Old May 04, 2011, 10:11 AM
Vista, CA
Joined Feb 2008
Originally Posted by actionplus View Post
Here are more videos.
Thank you for sharing! I still have to figure out how to make and publish a video here..
If covering the camera remedies the 'gass' problem, the algorithm of the vision software for the down looking camera is falling apart over grass... However, when it is working, it does a good job keeping the drone hovering in one place. Since I can not look at the source, my guess would be that they use some sort of correlation between successive image frames and just loose it over grass using a lot of CPU time, which in turn upsets everything else...
The wild swinging also happens here once in a while with the camera uncovered over concrete.
The midpoint problem might be due to the low resolution of the receiver signal sampling (+-100 points). I changed that in rev 0.05 to +-800 points.
Noticed you are flying with the indoor shell, did you change the 'cfgs[]' to reflect that?
miru is offline Find More Posts by miru
Old May 04, 2011, 10:33 AM
USA, CA, Fontana
Joined Mar 2005
Shell
No. I did not change the config to indoor shell. Do I just put 'false' in that line code?
I was thinking about using a little DPST switch on the arduino, where one is a pull up and the other a pull down, so that way we can switch between modes in a fly. But that will require some code changes from the master.
But I did try flying without any shell and it felt MUCH better and smoother, but didn't want to fly it too long till the drone figured out that the cam is still looking at one spot. (the tape).
On the helicommand, we place a piece of paper with a marking on it, so it thinks it is still looking at one spot and so no corrective action is taken by it. I will try placing a marker on the drones vision today and see if that helps.
As far video.
I took it on my iPhone. Download it to my Mac. Then uploaded it to YouTube.
Then pasted the links from YouTube on the thread v
actionplus is offline Find More Posts by actionplus
Old May 04, 2011, 10:55 AM
United States, OH, Powell
Joined Dec 2006
I am using ver. 004 with out issue...over grass, concrete.etc...but I do have a question...how do the settings, indoor hull, outdoor hull etc affect the drone?
rjrobbin is offline Find More Posts by rjrobbin
Old May 04, 2011, 11:06 AM
USA, CA, Fontana
Joined Mar 2005
Firmware
What drone firmware are you running? 1.5.1?
Maybe I should reload it again as I updated it via my iPhone. Might be better doing it via a Mac/pc
Old May 04, 2011, 11:59 AM
Joined Dec 2006
well...( long answer ) I am using the latest..1.5.1...I read on one of my iPhone apps that I was upgrading the suggestion to re-download the firmware....author claimed that Parrot does not do point releases...once again...that is what I read..So I down loaded the latest code and ftp'd it to my drone....( short answer ) 1.5.1.
Old May 04, 2011, 12:21 PM
Vista, CA
Joined Feb 2008
Yes.
Old May 04, 2011, 12:24 PM
Vista, CA
Joined Feb 2008
I think it affects the gains in the control loop, it is more sloppy if it is told that it is flying with the indoor hull.
Old May 04, 2011, 12:58 PM
Joined Dec 2006
Interesting..thanks...this has been bugging me for a while....
Old May 05, 2011, 12:40 AM
Joined Nov 2010
Yes, it does impact the PID gains.
http://code.google.com/p/brown-ros-p...common.h?r=964
Code:
 *  \var     CTRL_DEFAULT_NUM_PQ_KP
 *  \brief   Numerator of default proportionnal gain for pitch (p) and roll (q) angular rate control loops
 *  \var     CTRL_DEFAULT_NUM_EA_KP
 *  \brief   Numerator of default proportionnal gain for Euler Angle control loops
 *  \var     CTRL_DEFAULT_NUM_EA_KI
 *  \brief   Numerator of default integral gain for Euler Angle control loops
#define CTRL_DEFAULT_NUM_PQ_KP_NO_SHELL /*30000  26000 */ 20000
#define CTRL_DEFAULT_NUM_EA_KP_NO_SHELL /*7000  9000  7000 */ 8000
#define CTRL_DEFAULT_NUM_EA_KI_NO_SHELL /*4000  7000 6000 */ 7000
#define CTRL_DEFAULT_NUM_PQ_KP_SHELL /*30000 23000*/ 20000
#define CTRL_DEFAULT_NUM_EA_KP_SHELL /*9000 10000*/  9000
#define CTRL_DEFAULT_NUM_EA_KI_SHELL /*5000 9000*/   8000
It can be changed by AT*GAIN
MAPGPS is offline Find More Posts by MAPGPS
Old May 05, 2011, 02:34 PM
USA, CA, Fontana
Joined Mar 2005
Drone firmware update
I did my first update on the drone via my Mac yesterday. Usually via iphone and it took a few minutes to update.
Now, using ftp via Filezilla. It only took less than a minutes to transfer the file over. Then I disconnected the battery from the drone and reconnected. LED was red as usual, then back to green.
Instruction on the website said it will take about 10minutes
But mine was like normal bootup time. Did it really update it?
Old May 05, 2011, 05:47 PM
Vista, CA
Joined Feb 2008
Check with your iPhone and FreeFlight, it will tell you what version you are running.
Old May 05, 2011, 06:02 PM
USA, CA, Fontana
Joined Mar 2005
Version
Well. The problem is that I had 1.5.1 already in it. But I did
It via iPhone. But to make sure the install via iPhone was not causing the grass issue. I want to make sure my reinstall via Mac did actually install
And it is not the install from the iPhone. Guess there is no way of telling.
Old May 05, 2011, 06:48 PM
Joined Dec 2006
I did my update via the PC. It didn't take anywhere close to 10mins..more like a minute.
Old May 05, 2011, 08:42 PM
Vista, CA
Joined Feb 2008
If your iPhone has the latest FreeFlight, v1.7.1 at this time, AND you can 'telnet' into the drone, you can force an update of the firmware like this:
1) power up drone
2) once it shows the green lights telnet into it and do the following commands:
# cd firmware
# echo 0.0.0 > version.txt
# sync
# exit this should terminate your telnet session
3) cycle power to the drone, it should boot and turn on the green lights
4) get your iPhone connected to the ardroneXXX network and start FreeFlight, it will tell you that the drone is running revision 0.0.0 and there is an upgrade available, select OK and follow the procedure... when it wants you to restart the drone, cycle power to the drone and it will do the install. Do NOT quit FreeFlight during the power cycle, it expects, acually waits for, the loss of communication and reconnects once the drone is back up.
At least you know now that you are running the latest stuff on the drone.
Old May 06, 2011, 06:04 PM
USA, CA, Fontana
Joined Mar 2005
Grass issue
Think my grass issue is gone after the reinstall of Drone firmware. I only got a few minutes of flight. (Windy again out here)
But looks to be very promising.
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 113 May 13, 2011 02:26 PM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
