Old May 12, 2012, 07:23 AM
RHTizzy is offline
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
Originally Posted by kgeange View Post
I'd like to advise that the C3-370C GPS module runs fine out of the box with mirumod v17. Only change was the baudrate to 9600 in the sketch.
rx2at 0.17 20120428, at2so attached
loop 33.3 ms, gps 9600 bps
stick +-800 points, dcnt=2663
cpusg 1E950F fuses DA-FF-FD-CF
4 RX error
-RX- f[ms] p[us] value
AILE 52.5 1528 0
ELEV 52.5 1517 0
THRO 0.0 0 0 CFG4
RUDD 52.5 1548 0
AUX1 52.5 1524 0
GEAR 52.5 1101 0 LAND
GL=1,08,025354.000,47.6051500,-052.7420966,1.4,163.2
Mighty interested in the gps developments, how are you utilising the gps data?
RHTizzy is offline Find More Posts by RHTizzy
Old May 12, 2012, 07:24 PM
gustyk is offline
Find More Posts by gustyk
WING-WING situation
gustyk's Avatar
United States, NY, New York
Joined Jun 2006
My mod is complete..finally
After some time without doing much because I was waiting for the replacement for the central cross to come, I am very happy to announce I finished the mod
Here you are the results:
AR Drone with miru mod - GustyK version (4 min 8 sec)
Freeflight version 2.0.1
AR Drone: version 1.10.12
mirumod rev 0.17
Orange RX - 6 CH
Spectrum DX7 TX
Arduino Nano
I normally fly with a 3S-1300 mAH battery that gives me 15-20 minutes. For the purpose of this video, I'm using the stock battery.
This combination of software/firmware resolved all the little issues I had. Some of them were:
- Unable to boot up the mod. Need to reset the Arduino several times until finally responded to the DX7 commands.
- Sudden changes of altitude with no reason.
- No connection with iDev.
The only very minor thing is that I don't see any animation by switching from FM_1 to FM_2 and back to FM_1. I haven't investigated enough about it but I don't mind. The Drone flies beautifully. Once again, Thank you miru and all the very knowledgeable people in this forum.
gustyk is offline Find More Posts by gustyk
Old May 12, 2012, 07:52 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Congratulations!
To get an animation, you have to be in FM2 and shortly switch over to FM1 and back to FM2. Once you switch back to FM2 you have 0.4 seconds to move the aileron stick for the animation you want. You can practice/explore this in SETUP mode, it will show you if you did trigger an animation by showing an ANIM[1,2,3,4] message next to the FM_2.
miru is offline Find More Posts by miru
Old May 13, 2012, 08:22 AM
glasspony2010 is offline
Find More Posts by glasspony2010
Joined May 2012
Flysky fs ct6b transmitter
o precise control of drone
o cheap off the shelf hardware (Arduino Pro Mini or Nano, AR6100)
o started with firmware versions 1.4.6, 1.4.7, 1.5.1, 1.6.6, 1.7.4, 1.7.6
these versions can not be tested any more due to lack of existence in my lab
o tested with drone firmware version 1.7.11, 1.10.10 and 2.1.18
o true 'plug&play', disconnect HW and drone can be operated by iDev
+ no BEC needed
+ uses drone's serial port
+ no surgery of system files on drone
+ no need to make custom kernel for drone
+ prevents iDev highjacking of command port when in use
+ allows access to NAVDATA port for remote monitoring
+ allows access to video port for remote viewing
+ four different 'hot' selectable drone configurations
+ visual low battery alert (VLBA)
+ supports Mode 1, 2, 3 and 4 transmitters
Hardware
1) Drone
2) 5+ channel RC TX/RX, 4 channels for sticks, 1+ switche(s) for land/flightmode1/flightmode2
3) Arduino Pro Mini or Nano 16Mhz/5V
4) Please look at the wiring diagrams to find the parts needed
Software
From what I gather from the net, most people doing this have access to a
Windows box (I have XP) and can download the Arduino IDE (arduino-1.0.zip).
The implementation uses a pair of programs, one running on the Arduino, the
other running on the drone. The drone program is transfered and started by
the Arduino program.
rx2atp - receiver signal sampling and conversion to drone commands
Installation on Arduino Pro Mini, Arduino Nano
'rx2atp' is the program for the Arduino. It does not make use of any
Arduino environment library functions, exept the startup file and the
standard compiler support library, I hope they have not tinkered with...
This project has been tested with arduino-0022/3 and arduino-1.0-win.
Start the Arduino IDE, it comes up with an empty 'sketch', and select
<Sketch><Add File...>. Add the file 'rx2atp.c' from this package and
'Upload' it to the board.
at2so - forwarding drone commands from serial interface to socket
This program is uploaded and started on the drone by 'rx2atp'. It is loaded
into '/tmp' on the drone and does not survive a reboot of the drone.
