Old Apr 25, 2012, 10:02 PM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
Venom, sounds like you don't like messing with the gas end of it. Why don't you sell or trade me your DLE and you can go e-power with your 71" Slick. I've got a Hacker A50-12L that will do the trick.
The only thing I don't like about DLE is the noise level. I wish the Slick had a tunnel built into it for a cannister pipe (edit, Racerman just informed me that it does have a tunnel for a cannister). Just wait until you try the DLE20, you will definately have hearing problems after running that engine, way too loud.
gregory.da is offline Find More Posts by gregory.da
Old Apr 25, 2012, 10:03 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
I would use my arm torquing with a socket wrench The lesson is... just make sure they are tight cuz they seem to want to work loose. Kerwin do you recommend using any blue loctite?
3DNater is offline Find More Posts by 3DNater
Old Apr 25, 2012, 10:12 PM
VENOMiTry is offline
Find More Posts by VENOMiTry
United States, MD, Glen Burnie
Joined Mar 2012
The only thing I don't like about DLE is the noise level. I wish the Slick had a tunnel built into it for a cannister pipe. Just wait until you try the DLE20, you will definately have hearing problems after running that engine, way too loud.
well its my first gasser so im learning about it still and yea the dle 30 is very loud with the stock muffler
VENOMiTry is offline Find More Posts by VENOMiTry
Old Apr 25, 2012, 10:16 PM
racerman27410 is offline
Find More Posts by racerman27410
racerman27410's Avatar
United States, NC, Greensboro
Joined Dec 2006
I use loctite on everything except the prop bolts. they wont come loose.
i dont use a torque wrench... just tighten them up nice and snug.... stop before you crush the wooden prop hub or strip the aluminum threads.
i've never had one come loose. but its still a good idea to preflight your aircraft (prop bolts,servo arm bolts/screws and linkages) just in case.
racerman27410 is offline Find More Posts by racerman27410
Old Apr 25, 2012, 10:23 PM
Joined Mar 2012
do you use blue on the muffler cause ive seen some come loose in that area because of the heat? is there any other kind of loctite that will stand up to the heat of the engine
Old Apr 25, 2012, 10:36 PM
Joined Dec 2006
copper coat on the exhaust gasket (available at advance auto and autozone)
red loctite on the muffler bolts with periodic checks for tightness.. you will have to tighten them a couple of times as you heat cycle the engine.... not because the bolts got loose but because the exhaust gasket compresses and settles in.... make sure to remove the bolts ,clean them up with a wire brush and re loctite... dont disturb the exhaust gasket just re do the bolts one at a time.
you have to be disciplined and thorough when dealing with expensive aircraft like we are discussing. (least for me they are) besides being expensive they can be extremely dangerous!
Keep this in mind...
Vibration will shake things loose...its not a matter of if... but when.
you need to have a comprehensive preflight checklist and stick to it....minimal tools are required..... your eyes are the most important part.........check every thing that can be checked.... dont be lazy and not pull the cowl to check the motor mount bolts and the throttle linkage.... the time that you dont will come back to bite you in the tookus and turn your prized plane into toothpicks prematurely.
trust me on this one!
ProBro, 3D
gregory.da's Avatar
Joined Jul 2008
I use blue loctite and drill a hole in the muffler can and attach it via wire to something on the fuse in case it vibrates loose in flight. Mufflers are expensive to replace!
Old Apr 26, 2012, 12:11 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I just posted the question over at flying giants on torquing 4 bolt props.
http://www.flyinggiants.com/forums/s...22#post1722805
I myself after seeing a few broken prop bolts bought a single bolt prop adaptor from
http://www.valleyviewrc.com/estore/d...er-dle-30.html
it just gives me piece of mind and I don't have the headaches of drilling props plus I can use plastic or carbon fiber props as well
kerwin50 is offline Find More Posts by kerwin50
Old Apr 26, 2012, 04:45 AM
RC_Feen is offline
Find More Posts by RC_Feen
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Throttle linkage question
I'm in the process of installing my throttle linkage and had a question about the connectors I want to use. I'm going to use 4-40 rod. On the servo side I'm going to use a Du-Bro heavy duty ball link. On the carb side I want to use a Du-Bro safety lock kwik-link since the kwik-link will center up to the throttle arm. Since this is my first gas plane/set-up will the kwik-link be safe to use on the throttle arm? The Du-Bro safety lock kwik-link looks like this.
RC_Feen is offline Find More Posts by RC_Feen
Old Apr 26, 2012, 05:04 AM
RC_Feen is offline
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Prop question
For my OS GT-33 I need to run a 18x8 prop for break-in. Not much experience in wooden props so what is the difference between the Xoar & Zinger Pro props? Price difference between the two is about $5-6. Thanks!
Old Apr 26, 2012, 06:37 AM
CRFan1 is offline
Find More Posts by CRFan1
Northwest Indiana
Joined Feb 2011
Zingers are crap but for break in it will fine.....after that, go with a xoar
Venom as far as the prop bolts, i do use a small amount of blue loctitie on them and just snug them gradually in a criss cross pattern. You want them to be snug but don't go crazy where you start crushing the wood. I usually tighten them to just before that point
CRFan1 is offline Find More Posts by CRFan1
Old Apr 26, 2012, 11:02 AM
Joined Dec 2006
Xoar is a much better prop but the zinger will work for break in.... just make sure and balance it.
Old Apr 26, 2012, 12:59 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Zingers are great... for stirring paint.
Old Apr 26, 2012, 01:08 PM
flyracer is offline
Find More Posts by flyracer
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
good summarization!
flyracer is offline Find More Posts by flyracer
Old Apr 26, 2012, 01:11 PM
Cmircman is offline
Find More Posts by Cmircman
Rittman
Joined Apr 2010
Well my engine (DLE30) and props (falcon) just showed up today. Now I am just waiting on my canister and servos. I have everything else so it looks like this weekend will be spent building and possibly starting my engine for the first time.
Cmircman is offline Find More Posts by Cmircman
Discussion 71" AJ Slick Gas - First time with gas Hewey19 Fuel Plane Talk 7 Sep 06, 2011 03:53 PM
Sold 3dhs 71" aj slick - nib 6L6Amp Aircraft - Electric - Airplanes (FS/W) 4 Apr 05, 2011 11:09 AM
Discussion I'm torn, 71 slick or 72 sc? KillerCut 3D Flying 9 Mar 25, 2011 06:20 PM
Discussion 3DHS 42"Slick Side Force Generators bigtexas 3D Flying 3 Mar 03, 2011 12:42 PM
Wanted 3DHS 70" Slick Gas parts!!! helifryer Aircraft - Fuel - Airplanes (FS/W) 0 Feb 20, 2011 07:47 AM
