Old Apr 07, 2011, 11:29 PM
Pat Lynch is offline
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
Build Log
Peter Rake Albatros DXI in 1/6 scale
I made this thread a 'discussion' and it may remain so for quite a while...at least 'til my Morane AI is completed
It was not my intention to build another of Peter's models for a while but had been poring over pictures and Datafiles looking for a type that had masses of info available and then saw that Pete had the rather pugnacious Albatros DXI up for grabs - an aircraft for which there is almost NO data available! I'd never done a lozenge camo scheme before, and encouraged by Hammerd's results (who isn't) decided that a simple DXI build would make an ideal step before tackling the next big 'un later on. Pete is still designing that beastie for me
The Albatros DXI is about as far removed from it's sleek, sexy predecessors (DVa etc) as it could be but has a certain ugly-duck charm and will be infinitely easier to build with a square fuselage and round engine.
Only two prototypes were built serial 2208 and 2209. Both differed - one had a four bladed prop and balanced ailerons, the other was two bladed and normal Albatros ailerons. One was varnished wood fuselage and the other mauve and green camouflage. Both had Lozenge pattern wings.
I have a grand total of 4 useful photos - 3 of one machine and 1 of the other. While Pete's model physically depicts the two blade, varnished wood version, I'm sure no one would complain if the other colours were used!
Pat
Pat Lynch is offline Find More Posts by Pat Lynch
Old Apr 07, 2011, 11:41 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
DXI - the model..
This model is stubby little beast although at 1/6 scale is not that tiny. With a span of about 52" (1350 cm) and a length of only 34" (860mm), the DXI model stands over 18" (450) tall! The long legs needed to swing the big prop.
The model looks to be rather simple to build with no wire rigging and a rather old-fashioned fuselage construction - square with a rounded deck. The wings are entirely conventional the top being supported at the centre by two bipods. The outer struts are of solid 1/8 ply with two diagonal struts from fuselage to lower wing each side.
I am thinking of about a 4 - 4.5 lb model - probably similar to the Rake 54" SE5a. My only concern being how difficult will such a stubby little airframe be to fly?
Pat
Old Apr 07, 2011, 11:46 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
DXI - the real thing....
These are the only decent DXI photos I have.....probably a blessing as one might be tempted to keep it '..as per plan....' Well, I'll try
Any further info from anyone will be welcome - I think Baldguy asked some time back but apart from references to the Windsock Albatros experimental book (which I cant find), there seems to be very little data - and I've spent a lot of time looking on the 'net as well as my book collection.
Pat
Old Apr 08, 2011, 12:12 AM
Modelholic is offline
Find More Posts by Modelholic
Modelholic's Avatar
Perth WA
Joined Feb 2007
Good luck - subscribed. Hope you don't get too side tracked from the MS, that one is so close to completion and we want to see it fly!
Modelholic is offline Find More Posts by Modelholic
Old Apr 08, 2011, 12:33 AM
MerlinV is offline
Find More Posts by MerlinV
Melbourne, Australia
Joined Mar 2009
What an... interesting subject.
Should be an intriguing build to follow.
Hugh
MerlinV is offline Find More Posts by MerlinV
Old Apr 08, 2011, 06:18 AM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
definately an odd ball Pat, i should imagine it will be rather pitchy to fly with such a short fuselage, thank god for modern radio gear and expo! you might need to start preping your dodgy old club field now i can see takeoff and landing being reeeeal exciting will be interesting to see your go with lozenge, nothing against hammerd's masterpieces but your builds seem very practical with regard to tooling and method, as against Hammerd's dream world workshop if ya know what i mean, more something that i can realisticly aspire to attempt (and i do mean attemp) myself.
Craig
trumps is offline Find More Posts by trumps
Old Apr 08, 2011, 07:05 AM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Pat,
Don't let me stop you mate. If you want the balanced ailerons, go for it.
Actually, on the subject of moments, although it's a lot more span, the nose and tail moments, taken from the bottom wing position, are pretty close to to those on the Powell Racer. From the balance point, the DXI actually has the longer tail moment by almost 3". Nose length, of course, is a different matter entirely.
