Hey guys,
I'm happy to report that I recieved the Flying Balsa "Scout" from the recent giveaway contest in the mail today.
This is excellent timing since I'll be headed out of town tomorrow for work. I wasn't sure if it would arrive in time or not, but since it did I'll get started on it soon. Pics and video to follow.
The kit arrived packaged well with no damage(In only two days). Upon opening the kit, I found the laser work is perfect. There is an abundance of hardware with the kit, in fact; no additional hardware is required for the build!(with the exception of the Motor/prop/Esc/Servos/Rx/Batt) I will be adding a tail wheel to mine because I often fly off a paved surface. Here is a list of the Kit contents:
Documentation1 set of 6 sheets 11 x 17 CAD drawings
1 instruction manual(Very clear instructions with detailed photos and explanations)
Blades3 Aerobalsa SG6042 blades CNC machined and custom fit for the FlyingBalsa delta 3 Gen IIg ninja head.
CNC parts
Other included wood
Triangle stock 3/8 for horizontal stab attachment and 3/4 for firewall reinforcement.
Miscellaneous items
1.......... gimbal kit with instructions
1.......... Generation IIg head kit with instructions
1.......... pair of 3 spoke wheels
2..........4-40 push rods for pitch and roll
2..........pre-bent main landing gear wires
1..........1/16 cable rudder push rod with plastic housing
2..........velcro straps to secure the motor battery
Scout Hardware bag
2 each............. 4-40 swivel ball links
1 each............. #43 drill bit for reaming the 2-56 screw holes and gimbal toothpick holes
1 each............. #33 drill bit for reaming the 4-40 screw holes
2 each............. 3/32 wheel collars and set screws
2 each............. 1/8 wheel collars and set screws
3 each............. nylon rotor blade bushings
3 each............. 4-40 x 3/4 socket head screws (blade bolts)
3 each............. 4-40 self locking nuts
5 each............. #4 washers
2 each............. hardwood landing gear torque blocks
2 each............. landing gear attach straps with 4 screws
3 each............. rudder hinge strips
1 each............. 3/32 x 1 gimbal pivot wire
2 each............. Du-Bro '1/2a' control horns with long screws
1 each............. Du-Bro large control horn with short screws
4 each............. E-Z connectors with attaching hardware
1 each............. .050 allen wrench for the wheel collars
Scout Wood Bag1.......... balsa pylon core
1.......... firewall/landing gear mount
2.......... plywood tail doublers
2.......... plywood fork doublers
1.......... fiberglass servo mount
1.......... 1/4 square x 3 hardwood
1.......... 1/8' x 1/4 hardwood
2.......... 1/8 balsa landing gear drill jigs
Suggested Supplies and ToolsIn addition to the normal modelers tools we recommend the following:
Small machinist square
X-acto knife and X-acto saw
'T' pins
15 or 30 minute epoxy
Thin cyanoacrylate glue
Fine grit sand paper
Ultracote film covering for blades and tail. Fast drying enamel spray paint for all other parts.
Recommended Equipment
Motor.................. E-Flite Power 15
ESC..................... Castle Creations Phoenix 35
Prop..................... APC 11x3.8 slowflyer
Servos................. Hitec HS 225MG for pitch and roll, HS81 for rudder
Battery................. Commonsense budget 8c 3300 3s LiPo
Looking over the parts, and instruction manual; I'd estimate the build to be very quick. I have all the Equipment for the build in hand, and will start as soon as I arrive at my temporary duty assignment. Watch this space.
I'm certainly looking forward to a quick and simple build for a change.
Regards,
-Mike
P.S. this little aircraft is the perfect size to throw in your car, and get those lunch time flights in.
