| Thread Tools |
| This thread is privately moderated by Super D, who may elect to delete unwanted replies. |
E-Flite Park 480 & E-flite 40 Amp Brushless ESC Combo
Hello
I have a E-Flite Park 480 & E-flite 40 Amp Brushless ESC Combo For Sale! This motor and esc combo has less than 10 flights on it in a PA Katana Mini. I am thining out the fleet and this needs to go! This motor runs great no bent shafts, cut wires, ect. $59 Paypal & Shipped To Your Door! Here are the specs! MOTOR SPECS Type: Brushless outrunner Size: Park flyer Bearings or Bushings: One 4 x 9 x 4mm Bearing, and One 4 x 10 x 4mm Bearing Wire Gauge: 16 Recommended Prop Range: 10x7 to 12x6 Voltage: 7.2 to 12 RPM/Volt (Kv): 1020 Resistance (Ri): .06 ohms Idle Current (Io): 1.10A @ 8V Continuous Current: 22A Maximum Burst Current: 28A (15 sec) Cells: 6–10 Ni-Cd/Ni-MH or 2–3S Li-Po Speed Control: 25A to 40A brushless Weight: 87 g (3.1 oz) Overall Diameter: 35mm (1.40 in) Shaft Diameter: 4mm (.16 in) Overall Length: 33mm (1.30 in) ESC SPECS Brake: Yes, programmable Continuous Maximum Current: 40A Input Voltage: 7.2–14.4V Ni-Cd/Ni-MH or 7.4–11.1V LiPo battery Length: 2 in (50mm) Width: 1 in (26mm) Height: 0.4 in (10mm) Weight: 0.7 oz (20g) BEC Voltage: Dual BEC circuits Auto Cutoff: Yes, programmable Picture Time! ![]() ![]() ![]() ![]() ![]() ![]() Thanks for looking! If you want it please post "I'll Take It" and send paypal to dennis.harless@meritagehomes.com Thanks again, Dennis |
| Thread Tools | |
| Discussion E flite park 480 what prop size? | malcolxl | Power Systems | 3 | Apr 09, 2011 09:10 AM |
| Sold E-Flite Park 480 Motor | tinker31 | Aircraft - Electric - Power Systems (FS/W) | 2 | Mar 12, 2011 06:38 PM |
| Sold E-Flite Park 480 910KV | tinker31 | Aircraft - Electric - Power Systems (FS/W) | 0 | Mar 12, 2011 02:36 PM |
| For Sale Mini FuntanaX with (or without) Park 480 and E-Flite 40 Amp ESC | sdueck | Aircraft - Electric - Airplanes (FS/W) | 3 | Nov 22, 2009 11:04 AM |
| Sold E-Flite Park 480, 40-Amp Pro ESC, S75 Servos | MikeATL | Aircraft - Electric - Power Systems (FS/W) | 6 | Jun 23, 2008 07:52 PM |
