Old May 05, 2012, 09:15 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
I'm not sure. I think my buddy just used the stopper that came with the stock tank. I'll ask him to make sure but I don't know anything about the Earns Super Stopper kit.
3DNater is offline Find More Posts by 3DNater
Old May 06, 2012, 12:04 AM
Army flyer is offline
Find More Posts by Army flyer
Joined Jun 2011
Finished converting my electric 71 to gas tonight. Picking up my motor this week. Should have it running by the first hopefully.
Army flyer is offline Find More Posts by Army flyer
Old May 06, 2012, 03:27 AM
kerwin50 is online now
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
now what motor are you using.
BTW flyracer what prop are you using for the OS
I hear they have an 8mm prop shaft and most large props have a 10 mm hole.
kerwin50 is online now Find More Posts by kerwin50
Old May 07, 2012, 11:16 AM
flyracer is offline
Find More Posts by flyracer
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
I am using the JXF brand 18x8 and 18x10 prop from value hobby.com. I didn't have to ream the main shaft hole.
Flyracer
flyracer is offline Find More Posts by flyracer
Old May 07, 2012, 11:19 AM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
Watch those black fuel stoppers! If there are not rated for gasoline they will fail
Flyracer
Old May 09, 2012, 05:36 PM
VENOMiTry is offline
Find More Posts by VENOMiTry
United States, MD, Glen Burnie
Joined Mar 2012
i went flying today and wow that plane flys amazing its so light and floats around great. only problem is that on my 5th flight my elevator became unglued and made it dive down quick but i trimmed it out to get it flying straight enough to land. wasnt till i landed i seen the problem but all of them except for 2 on the left came apart so i dont know how to get those out without breaking something? any suggestions? other than that the plane is insane in a good way
VENOMiTry is offline Find More Posts by VENOMiTry
Old May 09, 2012, 05:49 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
Venom
are you saying the robart hinges came out on the elevator/horizontal stabs? The pins broke?
Flyracer
Old May 09, 2012, 06:09 PM
Joined Mar 2012
Originally Posted by flyracer View Post
Venom
Flyracer
the pins are fine its just the glue didnt hold the hinges and i glued my joiner stick in with epoxy so thats held on really tight so even if i got the hinges out the stick is still holding the 2 halfs together
Old May 09, 2012, 06:17 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
Can't you just glue the robart ends back into the elevator or horizontal stabs? Also, it's a good idea to seal your hinge line with dubro/blendaderm tape.... the tape seal air blow by and offers some help if hinges come loose.
Old May 09, 2012, 06:42 PM
Joined Mar 2012
i could glue the 3 on the right half that need it but i got 1 on the left half that needs glue but it would be hard to get glue in the hole without getting it on the pin so i kinda need to get both halfs apart and i dont know how to get the 2 that are glued apart without braking something inside the horizontal stab
Old May 09, 2012, 08:40 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
put alittle petroleum jelly on the pin area... the glue won't stick to the jelly. So if you get alittle glue squeezing out, you can wipe it away with out gluing the pin and joint.
Old May 10, 2012, 09:11 AM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
Try putting some oil or petroleum jelly on the hinge itself and get a syringe and try injecting some glue in. Otherwise, use a dremel cut-off blade to cut the two good hinges off, then you can drill new holes beside them and glue in new hinges. A lot of 3dhs guys use gorilla glue, but I still like to use epoxy. Good luck, and nice save on getting the Slick back down safely! DG
gregory.da is offline Find More Posts by gregory.da
Old May 10, 2012, 12:40 PM
Joined Mar 2012
yea i got it fixed by just injecting some glue in the hole and used petroleum jelly so no glue got in the hinge but so far it seems like its holding but wont know for sure till i fly saturday.
Old May 10, 2012, 12:44 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
good luck!
Old May 10, 2012, 08:03 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
Venom
Go back through and tape the hinge line with blendadern. Put the control surface in full deflection and hold it there while you apply the tape to seal the hinge line.
Flyracer
Discussion 71" AJ Slick Gas - First time with gas Hewey19 Fuel Plane Talk 7 Sep 06, 2011 03:53 PM
Sold 3dhs 71" aj slick - nib 6L6Amp Aircraft - Electric - Airplanes (FS/W) 4 Apr 05, 2011 11:09 AM
Discussion I'm torn, 71 slick or 72 sc? KillerCut 3D Flying 9 Mar 25, 2011 06:20 PM
Discussion 3DHS 42"Slick Side Force Generators bigtexas 3D Flying 3 Mar 03, 2011 12:42 PM
Wanted 3DHS 70" Slick Gas parts!!! helifryer Aircraft - Fuel - Airplanes (FS/W) 0 Feb 20, 2011 07:47 AM
