Old Jan 29, 2012, 06:02 PM
Redeye51 is offline
Find More Posts by Redeye51
Joined Aug 2011
Originally Posted by miru View Post
This looks like your TX is not on. Does the ORANGERX turn on the LED which shows it is conneted to the TX?
The tx is on. The light on the orangerx is on but dim. When i remove the rx to bind, the light is much brighter.
One thing to note is the light is on once its plugged into the usb and than after to tx is powered on there is no change in the led. Its almost like the binding is lost.
Redeye51 is offline Find More Posts by Redeye51
Old Jan 29, 2012, 06:35 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Which ORANGERX do you have?
I have never seen a dimm LED on my 6 channel ORANGERX, it's either on or off. Maybe you have a power problem. Can you measure the Voltage on the Arduino 5V pin? Measure it with the RX connected and disconnected.
miru is offline Find More Posts by miru
Old Jan 29, 2012, 07:28 PM
griffinmt is offline
Find More Posts by griffinmt
griffinmt's Avatar
Midland MI
Joined Nov 2006
Is it possible that the lines from the arduino to the rx are plugged incorrectly?
That would also account for not reading any signal values.
griffinmt is offline Find More Posts by griffinmt
Old Jan 30, 2012, 07:47 PM
griffinmt's Avatar
Midland MI
Joined Nov 2006
I was thinking about the problem that seems to cause the drone to automatically land for no apparent reason.
Something that will cause this to happen (ie: loss of signal) is a problem with the signal on a 2.4ghz being blocked by any carbon fiber (like the arms), by metal (the internal parts and battery) or the wifi electronics(was considered).
As far as the wifi blockage possibility, the newer dsmx rx are capable of running in fhss mode instead of dsss, which should all but eliminate that issue.
For anyone with this problem, if you have an rx that a sattelite receiver can be attached, try that with the sattelite as far removed as possible and at 90 degrees.
Martyn
Old Jan 30, 2012, 08:20 PM
griffinmt's Avatar
Midland MI
Joined Nov 2006
Speaking of the 6Ch OrangeRX (version that is spektrum compat.), does anyone have a transmitter that is compat with spektrum receivers such as the DX6I or better?
Martyn
Old Jan 30, 2012, 08:41 PM
g3f0rc3 is offline
Find More Posts by g3f0rc3
g3f0rc3's Avatar
United States, AZ, Phoenix
Joined Sep 2010
Just wanted to say thx macgyver. he sent me a replacement. works great now .
g3f0rc3 is offline Find More Posts by g3f0rc3
Old Feb 01, 2012, 11:56 AM
pawelsky is offline
Find More Posts by pawelsky
Makers gonna make...
pawelsky's Avatar
Poland
Joined Jan 2012
Originally Posted by ssgtmacgyver View Post
This looks like the same spring and lever i have for my FlySky CT6b radios.
Just got the spring from ssgtmacgyver and it indeed fits perfectly! The lever unfortunately is a different one, but it is not problem to make one yourself (I made mine out of an old credit card, which can be easily cut with scissors - took me about 15min)
BTW it was packaged very nicely and arrived in just 4 working days from US to Europe
pawelsky is offline Find More Posts by pawelsky
Old Feb 01, 2012, 02:19 PM
afinegan is offline
Find More Posts by afinegan
Joined Aug 2009
Well, I tried 0.13 to see if the disconnect problem went away, it didn't. The behavior is the same as 0.12.
Which is:
1. plug in drone
2. When the drone is ready to fly -> connect iphone to it and start up freeflight
3. push right stick to change camera's around
4. flip takeoff switch and start flying
5. It flashes all greens and lands (I have zero control)
What is really odd is, as soon as I "lose control" I flip the land switch to land and then back to takeoff, and as soon as it touchs the ground, it takes immediately off again.
I am thinking of purchasing an arduino nano so I have the 3.3 volt logic for the gps's that you are using miru (this will also rule out that my wiring job or my arduino mini pro is not bad).
I was wondering, have you tried the GPS chip that arducopter uses, it flies incredibly stable in hold position mode and their software is opensource so you can take their algorithyms so you aren't re-inventing the wheel
They do say that they use a 3 axis magnetometer in combination with gps chip to do this properly
arducopter position hold (perfectly acceptable position hold):
ArduCopter GPS position hold (2 min 29 sec)
gps chip used (same page is their source code on code.google.com):
http://code.google.com/p/arducopter/wiki/MediaTek
Mediatek GPS 3329 datasheet (looks like DIYDRONES runs a custom firmware on it - http://store.diydrones.com/MediaTek_.../mt3329-02.htm
https://docs.google.com/viewer?a=v&p...iNjcy&hl=en_US
afinegan is offline Find More Posts by afinegan
Old Feb 01, 2012, 03:10 PM
miru is offline
Vista, CA
Joined Feb 2008
I guess I need to get one of those GPS...
Old Feb 01, 2012, 03:34 PM
RolluS is offline
Find More Posts by RolluS
Hi all,
this GPS has caught my eye already.
Source code is clear, with librarie for the GPS, etc..
RolluS is offline Find More Posts by RolluS
Old Feb 02, 2012, 04:33 PM
griffinmt's Avatar
Midland MI
Joined Nov 2006
As far as I can tell, the GPS unit is fairly heavy user of power (relative to other choices at least) and it may not be any more accurate/reliable than some of the others that you looked at. But it certainly seems to weigh less.
Martyn
Old Feb 02, 2012, 04:41 PM
afinegan is offline
Joined Aug 2009
I was just showing a gps working the way we want, and there source code is open :-P, Help push the R&D side of things, maybe.
Old Feb 03, 2012, 02:56 PM
unisev is offline
Find More Posts by unisev
unisev's Avatar
Joined Sep 2011
Turborix 6ch cut-off
Hello,
I've tested my Turborix Receiver 6ch, all the channel are doing that :
http://youtu.be/ndU-9B8C3KA
Except N4 & 5 that maintain last signal...
So, Arduino should LAND the Drone when I switch OFF my Tx ?
unisev is offline Find More Posts by unisev
Old Feb 03, 2012, 03:04 PM
miru is offline
Vista, CA
Joined Feb 2008
Originally Posted by unisev View Post
Hello,
Yes it should, trust is good, checking is better, use SETUP to verify.
Old Feb 03, 2012, 04:42 PM
unisev is offline
unisev's Avatar
Joined Sep 2011
I already checked it, and no one is going red...
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
