2011
My Custom Mirumod
PROS of this setup:
CONS:
This is my Mod with Rx led and ARduino Led removed.
See that:
Mod with Setup Plug:
Mod with Bind Plug:
On the Drone with FTDI, Green led=Arduino, Red Led=Rx:
Fioulmaster is offline Find More Posts by Fioulmaster
Old Jul 24, 2012, 09:21 AM
CopyCatz is offline
Find More Posts by CopyCatz
Joined Jul 2012
I've been prototyping the connection between the rx (turnigy 8 chan) and an arduino uno, everything works fine; I was able to setup the tx, made sure all the digital pins had the right channel by using the terminal test program. Now I've moved the rx to a nano but am running into trouble; when I connect the bare nano to my windows 7 64 pc, it installs the driver and creates a com port. But when I attach the rx (signal pins and +5v and gnd) exactly the same way as on the uno, windows doesn't recognise it anymore and installs an "unknown device". I have signals on the D pins, rx + to 5v on nano, and rx gnd to nano gnd next to the d2 pin. Somehow having the rx attached messes up the ftdi connection? Anyone seen this before?
CopyCatz is offline Find More Posts by CopyCatz
Old Jul 24, 2012, 09:51 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Maybe that will help:
http://arduino.cc/forum/index.php?topic=58183.0
Old Jul 24, 2012, 09:55 AM
CopyCatz is offline
Joined Jul 2012
It's not that issue; I've been digging up some other usb cables, with some I get the nano recognized and the port works.. But when I use the terminal nothing shows up with ctrl b, then restarting the terminal connection gives me some leftover text bits from the test program.. It must be a power issue, maybe I should just complete the build and connect it to the ar drone for more juice.
Old Jul 24, 2012, 11:24 AM
pawelsky is offline
pawelsky's Avatar
Poland
Joined Jan 2012
Do you ground the setup pin? (D11)
I believe miru was warning to not do that (i.e. connect the drone power with Nano connected to USB)
Old Jul 24, 2012, 11:41 AM
miru is offline
Vista, CA
Joined Feb 2008
The W7 USB driver takes it's good time to figure things out and sometimes gets confused when the mod starts before it got things figured out. I changed in rev 0.19 the mod startup, it also waits in SETUP mode for the RX pin (TX from PC) to go active before it turns on it's TX, which reduces the number of driver insertion failures.
Pawelsky is right! Do NOT power the Nano from 2 sources! It's either USB OR the DRONE.
I'll check that FTDI pin 26 fix, when I get a chance.
Old Jul 24, 2012, 05:13 PM
CopyCatz is offline
Joined Jul 2012
Thanks Miru, I'll wait for that then. I'm kinda novice in the world of electronics, I can do my share of c programming, but wiring stuff up without the knowledge of what's going on makes me nervous
On that note, if it's not too much trouble could you or someone else explain the right side of the logic level converter in the ar drone 2.0 schematic? I don't really understand where the 1.8v is coming from when I connect both rx channels and the lv together?
Old Jul 24, 2012, 05:42 PM
miru is offline
Vista, CA
Joined Feb 2008
Check http://mirumod.tk/hw/arduino_nano/arduino_nano.php , it shows the wiring. Check http://www.sparkfun.com/datasheets/B...verter-v10.pdf for the schematics of the level shifter. I am using the resitor branches to generate the 3.3V for D1 or 1.8V for D2. The drone is always on the LV side and the Arduino on the HV side.
Old Jul 25, 2012, 04:42 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Ok, apologies for the noob question, but if I'm going to build one of these for my 1.0, does the newer wiring diagram for 1.0 and 2.0 mean that I'll be able to swap it safely if/when I upgrade to a 2.0 drone with just a minor change to the connections on the level shifter?
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
