700 for the ignition and 2500 for the Rx would be plenty.... I like keeping the power supply for the ignition completely seperate and two packs gives you the option of moving the weight around for balancing purposes. I use less than a hundred Mah per flight on the ignition and around 200-400Mah on the reciever pack per 12 minute flight using 7954SH HV servos.... i very rarely fly more than 3 flights before charging as i prefer to keep the reserve high. the LiFe batterys do recharge pretty quick so i just use one set per plane. After three 12 minute+ back to back to back flights the short break to recharge the batterys is not a bother at all. Frank |
Sorry for the late response... its a straight allen head 10-32 2-1/4" bolt. I actually had some of these sitting around. This worked perfect on the 3" CF spinner. On the 3-1/2" CF spinner I will need to track down a 10-32 2-5/8" bolt. Flyracer |
That is a good problem to have...the storage thing...
I built mine on a fold out table. Just tape the tail wheel down so the plane does not roll off the back of the table every 11.2 seconds.
Latest blog entry: smacked the beeeeg slick
Great idea! My issue was when installing the motor and everything else in the fuse the tail kept rolling off the back so 2" masking tape later it was rock solid.
yea I think the Dubro Gas Stopper is $2 and a 6 foot section of yellow gas tubing is $8 to $10.
http://www.troybuiltmodels.com/items/FTGS.html http://www.troybuiltmodels.com/items/TUBGASR.html |
I think you will want more than the 8 oz tank.
Latest blog entry: Southern Utah Huckin!
| Thread Tools | |
| Discussion 71" AJ Slick Gas - First time with gas | Hewey19 | Fuel Plane Talk | 7 | Sep 06, 2011 03:53 PM |
| Sold 3dhs 71" aj slick - nib | 6L6Amp | Aircraft - Electric - Airplanes (FS/W) | 4 | Apr 05, 2011 11:09 AM |
| Discussion I'm torn, 71 slick or 72 sc? | KillerCut | 3D Flying | 9 | Mar 25, 2011 06:20 PM |
| Discussion 3DHS 42"Slick Side Force Generators | bigtexas | 3D Flying | 3 | Mar 03, 2011 12:42 PM |
| Wanted 3DHS 70" Slick Gas parts!!! | helifryer | Aircraft - Fuel - Airplanes (FS/W) | 0 | Feb 20, 2011 07:47 AM |
