Old Apr 20, 2012, 03:12 PM
VENOMiTry is offline
Find More Posts by VENOMiTry
United States, MD, Glen Burnie
Joined Mar 2012
Originally Posted by SnowDog1974 View Post
It's whatever works for you; the engine doesn't care. I flipped my carb over so I could mount the throttle servo to the bottom of the engine box.
do you have to drill a hole behind the carb?
VENOMiTry is offline Find More Posts by VENOMiTry
Old Apr 20, 2012, 03:58 PM
CRFan1 is offline
Find More Posts by CRFan1
Northwest Indiana
Joined Feb 2011
I would...just go to Ace and get a simple 1" hole saw that you can stick in a drill
CRFan1 is offline Find More Posts by CRFan1
Old Apr 20, 2012, 05:08 PM
3DNater is online now
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
Tom, tell me about battery placement for ignition and servos. Are they pretty far forward or closer to the wing tube? Just curious. I'm running a life for ignition and a lipo for servos. Both unregulated so there isn't any extra crap in there for power share or voltage regulators.
3DNater is online now Find More Posts by 3DNater
Old Apr 20, 2012, 06:31 PM
flyracer is offline
Find More Posts by flyracer
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
even with my batteries right behind the wing tube my Slick is a little nose heavy.. I'm running only one elevator servo and I'm seriously considering doing two to try and get the CG more neutral
flyracer is offline Find More Posts by flyracer
Old Apr 20, 2012, 08:45 PM
Cmircman is offline
Find More Posts by Cmircman
Rittman
Joined Apr 2010
I am just getting ready to start building mine. This will be my 3rd slick. I was curious for the guys running the DLE30 with a cannister which cannister are you using?
Cmircman is offline Find More Posts by Cmircman
Old Apr 20, 2012, 10:15 PM
CRFan1 is offline
Northwest Indiana
Joined Feb 2011
Hey Nate, my battery is back under the hatch latch.......i had to install an additional tray to do that. My CG is a tiny bit nose heavy in this configuration where i like it. I tried it up by the wing tube but it was too nose heavy. Unless you do 2 elevator servos, you can probably plan on doing the same thing
Old Apr 20, 2012, 10:42 PM
3d NOOBular
3DNater's Avatar
Joined Aug 2010
ok great info guys. thanks.
Old Apr 21, 2012, 09:35 AM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
CRFan
I think I might go with adding a tray to reposition my batteries.... post a pic of yours in you can please
Flyracer
Old Apr 21, 2012, 04:33 PM
CRFan1 is offline
Northwest Indiana
Joined Feb 2011
Originally Posted by flyracer View Post
CRFan
Flyracer
I just cut a piece of light ply and epoxied it in between the former under the latch and the area where the pull pull servo goes. Simple as that really
Old Apr 22, 2012, 11:38 AM
FLYING-HIGH is offline
Find More Posts by FLYING-HIGH
Joined May 2005
i ordered this one.
http://www.sdshobby.net/muffler-cani...ine-p-654.html
FLYING-HIGH is offline Find More Posts by FLYING-HIGH
Old Apr 22, 2012, 11:56 AM
Joined May 2005
if you guy's are taking pictures of you building the plane
could you please post them?
it would be nice to see every ones setup.
and the equipment you are using.
thank you.
Old Apr 22, 2012, 08:25 PM
Cmircman is offline
Rittman
Joined Apr 2010
FLYING-HIGH thanks for the link. I take it they are out of china. How long did it take to get yours?
Just ordered my servos,prop, and engine. Should have this built by next weekend.
Old Apr 22, 2012, 10:07 PM
3d NOOBular
3DNater's Avatar
Joined Aug 2010
thank you.
You may have already seen these since I'm pretty sure they have been posted on this thread before (can't remember for sure). But here are pics of my build so far. It has been sitting for a little over a week with no progress due to waiting on parts. the last part should arrive tomorrow so it may be all finished up this week. Additional pics will be posted to this same album as more progress is made.
You can see the mods applied to the motorbox. This is due to how the first version of the 70" slick was made to accomodate a side-carb DLE 30. We cut out 25mm to make room in the cowl for the PTE 36cc that occupies the same exact space as a DLE 30.
We ended up wishing we would have cut out 30mm but it is going to be great how it is. Incidentally the newer version has a MB that is 30mm shorter than the original.
http://imageshack.us/g/818/img0445nl.jpg/
Old Apr 22, 2012, 11:02 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
Mr Slick in der Slick
Old Apr 22, 2012, 11:05 PM
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Sweet details
Discussion 71" AJ Slick Gas - First time with gas Hewey19 Fuel Plane Talk 7 Sep 06, 2011 04:53 PM
Sold 3dhs 71" aj slick - nib 6L6Amp Aircraft - Electric - Airplanes (FS/W) 4 Apr 05, 2011 12:09 PM
Discussion I'm torn, 71 slick or 72 sc? KillerCut 3D Flying 9 Mar 25, 2011 07:20 PM
Discussion 3DHS 42"Slick Side Force Generators bigtexas 3D Flying 3 Mar 03, 2011 01:42 PM
Wanted 3DHS 70" Slick Gas parts!!! helifryer Aircraft - Fuel - Airplanes (FS/W) 0 Feb 20, 2011 08:47 AM
