Joined Feb 2012
Joined Feb 2012
Folks,
So far mod works great and as i noticed, I felt there are some sudden glitches in the drone behavior to the TX stick movements. And also there is a slight delay in the communication as well..Is this normal ???. I don't feel it's a signal interference..Any suggestion guys.. Thx |
Joined Oct 2011
United States, NY, New York
Joined Feb 2012
Have a 2nd drone with miru mod also (thx to LittleG), is there a sketch configurator profile for DX8 like there is for DX6, DX7 or can I just use the DX7 profile with DX8? |
Joined Oct 2011
2. How happened: The problem appeared when AR drone was under RC control and iPad video simultaneously. This was about 10th flight with mirumod (all them were awesome without any problems). The AR drone landed slightly touching the obstacle, I don't remember sequence of powering off iPad, battery and RC. Next time AR drone with mirumod attached could not pass initial startup (red motor's leds). 3. Reasons: The problem may be or may be not caused by mirumod. 4. Ar Drone is operational under iDev. What is now: When no hardware attached to the connector the boot sequence is normal the log is in the "no_hardware_good.txt" file. When logical "1" is presented at the Rx pin of AR drone's connector boot sequence is incorrect ("hardware_wrong.txt"). Logical "1" at Rx is normal when mirumod is attached and waiting for the end of ardrone init; that is why the whole system does not work. The "hardware_wrong.txt" is recorded with level converter attached, but mirumod is not attached to the level converter for simplicity (from the above its obvious that this is equivalent to the attached mirumod at this stage). Level converter pull Ardrone's Rx pin to 1.8V providing logical "1" at the Rx pin. When this pin is grounded from the HV side the boot is OK. Ar drone's Rx pin itself is not pulled, so it has nearly "0" logical level if no hardware attached. Both logs are highly reproducible (except some internal addresses). Connectors, wiring etc. are OK. Checked a million times. Please advice. Many thanks. |
Vista, CA
Joined Feb 2008
I do remember from the very early stages of the project, that the drone bootloader puts out a short pulse on the RX line and checks if it can do it, if so it would mean the line is in a high impedance state (aka nothing connected) and go through the normal bootsequence. Somehow this is a burried subject and once people get around it they never come back and investigate, since it might have changed anyway. |
Joined Oct 2011
Vista, CA
Joined Feb 2008
new release 0.18 coming up
Just wanted to give you a heads up on what is coming down the next week or so...
Joined Jan 2004
Hi,
i build the mod for my drone (version 1) too. Since I have no receiver with 5 channels or more, but one withe a SUM-Signal Output, i have attached a 8 Leg Bug (ATTiny45) on the bottom side of the Arduino. This Controller converts the PPM Datastream from the Receiver to 5 independent Channels, that i wired to the correspondending Pins of the Arduino. Big thank to miru for his awesome work ! Nos! |
Since I've never been able to test your "failsafe" function, could you please explain it again ? When the sketch detect a faulty channel, what's happening ? does it immediately land ? does it "fix" a hoovering position before ? does it hoover for a time ? Sev |
Vista, CA
Joined Feb 2008
BTW, you can use a Johnson counter to decode a sum PWM signal. |
| Thread Tools | |
| Mini-HowTo RC Controlled AR.Drone w/o WiFi! | nosaari | Multirotor Talk | 113 | May 13, 2011 02:26 PM |
| For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 4 | Apr 16, 2011 09:42 PM |
| Discussion Wifi Boosted AR.Drone | Fallengod | Multirotor Talk | 7 | Feb 12, 2011 10:52 AM |
| Discussion And yet another AR drone Arial Video project | taudronis | Multirotor Talk | 17 | Dec 07, 2010 11:04 AM |
| Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad | Hoverup | Aircraft - Electric - Helis (FS/W) | 0 | Oct 12, 2010 03:54 PM |
