Old Apr 07, 2011, 07:46 AM
the rc dude is offline
Find More Posts by the rc dude
Fly The Best
the rc dude's Avatar
USA, FL, Lutz
Joined Nov 2008
3DHS 71" Slick on Gas
Anyone out there flying the new 71" Slick on GAS yet?
the rc dude is offline Find More Posts by the rc dude
Old Apr 11, 2011, 10:25 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
There are a few flying with a 30CC in them. In the electric 3D forum under the 71 slick we talk about both gas and electric setups. It was just easier to have them both in one place
losifanatic is offline Find More Posts by losifanatic
Old Apr 11, 2011, 03:35 PM
Fly The Best
USA, FL, Lutz
Joined Nov 2008
Thanks I did not want to step on any electric toes
Old Apr 25, 2011, 04:54 PM
flyracer is offline
Find More Posts by flyracer
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
71" AJ Slick Gasser version scheduled to arrive this week! I can't wait.
Flyracer
flyracer is offline Find More Posts by flyracer
Old Apr 25, 2011, 07:26 PM
Sippin the Koolaid!
Joined Oct 2007
When you gt it up and going post a video!
Old Apr 26, 2011, 12:23 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
I'm gonna have to setup a hat cam! the group I typically fly with are deep into electric flying and none of them will come out to the airfield where I fly my gas setups.... slackers!
Flyracer
Old Apr 26, 2011, 02:22 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
O No, If I lived closer I would come out to watch and lend a hand with a camera or what ever.
kerwin50 is offline Find More Posts by kerwin50
Old Apr 27, 2011, 02:09 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
The Slick arrived last night.... she's puuurty!
Flyracer
Old Apr 30, 2011, 11:30 AM
pryor808 is offline
Find More Posts by pryor808
pryor808's Avatar
United States, NY, Medford
Joined Oct 2008
Has anyone in here assembeled a gas version slick 71". cannister Dle30. Should I put all betteries up front. Rudder servo in tail.
pryor808 is offline Find More Posts by pryor808
Old May 05, 2011, 09:01 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
fly you got any pictures of that slick
Old May 05, 2011, 09:40 AM
pryor808 is offline
pryor808's Avatar
Joined Oct 2008
My 71" is done. The ignition battery (A123 1100ma) is on side of motor box and, the Rx battery (A123 2300ma) behind wing tube. Maiden tomorrow weather permitting.
Dle30 rear carb conversion with Bowman ring and, cannister exhaust.
Rexel Opto-kill switch
Vess 19A
A123 batteries. Rx 2300 and, ignition 1100
Fiji 550ml tank (saves weight)
Flywheelz 3" aluminum hub wheels
Hitec's 7985's and, a XQ metal gear servo for throttle.
3" CF spinner
Thank you! all for help. Especially Steve400 for putting up with my bullsh*t.
Old May 05, 2011, 03:42 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
I started trimming the monocote last night for assembly... I"ll post some pics!
Battery switches arrived yesterday and I also picked up the HS225MGs for the Elevator setup.
Flyracer
Old May 05, 2011, 03:43 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
Pryor
I'm planning on mounting a DLE30 with the rear carb conversion kit... I haven't installed the rear carb kit yet... did you do your own conversion? If so, any tips?
Also, what's your AUW now?
thanks
Flyracer
Old May 05, 2011, 05:49 PM
pryor808 is offline
pryor808's Avatar
Joined Oct 2008
Flyracer,
The conversion kit is simple but, you will need to reseal the rear cover (case) with a good sealant. I used the loctite aneorobic sealant and, let it set for at least 24hrs. The new case rear cover is not going to be a snug fit like the cover you are removing from your engine, that's why you need to use the sealant. Just remove the carb from your engine (2 screws) then remove the rear crankcase cover (4 screws) remove the rear cover as you will notice it's a nice and, tight fit. Now, remove the pin that you will see (you do not need it). Trial fit the new cover and, you will notice how loose it goes on compared to the one you just removed. There is a reason for that (don't worry). now that you trial fitted everything, remove the new cover and, add a good continous bead of sealer around the perimeter/face (make sure it's clean before adding sealer) now, gently place the new cover on. Do not fully tighten the 4 screws yet! hand screw the 4 screws. Now, with the new cover on and, screws hand turned snugged, you should notice some of your sealant seeping out the sides (that's good). It's ok if it seeps inside the crankcase (don't worry) it will burn out. Now, turn your engine over a few times. This will allign your rotating assembly, make sure it's turning freely. As soon as you feel that everything is lined up properly, start tighting the screws with your allen wrench (tighten in the screws little by little going into opposite corners) until fully tighten. Clean off ecess sealant that may have squeezed out. Mount carb back on. Your done. Let set 24hrs.
Paul
Old May 05, 2011, 11:01 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
Paul
Many thanks for the detailed instructions! It sounds/reads like an easy enough process. I'll give this a try over the weekend.
Jacques
Discussion 71" AJ Slick Gas - First time with gas Hewey19 Fuel Plane Talk 7 Sep 06, 2011 03:53 PM
Sold 3dhs 71" aj slick - nib 6L6Amp Aircraft - Electric - Airplanes (FS/W) 4 Apr 05, 2011 11:09 AM
Discussion I'm torn, 71 slick or 72 sc? KillerCut 3D Flying 9 Mar 25, 2011 06:20 PM
Discussion 3DHS 42"Slick Side Force Generators bigtexas 3D Flying 3 Mar 03, 2011 12:42 PM
Wanted 3DHS 70" Slick Gas parts!!! helifryer Aircraft - Fuel - Airplanes (FS/W) 0 Feb 20, 2011 07:47 AM
