Old May 15, 2012, 09:05 PM
glasspony2010 is offline
Find More Posts by glasspony2010
Joined May 2012
Ar drone 2
[QUOTE=miru;21623536]What app are you using on the iDev? I tested with FreeFlight 2.0 and it did work.[/QUOTE
when I am flying my drone with my me fly sky six channel transmitter at the same time I connect my iPhone I can get video feed on the iPhone but what I push record it will not record. How do I fix this I do have FreeFlight 2.0 on the iPhone
glasspony2010 is offline Find More Posts by glasspony2010
Old May 15, 2012, 10:07 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Does it take a picture when you tap on the camera icon?
miru is offline Find More Posts by miru
Old May 15, 2012, 10:19 PM
Joined May 2012
NO picture when you tap on the camera
Old May 16, 2012, 09:19 AM
kgeange is offline
Find More Posts by kgeange
Joined Apr 2012
Originally Posted by RHTizzy View Post
Mighty interested in the gps developments, how are you utilising the gps data?
Hi RHTizzy. I'm developing an iOS app (see post #2206) that will display the GPS data on the screen and record it (as KML) for viewing on Google Earth.
It's based on freeflight so I'll make the source available when it's complete (assuming I'm not breaking any of Parrot's legal agreements). I believe you have to sign up for Parrot's developer program to view the freeflight source so I'm not sure of the legalities...
kgeange is offline Find More Posts by kgeange
Old May 17, 2012, 09:38 AM
RHTizzy is offline
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
Sounds excellent! You know what would make it even better? If you got it working on Android, now that would be something ;-) Just kidding, I'm amazed at what you guys are able to get out of these things even if it is only available on those funny apple thingys..
RHTizzy is offline Find More Posts by RHTizzy
Old May 17, 2012, 09:12 PM
kgeange is offline
Joined Apr 2012
Ya, it was a hard choice between iOS and Android. I actually prefer Android for a lot of development work but I thought I could leverage the existing AR.Drone iOS framework to get something out quickly.
Android will be next.
Off topic: My Fox 1.3GHz 800mW video tx/rx showed up today and it's working nicely in the basement. Still gotta range test on the weekend. I fear the AR.Drone is probably underpowered for it so I'm a building a MultiWii quad. Fun...
Cheers!
Old May 18, 2012, 10:53 PM
jinpa108 is offline
Find More Posts by jinpa108
Joined May 2012
Hobbyking HK TR6A
HI I'm new here.
I searched this thread and I found some mentions of this transmitter/receiver/radio from hobbyking (HK-TR6A). the Receiver is labeled 1-6 from the bottom up and BATT at the top. the transmitter/Radio is 6 channels and has 2 Aux channels with a 2-position switch (SW) and 1 POT (VR) per channel 5 and 6.
My question is what configuration do I use on ver. DRS017. using the sketch configuration on: http://mirumod.hopto.org/tools/sketch_configurator.php
I believe this is the appropriate field to change things:
LAND and FM_x switch setup:
DropDown Menu choices:
One 3 position switch (e.g. DX7)*
One 2 position switch
Two switches (e.g. DX6)
Two switches
Also Please if someone could explain this FM1 FM2 FM3 stuff. I gather it has something to do with flight modes (indoor/Outdoor, Hull/No Hull) but thats all I can get, any specifics would be appreciated.
Thanks Miro for this great mod and everyone for their contributions.
Dan
jinpa108 is offline Find More Posts by jinpa108
Old May 19, 2012, 08:44 AM
miru is offline
Vista, CA
Joined Feb 2008
Originally Posted by jinpa108 View Post
HI I'm new here.
My question is what configuration do I use on ver. DRS017. using the sketch configuration on: http://mirumod.tk/tools/sketch_configurator.php
Two switches
Dan
The sequence of channels on a DSM RX is THRO,AILE,ELEV,RUDD,GEAR,AUX1 .
LAND, FM1, FM2 and FM3 are flight modes you set with your switches, before start you need to be in LAND, center the sticks and switch to FM1, this will make the drone take off and hover in place about 1 Meter above ground, using it's bottom camera to stay on the spot. You can fly it around go up and down rotate it. If you get in trouble let go of the aileron/elevator stick and it will stabilize itself by trying to stop any lateral motion and keeping it on the spot with the bottom camera. When you switch to FM2, the bottom camera data is not used to keep it on the spot when you let go of the aileron/elevator stick, it will coast to a stop and just hover, but not do any position maintenance, so it's up to you, the pilot, to do it. FM3 is not implemented yet, it will be used to trigger a RTL function once I got the GPS code in.
Make sure you read up and follow the instructions for SETUP mode!
Old May 19, 2012, 10:36 AM
miru is offline
Vista, CA
Joined Feb 2008
I had a chance to retest and it works here. The part I have not tested yet is if you record to an USB stick on the drone, do you have that turned on?
Old May 19, 2012, 11:05 AM
Joined May 2012
AR DRONE 2 radio and transmitter
I have the AR drone 2 and I am flying at the radio transmitter receiver kit. My problem is trying to do flips. Is there something I need to program into the transmitter if so what.? I am running the 017 stretch in the receiver board
Old May 19, 2012, 11:28 AM
miru is offline
Vista, CA
Joined Feb 2008
No, follow the instructions in this post:
http://www.rcgroups.com/forums/showp...postcount=2061
By default configurations 1 and 2 will do the flip, 3 and 4 will not.
Old May 19, 2012, 12:15 PM
Joined May 2012
I know all all the information about. my question is is there something I need to program the transmitter to make all this work
Old May 19, 2012, 12:27 PM
Joined May 2012
Ar drone 2 and raido transmitter
I have the fly sky fs-ct6b transmitter. Is there anybody out there that has this transmitter set up to fly the AR drone 2 . And they can do flips. If so could you send me by e-mail the command files to load into the transmitter using the USB cable with the T6 config program
send to pony1920@hotmail.com
thank you
Old May 19, 2012, 02:48 PM
miru is offline
Vista, CA
Joined Feb 2008
If your setup can do LAND/FM1/FM2 you don't need to change anything in your TX. Practice in SETUP mode, it will show you when your actions trigger an animation.
Old May 19, 2012, 08:16 PM
jinpa108 is offline
Joined May 2012
IF anybody has a good config file for a CT6A/B that they could PM or email me I would be very grateful.
Dan
jinpa108@gmail.com
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
