This thread is privately moderated by Sandancer, who may elect to delete unwanted replies.
Old Apr 07, 2011, 10:23 PM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Build Log
Starmax 63" P-51 "Gunfighter": The Radiator Vent Door
One of the features I liked about the Starmax was the Radiator Vent Door, so I set out to see what it would take to make mine functional.
Starmax Gunfighter_Radiator Vent Door.mov (2 min 2 sec)
The first thing I need to address was alignment of the linkage. I wasn't crazy about trying to run linkage from a servo mounted on the tray down to where I planned to mount the horn on the vent door, so I designed my own dropped & channeled servo tray out of some 1/16" plastic. I first cut the hole for the HXT 900 9g servo, and then took the hot air gun and started forming the tray. Once I got the dimensions and depth I wanted for the hole between the rudder and elevator mounts, I dropped the entire assembly down in there, and had a much better alignment for the linkage.
The door, on the other hand, was a bit more difficult. Because it fit so tight in the bay opening, I knew I would have to remove it so I could clearance it so it would swing clear and not bind the servo. To get the door out I had to cut the foam swivel hinges on the sides. I used a piece of FMS fiberglass spar material for the new hinge rod, and anchored it with two 1/2 x 1/2 square tubing plugs on both sides. I drilled the square centers of the plugs out to accept the round spar, and fit them to the side of the fuse. I epoxied one of those larger aluminum 30mm tall control horns to the door so I would have enough room for the linkage to clear the pivot spar.
NOTE:
I finally got a perfect match for the Gunfighter green. I mixed 1:1 Testors MM Medium Green #FS34102 with MM Olive Drab #FS34087 and it proved to be a perfect match. When applied with an airbrush it goes on flat, so to achieve the same sheen as the factory finish, I sprayed a coat of Krylon Crystal Clear Satin over it.
Sandancer is offline Find More Posts by Sandancer
Old Apr 26, 2011, 04:32 PM
flmlm is offline
Find More Posts by flmlm
flmlm's Avatar
Holly Hill, Fl.
Joined Mar 2005
Sweet!
Gary
Really like the operating door...well done!
Regards
flmlm is offline Find More Posts by flmlm
