Old Apr 24, 2012, 09:24 AM
pawelsky is online now
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Originally Posted by miru View Post
And here are some bad news... I/O on drone 2 is 1.8V, which means one will have to use a level shifter to talk to it with the 5V Arduino.
Will that do the job?
http://www.sparkfun.com/products/8745
pawelsky is online now Find More Posts by pawelsky
Old Apr 24, 2012, 09:58 AM
daytimer is offline
Find More Posts by daytimer
United States, IL, Joliet
Joined Sep 2010
Yes, I do have a drone 2.0 now and started to work on it!
Don't forget about us lowly v1 users now!
daytimer is offline Find More Posts by daytimer
Old Apr 24, 2012, 10:01 AM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Originally Posted by pawelsky View Post
That's what I ordered, we'll see. I found in my research that some people had problems with 1.8V and a BSS138.
miru is offline Find More Posts by miru
Old Apr 24, 2012, 03:08 PM
vistauser is offline
Find More Posts by vistauser
Germering, S-Germany
Joined Nov 2010
It works now
Thank you Miru for your response,
to get the correct values in Setup-GUI i had to change flight control switching from S_GEAR to AUX1.
After this was fixed i run into the next trap: No takeoff possible with v 016.
Checking the last pages of this forum i found the solution --> increase the boot time from 10 to 21. Thanks to Pawelsky!
Now it flies as month before with v 008.
vistauser is offline Find More Posts by vistauser
Old Apr 24, 2012, 04:14 PM
Candu1 is offline
Find More Posts by Candu1
Joined Jul 2011
... I do have a drone 2.0 now and started to work on it!...
With the new compass and pressure sensors available on version 2, it should make GPS navigation development work easier too.
Candu1 is offline Find More Posts by Candu1
Old Apr 24, 2012, 06:49 PM
dante1 is offline
Find More Posts by dante1
XR-4Drone.com
dante1's Avatar
Canada, QC, Montreal
Joined May 2011
Newbie to mod
Hey Everyone,
I am very excited to try out this mod.
I bought a DX6i, OrangeRX and a Arduino Nano.
My question is, what gauge wire should I use to wire the Arduino to the RX and to the AR Drone? Would 30AWG be okay? Also, the instruction guides don't really talk about the Nano but does it use the same instructions as if I was using a Mini Pro?
Also, I am a little bit nervous about loosing my drone because it went out of range. Do the software have a fail safe setting?
If anyone has tips or suggestions for this mod, please throw them my way.
Dante1
(Montreal)
dante1 is offline Find More Posts by dante1
Old Apr 24, 2012, 06:55 PM
miru is offline
Vista, CA
Joined Feb 2008
Originally Posted by dante1 View Post
Hey Everyone,
Dante1
(Montreal)
AWG 30 is fine, just make sure you don't loose any strains when stripping it.
You will find eberything else you need on mirumod.tk
Old Apr 24, 2012, 07:03 PM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
You will find eberything else you need on mirumod.hopto.org
Thanks.
Old Apr 24, 2012, 08:32 PM
ccme is offline
Find More Posts by ccme
Joined Apr 2012
FreeFlight Version 2.0.1
http://itunes.apple.com/en/app/free-...373065271?mt=8
What's New in Version 2.0.1
- Video recording compatible with iPhone 3GS and iPod touch 3 (recording in 360p)
- Access to the registration for a demo in store through the section USER VIDEOS
- Bug fix
ccme is offline Find More Posts by ccme
Old Apr 24, 2012, 10:04 PM
ccme is offline
Joined Apr 2012
What is the firmware version ?
I found that v 014 work with FW1.7.11, but not v015 nor v016.(arduino mini pro LED does not blink)
Both v015 & v016 work with FW1.10.10
I prefer FW1.7.11to FW1.10.10 at the moment.
Old Apr 24, 2012, 10:10 PM
ccme is offline
Joined Apr 2012
Originally Posted by yessenzhar View Post
Hello. Great job thank you very much.
I have a little problem with this mode. Sometimes drone doesn't launch, as i think because arduino is overheated, I'm using arduino mini pro and the battery 1300mAh. Battery output voltage is 13.0V. Is it ok?
Please list more details such as firmware version and Mod version.
What is your receiver ?
Old Apr 24, 2012, 11:02 PM
ccme is offline
Joined Apr 2012
inertial software
I have upgraded from FW 1.7.11 to 1.10.10 and restored to 1.7.11 several times.
Now strange thing happens.
I got a new FW(1.10.10) with old inertial software (4.324).
Before that , the old FW (1.7.11) is with newer inertial software (4.65).
How does it happen ?
Is it possible to select the flight control, inertial and motor software to be updated individually ?
Please help.
Old Apr 25, 2012, 08:31 AM
miru is offline
Vista, CA
Joined Feb 2008
Please help.
4.65 is older than 4.324. I think 1.7.11 can not handle 4.324 reports.
Old Apr 25, 2012, 04:02 PM
miru is offline
Vista, CA
Joined Feb 2008
Need input
While waiting for parts for the new drone (level shifter and connector) I found out, that the flip is initiated with a CONFIG command. Further research showed that it is just a new flight animation move. So far we have not addressed triggering animations on the drone, which should be done so one can use the animations. There are 16 different ones in drone 1 and the new drone must have more, since the left flip is #18 (this is the only one I have been able to trigger so far).
I need input and ideas from the group how to do that trigger from the TX. My initial thought was to use the rudder channel (short hard left or hard right) to trigger at least 2 different animations, but it's not that good, since the drone reacts to the yaw command fairly quick.
Old Apr 25, 2012, 04:13 PM
pawelsky's Avatar
Poland
Joined Jan 2012
Have you tried to force #17 and #18 on Ardrone 1.0?
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