Modifications to this program are not for the faint of heart. You need a
toolchain for the ARM processor that can generate programs for Linux on the
drone. At this point I use:
arm-2010.09-50-arm-none-linux-gnueabi-i686-pc-linux-gnu.tar.tar
on a Linux box.
miru
This thread has become fairly long and it is difficult to find the 'essentials', Pawelsky made a nice webpage that gets you the releveant information fast! Check out: http://mirumod.hopto.org/
Arduino Pro Mini wiring by Lorenzo29:
http://www.rcgroups.com/forums/showp...5&postcount=48
Arduino Nano wiring:
http://www.rcgroups.com/forums/showp...&postcount=484
REV 0.13 wiring:
http://www.rcgroups.com/forums/showp...postcount=1417
Drone 2 wiring:
http://www.rcgroups.com/forums/showp...postcount=2061
Latest revision REV 0.17 (consult README in .zip file for answers to some questions):
0.17 http://www.rcgroups.com/forums/showp...postcount=2061
Proper terminal emulator in case you are on Windows 7:
http://digitizor.com/2009/08/29/how-...indows-7-free/[/QUOTE]
+ Okay maybe you can help me with a problem that came up.I have the FLY SKY FS-CT6B transmitter and the instructions that you sent me I cannot find the program files to download into the transmitter using USB and the T6comg program that comes with the transmitter so you can download command files. the rx2atp.c for the arduino pro mini 16mhz /5v as been revised for the AR drone 2 but now the old command files for the transmitter will not work with the new rx2atp.c files so I need the new command files for the transmitter can you help
glasspony2010 is offline Find More Posts by glasspony2010
Old May 13, 2012, 08:40 AM
miru is offline
Vista, CA
Joined Feb 2008
Once your TX/RX is setup for the mod you don't have to change anything in the TX if the mod revision changes. I don't have a FLY SKY FS-CT6B, maybe somebody that has it can help.
Old May 13, 2012, 10:38 AM
Joined May 2012
AR drone 2 and transmitter
I need help with a little problem. While flying with transmitter and connecting iPhone for video recording I have no transmitter control I can only rotate right and rotate left no other functions will operate and tell I disconnect iPhone. How can I get video feed and use full transmitter control
Old May 13, 2012, 11:14 AM
miru is offline
Vista, CA
Joined Feb 2008
This sounds odd, can you elaborate some?
(Drone firmware version, iPhone application and version)
Does SETUP mode work properly?
Old May 13, 2012, 01:10 PM
Joined May 2012
I HAVE AR DRONE2
Drone firmware version 2.1.16
do I need to use a different rx2atp?
Old May 13, 2012, 01:38 PM
miru is offline
Vista, CA
Joined Feb 2008
I HAVE AR DRONE2
I never had firmware 2.1.16, mine is on 2.1.18.
You have to use rev 0.17 of the mod, it handles drone 1 AND drone 2.
Does SETUP work?
Old May 13, 2012, 09:08 PM
Joined May 2012
Does SETUP work?
I am having a problem getting the failsafe to operate I am using DSN017 is there something in his file that I need to change. I have the LED light wire on the receiver connected to 8 on the board or change a setting in it transmitter
Old May 13, 2012, 10:06 PM
arisarts is offline
Find More Posts by arisarts
Athens, Greece
Joined Dec 2004
What TX/TX are you using?
From Readme Miru file in the DSR017
"On my setup this did not work at first, because
in this situation the AR6100 kept on sending what it received last except for
the THRO channel, which will transmit the value the throttle stick had when it
was bound to the transmitter. To fix this in my setup, I did rebind the AR6100
with a very low throttle stick value (-150%), which fixed this (after putting
the gain back to 100%).
Then turn the transmitter back on and make sure everything comes back to normal."
arisarts is offline Find More Posts by arisarts
Old May 14, 2012, 08:43 AM
miru is offline
Vista, CA
Joined Feb 2008
The FSAF hardware failsafe is NOT enabled by default, you have to do that in the sketch or use the configurator on http://mirumod.tk/tools/sketch_configurator.php
The configurator still references the old A3 input, but the sketch will use the pin labelled 8.
Old May 14, 2012, 09:15 AM
pawelsky is online now
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
I've just corrected the description in configurator - it is now (D)8.
pawelsky is online now Find More Posts by pawelsky
Old May 15, 2012, 06:54 PM
Joined May 2012
Ar drone 2
thank you for your help I got everything working. Now I have one question.
When I am flying with remote control then I hook up the iPhone for video feed I get video feed but I cannot record. Is there a way to fix this
Old May 15, 2012, 07:03 PM
miru is offline
Vista, CA
Joined Feb 2008
What app are you using on the iDev? I tested with FreeFlight 2.0 and it did work.
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
