Old Sep 26, 2012, 02:57 AM
RC_Feen is offline
Find More Posts by RC_Feen
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
brathanke..PM sent. Thanks!
RC_Feen is offline Find More Posts by RC_Feen
Old Sep 26, 2012, 06:32 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
I dont know I have heard people running the os gt33 on an eight ounce getting 6 minutes so who knows.
Originally Posted by brathanke View Post
Yes I have the PTE. I am guessing it would be a little more thirsty than the OS based on it's higher displacement.
going4speed is offline Find More Posts by going4speed
Old Sep 26, 2012, 08:00 PM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
I'm using a fiji water bottle which is right around 16oz. I have been doing 10 minute flights and I don't think I have gone through half a tank yet. Now I am running a 18x8 break in prop so I'll see how it goes when I step up to a Vess 19B.
There is a smaller fiji tank that is around 12oz that could be a compromise.
Since my Velox met her demise I might use this in the 71 to save weight.
Enterprise7 is offline Find More Posts by Enterprise7
Old Sep 26, 2012, 08:53 PM
RC_Feen is offline
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
The 330ml Fiji bottle is equal to 11.158oz.
Old Sep 26, 2012, 08:56 PM
USA, NH, Manchester
Joined Jun 2010
That is the one I had in the Velox. On the Mintor 22 it was in excess of 25 minutes of flight time.
Old Sep 26, 2012, 10:04 PM
3DNater is online now
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
the 500 ml bottle is 16.9 oz. I was using it at first but didn't like the extra weight. I flew 15 min flights with half a tank left on that tank.
3DNater is online now Find More Posts by 3DNater
Old Oct 05, 2012, 01:15 AM
RC_Feen is offline
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Throttle Radio setup question
Setting up the throttle end points on my DX7. When setting up the throttle end points do you set the low point to 0 and the high end (full throttle) to whatever % that will drive the throttle arm to the mechanical end-stop? First time setting up the throttle in my radio for a gasser. Thanks!
Old Oct 05, 2012, 01:38 AM
3d NOOBular
3DNater's Avatar
Joined Aug 2010
RC_Feen here is my opinion on your question.
Yes you want both ends to be set where they are effective at capturing the entire relevant range of throttle for your engine. I like to leave some room for trimming the throttle on the low end so keep that in mind. High end should be at the max mechanical throw possible without binding the servo.
Old Oct 05, 2012, 02:08 AM
RC_Feen is offline
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Yes...I want to be able to use the throttle trim to kill the motor if I need to even though I have a Sparks switch to kill the engine from the gear channel. On my DX7 right now I have my "travel adjust" for the throttle at H=111% L=5%. One thing I noticed that when I move the throttle...the throttle servo/linkage is not linear to the Rx throttle input. It's like at 50% on the Rx the throttle linkage for the engine barely moves at all. Does this seem right? My goal is to get this baby fire up before Sunday...Thanks all!
Old Oct 05, 2012, 09:40 AM
3d NOOBular
3DNater's Avatar
Joined Aug 2010
I am no expert on throttle linkage but it sounds like you might need to work on the geometry of your linkage a little. I hope someone else will chime in soon but my concern is that the engine power is also non-linear even if your input was. The low end gives a lot less power than the top end. If you are having hardly any throttle movement in the first 50% of the travel then you could be compounding the issue. You might end up flying with only the top half of your stick and it will be super sensitive.
Someone let me know if I am off-base with my analysis. Part of the reason I'm responding to this is just to learn it better myself so please speak up
Old Oct 05, 2012, 10:02 AM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
I found this this last year after struggling with my setup, it has a good diagram on the proper way to set up your throttle linkage for gas engines. Hope it helps! DG
gregory.da is offline Find More Posts by gregory.da
Old Oct 06, 2012, 04:11 PM
RC_Feen is offline
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
SEF 94 and oil ratio
For those of you running the OS GT33, what ratio should you use for the break-in period? I read in the manual but don't understand which ratio for break-in and which ratio for normal operation! Also has anyone used SEF 94 fuel or the SEF 94 50:1 pre-mix? Thanks!
Old Oct 06, 2012, 05:19 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
Plus one on that Greg. for a gasser this is really needed
kerwin50 is offline Find More Posts by kerwin50
Old Oct 07, 2012, 12:09 PM
lb.man is offline
Find More Posts by lb.man
fly low be happy
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
My understanding of the manual is to use 25:1 for break in
and to use 30:1 for normal flight,
it is confusing when you read the manual and it says"Use a 25:1 fuel/oil mixture if the particular brand of oil states 50:1 mix set only the high speed needle 100-200 below max rpm.."
I am assuming that they mean use 25:1 for break in. and to double up your 50:1 premix to obtain a 25:1. And to set your high speed need on the fat side. But the key phrase was" use 25:1" so far 30 minutes in the air and no problems.
lb.man is offline Find More Posts by lb.man
Old Oct 07, 2012, 12:21 PM
RC_Feen is offline
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Thanks! I read and re-read the manual and it was just unclear to me.
Discussion 71" AJ Slick Gas - First time with gas Hewey19 Fuel Plane Talk 7 Sep 06, 2011 04:53 PM
Sold 3dhs 71" aj slick - nib 6L6Amp Aircraft - Electric - Airplanes (FS/W) 4 Apr 05, 2011 12:09 PM
Discussion I'm torn, 71 slick or 72 sc? KillerCut 3D Flying 9 Mar 25, 2011 07:20 PM
Discussion 3DHS 42"Slick Side Force Generators bigtexas 3D Flying 3 Mar 03, 2011 01:42 PM
Wanted 3DHS 70" Slick Gas parts!!! helifryer Aircraft - Fuel - Airplanes (FS/W) 0 Feb 20, 2011 08:47 AM
