The spot you circled is where I mounted my ignition. My throttle is on the other side of the motor on the PTE though.
Latest blog entry: Southern Utah Huckin!
This is what I should have done and I know we discussed it but I had already fuel proofed the front of the plane and did not want to epoxy on top of the other epoxy for fear of a bad bond.
![]() Quote:
Latest blog entry: smacked the beeeeg slick
I may have to move the throttle servo but I am going to be installing the tail servos this weekend and get some gas in the tank to see what the final CG is..oh and I have a bigger battery coming which will mount behind the wing tube so that will help just a little.
I have a 1/2" x 2" balsa plate that is glued over the pull pull location and ends at the rear former at the back of the canopy. I have the ibec on the front over where the pull pull servo would go and the battery will be behind it. I have a 1100 mah A123 in there right now but I dont trust it will have enough azz so I ordered a fromeco 2300 Iron corp battery and badger yesterday.
Fromeco rocks by the way...called to change something...answered the phone and spent 10 minutes talking to me about my setup and what I needed. ![]() |
per 60 minutes i think you will be fine with the 2300 running both Rx and ign..... just do your duty and log Mah you put back in (IE one flight and charge, two flights then charge, three flights then charge... etc). the LiFe/A123 batterys drop off real fast if you discharge them too far. Personally I dont like discharging them too far past halfway. (better safe than sorry) Especially since they recharge so fast. |
Hyperion servos are back in stock at allerc.com and I just made their stock smaller. Got some Dubro #670 heavy duty servo arms as well. Just ordered a 18x8 and 19x8 ProTek prop from AMain as well. Both orders via USPS so maybe they will get here by Saturday.
I think that completes the shopping process (I really hate shopping, even when it is for cool stuff). Weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee! |
At first I ordered a life at 2600 mah and called back today to change to a 2300 lifeP04 because of the amp draw head room. I am going to run an ibec so it will run all off the same battery. It just seems like such an amp draw to have five big digital servos and an ibec for ignition.
Have you had any jitter issues out of the 7954's? Quote:
Throttle servo setup
Here is where I put my throttle servo and how I did it for the GT-33:
![]() ![]() ![]() Still need to drill a hole in the firewall and setup the linkage. This is the best position I found that would allow me to get to the servo. I made the plate from a 1/4 inch ply then epoxied it into the airframe. |
[QUOTE=going4speed;22395666
Have you had any jitter issues out of the 7954's?[/QUOTE] No.. they work perfectly .... i have them in all my planes and think they are a great bang for the buck high voltage servo.... they are super strong and not too slow on unregulated LiFe too. ![]() I dont know why some people talking about them getting slop but i have three planes using them for over a year and they are all just as tight as new . |
This Miracle switch is cool and looks beefy... Too bad it isn't a little easier to install!
I decided I didn't want this big of a switch right up at the front of the fuse and obnoxiously visible. It is a chunk of aluminum and it does weigh something, so I wanted to move it back. Under the wing would make it less visible. But there isn't anything flat back there to mount it to. I used card stock to cut out a template for some 1/8" ply that would fit between the frame of the fuse and glued it in there. Yea, it took some time. But I'm satisfied with the results. I wonder how hard it is going to be to get the fuel line to go back in. There isn't much clearance on the back side of the switch. Since I'm not using a canister muffler I might have to drill a hole and let the fuel fill line slide into the canister area. |
| Thread Tools | |
| Discussion 71" AJ Slick Gas - First time with gas | Hewey19 | Fuel Plane Talk | 7 | Sep 06, 2011 03:53 PM |
| Sold 3dhs 71" aj slick - nib | 6L6Amp | Aircraft - Electric - Airplanes (FS/W) | 4 | Apr 05, 2011 11:09 AM |
| Discussion I'm torn, 71 slick or 72 sc? | KillerCut | 3D Flying | 9 | Mar 25, 2011 06:20 PM |
| Discussion 3DHS 42"Slick Side Force Generators | bigtexas | 3D Flying | 3 | Mar 03, 2011 12:42 PM |
| Wanted 3DHS 70" Slick Gas parts!!! | helifryer | Aircraft - Fuel - Airplanes (FS/W) | 0 | Feb 20, 2011 07:47 AM |
