Old Apr 08, 2011, 09:50 AM
Flyboy Steve is offline
Find More Posts by Flyboy Steve
Joined Nov 2007
Question
Delta Wing Craft: Nose or Mid Motor?
I've seen basically two types of Delta Wing craft in these forums: Motor in the nose and motor mounted in the middle, near the CG.
Now, with a nose motor, one has to put the Lipo near the tail for balance.
For a mid mount, the motor and the Lipo are both closer to the CG of the plane.
Any advantages to one design over the other? Better to keep to large masses close together, or farther apart?
Thanks!
Flyboy Steve is offline Find More Posts by Flyboy Steve
Old Apr 08, 2011, 03:07 PM
foamflyer is offline
Find More Posts by foamflyer
Trapped in California
foamflyer's Avatar
United States, CA, Arcadia
Joined Nov 2003
In my opinion, motor in the middle is best. I've built a number of foamboard deltas this way and they perform superbly. I like to keep as much as possible near the CG, and position the battery wherever it needs to be for correct balance.
foamflyer is offline Find More Posts by foamflyer
Old Apr 08, 2011, 03:32 PM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
Nose is best if you want to prop hang. Keep the battery near cg and move servos etc to the rear so you can use different size batteries without too much issue. Mid motors protect props, but are generally too loud for my taste. The simple delta by dekan is a superb design!
tymbrewolf is offline Find More Posts by tymbrewolf
Old Apr 08, 2011, 04:29 PM
Joined Nov 2007
Are the front motor planes that much quieter?
Do you have a link for the dekan design?
Thanks!
Old Apr 08, 2011, 06:45 PM
Joined Feb 2007
Simple delta. http://www.rcgroups.com/forums/showt...t=simple+delta
I set up my phone decibel meter but forgot and had the mic upside down on the cabinet.
Here are similar motors both 8x4's but the prop in slot is a sf prop.
Other vids of these planes on youtube can here a difference too.
Prop in slot vs tractor noise (2 min 16 sec)
Zaurak3 is offline
Find More Posts by Zaurak3
Gravity-Compliant User
Zaurak3's Avatar
Nebraska USA
Joined Mar 2008
My preference is the tractor (nose) configuration. Quieter since the prop is being fed with undisturbed air. With my Komet design in my avatar, the battery sits right on the CG - a good thing because you can put any size battery in the same place without disturbing the CG. The Komet is not a pure delta, but it can be done with deltas as well. On the negative side, it puts the prop in a vulnerable position.
Another choice is placing the motor fully aft in a pusher configuration. Speed-wise, a tractor or a pusher is a better choice than an mid mount, at least in my experience.
Zaurak3 is offline Find More Posts by Zaurak3
Old Apr 08, 2011, 07:10 PM
Joined Feb 2007
Tailess is always cool. I like my xp-39
Tailless XP-39 maiden flight (1 min 20 sec)
Old Apr 08, 2011, 07:21 PM
inline300 is offline
Find More Posts by inline300
Joined Jan 2009
I like mid due to the tractor style just looks weird.
I made some quick and easy prop in a slot style triangles that would hover in mid air at about 30-45 degree nose up, you could turn it either direction you wanted, 180~360 or whatever, then just fly off, its the first video in the following link. Something to see in person. And the build is ridiculously simple.
http://www.rcgroups.com/forums/showthread.php?t=1123782
inline300 is offline Find More Posts by inline300
Old Apr 08, 2011, 09:59 PM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Here's my 8 yr old Pogo. Finally put her to rest about a week ago. Died of old age. It would hover hands off with a rearward CG. Sweet flier. Made a new smaller one.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Apr 09, 2011, 12:00 AM
Joined Feb 2007
If you want delta, tractor, very easy, indestructible and RET, I would humbly submit the best RET Delta on the planet.
6mm EPP Bullseye Delta.wmv (5 min 38 sec)
Old Apr 09, 2011, 07:26 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it Ò>
leadfeather's Avatar
Joined May 2006
The FireFly is a great indoor/outdoor prop in slot delta. Very rugged, versatile and easy to build.
The 3D Delta is the most aerobatic delta. Highly maneuverable, hands off hovering yet very pitch stable at high speed. It also shows that a tractor delta can look good.
3D Delta, test flying (3 min 50 sec)
leadfeather is offline Find More Posts by leadfeather
Old Apr 09, 2011, 07:54 AM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Well , since we're posting Delta videos ....
A-12 movie.mov (5 min 30 sec)
Here's Gene Bond and I trying out the 48" A-12 with BW motor in the slot ...
The Prop in the slot IS pretty Noisy ... and since deltas usually balance somewhere in the middle ... the question becomes whether you want to prop hang or not ... But one more consideration , the PITS configuration Does seem to offer more prop protection ...
gpw is online now Find More Posts by gpw
Old Apr 09, 2011, 11:57 AM
Joined Feb 2007
It is funny how the clean air is quiet. You can really notice the difference in the turns. The only real way to truly be happy its some of each.
Old Apr 09, 2011, 04:51 PM
yolomojo is offline
Find More Posts by yolomojo
complet beginer
canada
Joined Aug 2010
depends what you want and how good your servos are. but with it at the front and vary back you cant do thrust vectoring. or alot harder when its not in the middle. at the rear if your batery or esc ect. falls of (i use velcro so this is a problem for me but for others maby not depending how you build your plane but valcro is strictly easyer to build) its cought in the shreder (propeller).
yolomojo is offline Find More Posts by yolomojo
Old Apr 09, 2011, 05:16 PM
Joined Feb 2007
Here is an example of voting for the simple delta and why a tractor is cool. Goldguy I believe is on the sticks in this video.
Sold *DELTA WING* Vintage Global Models Cutlass 45 $125.00 FREE SHIPPING! stevster Aircraft - Fuel - Airplanes (FS/W) 3 May 02, 2011 03:35 AM
Question Indestructible mid-wing 3D trainer not UM? demuddy Beginner Training Area (Aircraft-Electric) 11 Apr 10, 2011 12:43 AM
Delta Wing with wide nose dst Flying Wings 9 Aug 30, 2005 06:55 PM
High-wing, mid-wing or low-wing? e-geezer Modeling Science 3 Oct 22, 2003 12:26 PM
Question Delta mid motor cut-out shape? hardlock Modeling Science 12 Aug 27, 2003 03:43 PM
