Old Apr 09, 2011, 08:00 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Yippee!
5.8Ghz circular polarized omnidirectional range test sensation
Hi all,
I just wanted to share this. We did a short range test trying to find the limits of the following 5.8ghz setup:
- Custom 200mW tx
- Stock RC 305 reciver
- custom Cloverleaf 5.8Ghz omnidirectional cicular polarized antenna on tx
- custom Skew Planar Wheel 5.8Ghz omnidirectional cicular polarized antenna on rx
We flew out 4.5Km and returned. No special events so far. We now will try to go out even further as there was still no visible degreation in video quality and report back. The 4.5Km were without any noticeable events, clear video, no issues.
Edit: We flew again, this time we went 6 Km out! At this point we had to return because the video started to slightly snow at around 5Km, getting to a ponit at 6Km where we found it adviseable to return. So it seems that one can fly out with this setup to 5Km without much concern!
The transmitter is the one presented in this thread:
http://www.rcgroups.com/forums/showthread.php?t=1404925
However, it uses the same HF module as the stock tx. We haven't tested yet if the stock tx would be worse range wise. We may will test this later.
The custom tx, the cloverleaf and skew planar wheel antennas were made by myself.
Omnidirectional circular polarized antennas rule
Markus
markus123456 is offline Find More Posts by markus123456
Last edited by markus123456; Apr 09, 2011 at 10:36 AM. Reason: New flight out to 6Km
Old Apr 09, 2011, 01:44 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Markus
That's an understatement.
CP is the way of the future for FPV. No two ways about it. Anyone who doesn't think that has likely never tried it.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 09, 2011, 01:50 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
I so need to get a LRS and test the stock TX. Looking forward to your findings markus. Looks like I am not so upset that I went with 5.8 after all. 6km here in Germany is great as going further you are always over towns.
I can't believe the different CP antennas work. Alex you changed the way I enjoy FPV with these.
whakahere is offline Find More Posts by whakahere
Old Apr 09, 2011, 04:27 PM
swing2harmony is offline
Find More Posts by swing2harmony
Canada, ON, Toronto
Joined Mar 2011
Only if someone could do the same test with the stock 200mW tx so we can see how much of a difference the custom tx makes.
btw Markus, was this test done in a RF busy area? Were there any tall buildings between you and the plane at 5km to prove CP and 5.8Ghz really work? thanks!
swing2harmony is offline Find More Posts by swing2harmony
Old Apr 09, 2011, 05:29 PM
Registered FPVer :)
Joined Aug 2006
This particular test was made more in a country side area. There IS civilisation around too (as in most parts of Switzerland) but it was not really a city. We had to go there because of regulations at the usual flying field which would not have allowed to do this kind of tests. We usually fly from an air base and there some rigid restrictions are in place.
Regarding the tx, the only difference is the power feed of the transtmitter module the HF module is the same as the one used in the stock tx.
Obviousely good filtering can lead to more range if there is less noise disturbing the image when reaching the limits. I think though that if it would not have been the same, the difference might only be in the last kilometer flown.
There are IMHO two magic factors here. First and most importantly the antennas, secondly the exceptionally good reciver with its outstanding -90dB sensitivity.
So if anyone wants to reproduce this, get yourself a pair of those CP antennas. I'm willing to make some so as people can reproduce my experience. Intersted parties shall send me PM.
Markus
Old Apr 11, 2011, 11:04 AM
Registered FPVer :)
Joined Aug 2006
The CP antennas rule
Hi all,
I'm getting messages from people interested in my transmitter thining it was the transmitter who is responsible for this exceptional flight. I'd like state that similar range can be reached with the STOCK transmitter. The magic is in the circularely polarized antennas. I'm sorry if my information given was misunderstood.
Markus
Old Apr 11, 2011, 11:15 AM
mitsudriver274 is offline
Find More Posts by mitsudriver274
Joined Jul 2009
What reciever did you use markus?
mitsudriver274 is offline Find More Posts by mitsudriver274
Old Apr 11, 2011, 11:20 AM
Registered FPVer :)
Joined Aug 2006
The stock reciver, RC 305 as it's available on many places.
Markus
Old Apr 11, 2011, 11:24 AM
ysb is offline
ysb
Find More Posts by ysb
ysb
use the force..or a quadcopter
ysb's Avatar
quebec
Joined Dec 2010
the best is not the contrary ?
custom Cloverleaf 5.8Ghz omnidirectional cicular polarized antenna on RX (receiver) instead of tx
- custom Skew Planar Wheel 5.8Ghz omnidirectional cicular polarized antenna on TX (transmetter) instead of rx
ysb is offline Find More Posts by ysb
Old Apr 11, 2011, 11:44 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That will work fine. The skew wheel and cloverleaf are more or less interchangeable. however the Skew wheel has better multipath rejection and the cloverleaf just seems to do a little better as a TX antenna than the skew wheel.
-Alex
Old Apr 11, 2011, 01:26 PM
Registered FPVer :)
Joined Aug 2006
That said, the cloverleaf is a superior antenna to TRANSMIT, where as the skew planar wheel is really good on reciveing.
Note, english is not my native language, maybe that's why. Could you clarify what your point is?
Markus
Old Apr 11, 2011, 01:47 PM
ysb is offline
ysb
ysb
ysb's Avatar
quebec
Joined Dec 2010
sorry .. in my mind, I thought it was the opposite ..
Old Apr 11, 2011, 01:51 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Crazy you got so far, I cant even get 1/5 that distance with my CP antennas.
airbagit13 is offline Find More Posts by airbagit13
Old Apr 11, 2011, 01:57 PM
Registered FPVer :)
Joined Aug 2006
What frequency? Did you make them yourself?
Are you using this tx/rx?
http://www.himodel.com/electric/FPV_...ng_System.html
(note, this set is available in many places, above store is only for reference, I do not endorse it specially nore am I in any ways related)
If in doubth about your antennas, I could make you a pair. I'm sure you can duplicate my experience.
Markus
Old Apr 11, 2011, 02:07 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It's all about the RF environment. I did 2.5km on mine on 1.3GHz, no problems. 900MHz gets hammered by cell phones and towers which can significantly reduce your range.
-Alex
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
Discussion Advantage of a Circular Polarized Patch Ant? Mach61 FPV Talk 2 May 01, 2009 10:53 PM
