This thread is privately moderated by Jeff Keith, who may elect to delete unwanted replies.
Old Apr 07, 2011, 11:40 AM
Jeff Keith is offline
Find More Posts by Jeff Keith
Wingman Jeff
Ohio
Joined Dec 2007
Airfield B-25 from Nitroplanes
Airfield B-25 from Nitroplanes,
Right out of the box this Beauty was pre-decorated complete with front , side, rear gunners, pilot and co pilot figures.
Wiring is not difficult at all becasue all wire ends are marked and labeled clearly .
Pre-installed servos, retractable landing gear, motors, ESC's and even the landing lights are all done for you.
Once assembled only the marked wires need to be plugged into the RX and it is ready to go !
Assembly is fast and easy too. Only the main wing halves need secured into the fuselage and the twin rudders and elevator assembly need glued together and the plane is built. All linkages are pre-installed for convenience.
Besides Beautiful scale looks, the engines on this Bomber counter rotate giving the Aircraft an awesome look even at low rpms with yellow decals on the tips of the 3 bladed props flashing brightly. .
Channels :
1- ailerons
2-elevator
3-throttle
4- nose steering / rudder
5- retractable landing gear
6- landing lights
Jeff Keith is offline Find More Posts by Jeff Keith
Discussion Airfield 1400 mm Corsair from Nitroplanes Jeff Keith Nitro Planes 0 Apr 05, 2011 01:50 PM