It isn't until you compare size for size that you really see how short the DXI is. All good fun though.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Apr 08, 2011, 07:18 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Tail moment is an interesting thing. I was always afraid of a plane with a short tail because of the thoughts of ground loops and twitchy behaviour.
For some reason I built Pete's 36" Camel. That was one of the most well behaved planes I have ever flown (unless you put over 100W/lb on it ). It would fly hands off for quite a while. I would practice with it, flying complete circuits with just the left hand (rudder and throttle). Yep, even landings were done on rudder and throttle alone. The elevator was no more sensitive than any other plane once the throws were set up correctly (enough to flare for a landing and make nice round loops). I don't use exponential either.
High rates did make it more aerobatic, and, more sensitive, but, also not very scale. 4 big ailerons will make it roll at 360 a second if you want and the big elevator can make it loop almost in it's own length.
So, just set it up the way you want to fly and ignore how short the tail is.
After that I don't bother thinking about short tails.
charlie
PS if short tails were that scary then why can a flying wing be so docile to fly?
portablevcb is offline Find More Posts by portablevcb
Old Apr 08, 2011, 07:46 AM
baldguy is online now
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
Data Files has a little book that claims to have the DXI in it. Never ordered and haven't been able to get around to starting the DXI I got from Charlie yet. I am gong to do the stained wood version though, and try to learn from Hammereds thread too.
baldguy is online now Find More Posts by baldguy
Old Apr 08, 2011, 09:29 AM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Interesting how towards the end of the war, the major German manufacturers all developed short fuselage, big nosed designs. The Siemens Shuckert D.III , Pfalz D.VII/V.III, and this odd ball Albatros. An interesting project for sure. I'm sure you will do your usual fantastic job!
Wolpertinger is offline Find More Posts by Wolpertinger
Old Apr 08, 2011, 11:03 AM
Buzzkill2 is offline
Find More Posts by Buzzkill2
Buzzkill2's Avatar
United States, MI, Grand Blanc
Joined Mar 2007
Great subject. Subscribed!
Buzzkill2 is offline Find More Posts by Buzzkill2
Old Apr 08, 2011, 01:12 PM
BaZsiX is offline
Find More Posts by BaZsiX
Homo Modelicus
BaZsiX's Avatar
Hungary
Joined Jan 2005
Great subject, subscribed too.
BaZsiX is offline Find More Posts by BaZsiX
Old Apr 08, 2011, 02:56 PM
hammerd is offline
Find More Posts by hammerd
Las Vegas, NV
Joined Mar 2008
She is spunky looking.
hammerd is offline Find More Posts by hammerd
Old Apr 08, 2011, 05:36 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Originally Posted by PETERRAKE View Post
Pat,
Pete
Thanks Pete - I may do that. If the side photo of the balanced version is looked at closely, the upper tip profile looks a bit strange - maybe to acommodate the balance horns....unless my eyes deceive me, the undercamber seems to be missing!
Pat
Old Apr 08, 2011, 06:29 PM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Pat, I think it looks a little strange because it is drooping. Look at the far end of the aileron and also at the aileron on the opposite wing and you will see that they are deflected for a right bank. Accounting for the droop, it looks to me like the aileron would line up with the wing tip fairly well if it wasn't deflected.
Larry
Lnagel is online now Find More Posts by Lnagel
Build Log A Prototype Albatros DII by Peter Rake Pat Lynch Scale Kit/Scratch Built 447 Mar 09, 2016 06:10 PM
Build Log Peter Rake 1/6 Scale Albatros DVa hammerd Scale Kit/Scratch Built 914 Dec 29, 2014 05:04 PM
Build Log Peter Rake 67" Bristol F2b build trumps Scale Kit/Scratch Built 97 Feb 29, 2012 08:16 AM
Discussion Peter Rake's Udet Flamingo ben199 Scale Kit/Scratch Built 139 Jun 05, 2011 05:04 AM
