Canada, ON, Ottawa
Joined Apr 2011
Flight Videos
Hi,
Does anyone have any flight videos (3rd person view) with the mod they can post? I want to see the impact of the improved 'potortional' control and also the effect of mixing the rudder and aleron to smooth the flight....I have been flying well on the ipod, but the lack of rudder feedback (because of the touch screen), makes you fly back and forth in a Box! I fly my helis in smooth circles and would love to do that with the AR.D. My AR.D did two flyaways onm wifi requiring some climbing!! - parrot repaired it twice but have RC for outdoor flight with the improved range will make all the difference...nice job muru on the mod.looking forward to trying it. malder |
USA, CA, Fontana
Joined Mar 2005
Controlability
Well, you will have a heli feel once you convert.
With iDevice you should still be able to fly with out the "box" flight. I fly it with out the acc enabled. So, both thumbs on the screen and you can control both rudder and aileron at the same time. Or at least I think I can. ![]() I think there is a video on this thread on how it looks like when it flies. I just tried mine yesterday. Crimp 2mm connectors worked out very well. Still using 0.03 firmware. Will update to 0.04 today before flight. Maybe will take some videos this evening and upload them. |
Vista, CA
Joined Feb 2008
France - Brest
Joined Oct 2007
Hello,
i did the mod for a friend... with a AR.drone with Firmware 1.5.1, no problem, everything works fine ! We used a FUTABA F-617FS receiver... perfect... works fine ! The transmitter is a 12FH, very nice radio... we used the FM2 3 position switch mode... off course ![]() For your information, we setted up the sensibilities of the channels in the arduino software to the maximum and we used the exponential function in the radio to calm down the Drone a bit Works fine...Cheers. Laurent |
Joined Nov 2010
The IDG-500 gyro has two separate outputs per axis for higher speed motions and lower-speed precise movements: 500°/s full scale range (higher speed) 110°/s full scale range (high precision) They are gyro(X,Y,Z) and gyro110(X,Y). On the ground, they have the same outputs. On flying, they have different outputs. The NavData_Demo Psi (Yaw) is a fusion of them (including acc). No further analysis yet. |
Vista, CA
Joined Feb 2008
Canada, ON, Ottawa
Joined Apr 2011
I ordered the FTDI Breakout 5V Sparkfun : do you have a photo or wiring diagram to connect to the Arduino? I ordered the parts and I am awaiting the arrival, I am not sure if it just plugs in and then USB's to the MAC/PC or if I need to wire it up like Miru's photo... thanks...! |
USA, CA, Fontana
Joined Mar 2005
Ftdi
Then just plug the Ardunio to the FTDI board(female connector already on it). Then plug it in to your Mac. |
Vista, CA
Joined Feb 2008
USA, CA, Fontana
Joined Mar 2005
And when it takes off, seem not to take off straight up. Takes a few seconds before it stabilize. (non grass surface) But again, it has been really windy this weekend. Will keep trying. |
Vista, CA
Joined Feb 2008
| Thread Tools | |
| Mini-HowTo RC Controlled AR.Drone w/o WiFi! | nosaari | Multirotor Talk | 113 | May 13, 2011 02:26 PM |
| For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 4 | Apr 16, 2011 09:42 PM |
| Discussion Wifi Boosted AR.Drone | Fallengod | Multirotor Talk | 7 | Feb 12, 2011 10:52 AM |
| Discussion And yet another AR drone Arial Video project | taudronis | Multirotor Talk | 17 | Dec 07, 2010 11:04 AM |
| Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad | Hoverup | Aircraft - Electric - Helis (FS/W) | 0 | Oct 12, 2010 03:54 PM |
