Espritmodel.com Heli Air
Old Oct 24, 2011, 11:14 AM
Northwest Indiana
Joined Feb 2011
Originally Posted by RC_Feen View Post
Thanks for the pic's SnowDog1974. Haven't made much progress with the build. Ordered and received this switch. Once I got it and inspected the switch it's quite large. I would have to cut a huge hole in the fuse to get it in there and re-enforce it with some ply. What switch fits in the already provided cut-outs for the switches? This one? I don't want to have to make too much of a modification to install the switch. Thanks!
I installed my switch into a piece of 3/6" balsa that I mounted inside the plane....
CRFan1 is offline Find More Posts by CRFan1
Old Oct 24, 2011, 01:22 PM
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
I like that idea but the only thing I don't like is having to open the canopy before and after flights to switch on/off.
RC_Feen is offline Find More Posts by RC_Feen
Old Oct 24, 2011, 02:00 PM
Northwest Indiana
Joined Feb 2011
Honestly, not a big deal at all and there is not a lot of wood to mount it anywhere else. It works. I don't need to open the canopy to kill the motor remember...thats the beauty of the optical kill...flip the gear switch and she stops.
Old Oct 24, 2011, 04:13 PM
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
My switch
Here is a picture of the PowerBox switch I have. Look at the size of this thing. I like the fact it has as led showing that the switch is one or off. No to crazy of the size and what I'll need to do to make it fit. What do you think? Stick with this one or just get the JR HD switch? I do want to mount it so you can access the switch from the outside of the plane.
Old Oct 25, 2011, 08:34 AM
Northwest Indiana
Joined Feb 2011
Yeah that switch is pretty big. If you are dead set on mounting it outside, than I would probably look at a smaller HD type of switch.
Old Oct 25, 2011, 11:46 AM
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Yeah....it is pretty big and pricey at $52. Has a nice charge port and charge adapter included. Not 100% sure its worth it based on the size of the switch and what I would need to do to mount it.....
Old Oct 25, 2011, 12:41 PM
Northwest Indiana
Joined Feb 2011
Can you maybe mount it in the turtledeck area?
Old Oct 25, 2011, 12:48 PM
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
What area is that?
Old Oct 25, 2011, 03:50 PM
Northwest Indiana
Joined Feb 2011
What area is that?
Behind the canopy...maybe just above the longeron where the fuse starts to curve....just a thought....
Old Oct 25, 2011, 06:12 PM
kerwin50's Avatar
winston mo
Joined Oct 2006
yeah that switch is alittle overkill
kerwin50 is offline Find More Posts by kerwin50
Old Oct 25, 2011, 08:18 PM
Northwest Indiana
Joined Feb 2011
Yeah, Kerwin is right, hehe...get a different switch if you can
Old Oct 26, 2011, 07:19 AM
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
I use a similar switch (but I think it is better) on my Su-26.
The Miracle switch is really nice:
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Oct 26, 2011, 08:25 AM
racerman27410's Avatar
United States, NC, Greensboro
Joined Dec 2006
Since i'm running an ignition pack and a flight pack i wanted a dual switch/fuel dot
i put my switch on the vertical and supported it on the backside with a piece of light ply.
racerman27410 is offline Find More Posts by racerman27410
Old Oct 26, 2011, 08:27 AM
Northwest Indiana
Joined Feb 2011
Hehe..that is even too big for the Slick...the problem is there is not much wood to mount it on! That's why I just mounted mine on a plate inside. Just less hassle.
Old Oct 26, 2011, 12:28 PM
Joined Jan 2009
I had nowhere to mount it either, so I just made a plate for it.
Discussion 71" AJ Slick Gas - First time with gas Hewey19 Fuel Plane Talk 7 Sep 06, 2011 03:53 PM
Sold 3dhs 71" aj slick - nib 6L6Amp Aircraft - Electric - Airplanes (FS/W) 4 Apr 05, 2011 11:09 AM
Discussion I'm torn, 71 slick or 72 sc? KillerCut 3D Flying 9 Mar 25, 2011 06:20 PM
Discussion 3DHS 42"Slick Side Force Generators bigtexas 3D Flying 3 Mar 03, 2011 12:42 PM
Wanted 3DHS 70" Slick Gas parts!!! helifryer Aircraft - Fuel - Airplanes (FS/W) 0 Feb 20, 2011 07:47 AM
