Old Oct 26, 2012, 09:25 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
also get rid of that mechanical stop.
kerwin50 is offline Find More Posts by kerwin50
Old Oct 26, 2012, 09:37 AM
RC_Feen is offline
Find More Posts by RC_Feen
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
I'll have to look if I can do that on the OS GT33.
RC_Feen is offline Find More Posts by RC_Feen
Old Oct 26, 2012, 02:04 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
get rid of the mechanical stop on the throttle? why?
going4speed is offline Find More Posts by going4speed
Old Oct 26, 2012, 02:11 PM
RC_Feen is offline
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Yeah...doesn't make sense to me. It's there for a reason.
Old Oct 26, 2012, 02:42 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
your stop should always be the servo and never mechanical. Even though the throttle stop screw is on nitro as well. It's always been a no no to use them. The servo should always be allowed to fully close the butterfly.
Old Oct 26, 2012, 02:57 PM
3DHS 'native'
USA, TX, Spring
oh absolutely I agree. I thought y'all were talking about removing the full throttle stop and could not think of one good reason to do that.
Old Oct 30, 2012, 10:50 AM
RC_Feen is offline
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Originally Posted by gregory.da View Post
I found this this last year after struggling with my setup, it has a good diagram on the proper way to set up your throttle linkage for gas engines. Hope it helps! DG
This is a bad drawling but you'll get the idea. In red is how I currently have my throttle linkage setup and having problems getting the endpoints set. What I'm thinking is I need to make my throttle linkage longer and set it up like the blue drawling to get the correct endpoints based on throttle stick position. Does this look or seem right?
Old Oct 30, 2012, 01:19 PM
Hewey19 is offline
Find More Posts by Hewey19
Hewey19's Avatar
USA, MI, Lansing
Joined Aug 2009
Yes RC_Feen the blue drawing how you should set up the linkage. I'm not sure about your endpoints but a setup like that will give you the nice throttle curve that you need on gas engines.
Hewey19 is offline Find More Posts by Hewey19
Old Oct 30, 2012, 01:36 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Yes the blue is what you need. Set your EPA's to max 1st then make your linkage. Then reset your epa's after that.
Old Oct 30, 2012, 02:56 PM
RC_Feen is offline
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Great! Now I'm onto something. I'll make a new linkage tonight and hopefully test it out later this week. Probably won't get to maiden is week because Sandy pretty much flooded our field.
Old Oct 31, 2012, 12:06 AM
flyracer is offline
Find More Posts by flyracer
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
have you seen Losifanatic's video where he's flying in a culdesac hand launching and catching his Slick?
flyracer is offline Find More Posts by flyracer
Old Oct 31, 2012, 01:06 AM
RC_Feen is offline
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Yeah I think....but he's running electric right? I'm running gas! Would be kind of krazy trying to try to catch a gasser unless I've missed that vid.
Old Oct 31, 2012, 10:39 AM
3DNater is online now
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
I'm not gonna lie... I'm way too scared of a 4+ HP motor turning a 20" prop to try catching mine.
3DNater is online now Find More Posts by 3DNater
Old Oct 31, 2012, 12:26 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
No Nate your not scared, your wise.
Old Nov 02, 2012, 12:04 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
hahahah.... I'll be honest, I don't have the guts to try and tail catch a 30cc sized airframe out of the air!
Discussion 71" AJ Slick Gas - First time with gas Hewey19 Fuel Plane Talk 7 Sep 06, 2011 04:53 PM
Sold 3dhs 71" aj slick - nib 6L6Amp Aircraft - Electric - Airplanes (FS/W) 4 Apr 05, 2011 12:09 PM
Discussion I'm torn, 71 slick or 72 sc? KillerCut 3D Flying 9 Mar 25, 2011 07:20 PM
Discussion 3DHS 42"Slick Side Force Generators bigtexas 3D Flying 3 Mar 03, 2011 01:42 PM
Wanted 3DHS 70" Slick Gas parts!!! helifryer Aircraft - Fuel - Airplanes (FS/W) 0 Feb 20, 2011 08:47 AM
