Old Apr 10, 2012, 12:09 AM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
by then I should be able to offer a full review of the PTE engine I'm putting on mine. It ends up being a little cheaper if you want the pitts muffler and as I have already said... MO POWWAH !
3DNater is offline Find More Posts by 3DNater
Old Apr 14, 2012, 12:59 PM
FLYING-HIGH is offline
Find More Posts by FLYING-HIGH
Joined May 2005
are you guy's putting your rudder servo in the tail?
and what spinner do you use?
and is 166 .oz in enough torque for the slick?
FLYING-HIGH is offline Find More Posts by FLYING-HIGH
Old Apr 14, 2012, 01:12 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
servo in the tail... I'm told it would be tough to balance otherwise. I'd say 166 is a little weak. The minimum rating I can find is the hs 985mg which has 172 oz/in. You may be ok but your servo setup is going to have to be perfect and you might have to sacrifice some throw to avoid blowback.
Old Apr 14, 2012, 01:45 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I use this servo for my rudder and i don't worry about any blow back.
I don't like there rubber grommets though and recommend changing them
http://www.giantmodelproducts.com/in...roducts_id=211
kerwin50 is offline Find More Posts by kerwin50
Old Apr 14, 2012, 02:15 PM
Joined May 2005
well if you think that is weak .what do you think about the
power hd 1214th it is194 .oz .14sec at 6.0v
would this be considered a slow servo?
Old Apr 14, 2012, 02:26 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
The 1214th servo is really fast. Incidentally it's what I'm using but on unregulated 2s life. It is an HV servo. Mine are already installed but I don't have any flights on them yet. It was a good value at about $35/servo each shipped from hobbyking. I haven't inspected them in person yet since my buddy is building the plane and lives 4 hours away. He says they are killer and he generally usually only uses high dollar hitec servos in all his stuff. Center well and lots of speed and torque.
Old Apr 14, 2012, 02:28 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Kerwin that servo isn't even going to center by the time I'm pushing it the other way in my rollers Need something 2x that speed IMO.
Old Apr 14, 2012, 02:58 PM
Joined May 2005
i have not seen any bad reports on the 1214th
Old Apr 14, 2012, 03:32 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Nate thats a great find on those servos if they center. Please let me know how they work out I may just have to put them in my plane, though I don't know if I need anything that fast.
Old Apr 15, 2012, 10:56 AM
flyracer is offline
Find More Posts by flyracer
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
in hind sight, I should have gone with HS7955TG servos in my 71" Slick....
flyracer is offline Find More Posts by flyracer
Old Apr 15, 2012, 11:08 AM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
which ones did you end up using?
Old Apr 15, 2012, 03:10 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
I used Futaba S3051HV servos all the way around.... 146oz of torque @ 7.4v..
Old Apr 15, 2012, 03:48 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
oh ya I can see how that would be a little on the weak side.
Old Apr 15, 2012, 04:43 PM
lugnutz is offline
Find More Posts by lugnutz
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
i am using spectrum H6040 on both of my slicks ,one gas and one electric with no issues at all
lugnutz is offline Find More Posts by lugnutz
Old Apr 16, 2012, 08:35 AM
CRFan1 is offline
Find More Posts by CRFan1
Northwest Indiana
Joined Feb 2011
I am using HS 5645's running on a an A123 straight into the Rx and I have zero issues......it will easily do a knife edge loop, hehe I should have put a faster servo in it but after flying it, it is not a problem at all.
CRFan1 is offline Find More Posts by CRFan1
Discussion 71" AJ Slick Gas - First time with gas Hewey19 Fuel Plane Talk 7 Sep 06, 2011 03:53 PM
Sold 3dhs 71" aj slick - nib 6L6Amp Aircraft - Electric - Airplanes (FS/W) 4 Apr 05, 2011 11:09 AM
Discussion I'm torn, 71 slick or 72 sc? KillerCut 3D Flying 9 Mar 25, 2011 06:20 PM
Discussion 3DHS 42"Slick Side Force Generators bigtexas 3D Flying 3 Mar 03, 2011 12:42 PM
Wanted 3DHS 70" Slick Gas parts!!! helifryer Aircraft - Fuel - Airplanes (FS/W) 0 Feb 20, 2011 07:47 AM
