Old Apr 05, 2011, 09:10 PM
kman24 is online now
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Dynam T-28 Trojan
Welcome to the Dynam T-28 Trojan warbird thread! This is a place to discuss all things about this plane including initial setup, modifications, known issues/fixes, and our product experiences (good or bad). I will try to keep this as up to date as I can going forward, so if you would like me to add anything just send me a PM and I will add it to this page.
General Information
Stock Specifications
  • Wingspan 1270mm
  • Fuselage length 1000mm
  • Wing loading 50g/dm2
  • Flying weight 1350g
  • Servo 9g4 (x6 with flaps)
  • Battery 11.1V 2200mAh 20C Li-Po
  • ESC 30A
  • Motor KV850
  • Prop 11x7x3
Dynam T-28 Website Links
Red Version - http://dynam-rc.cn/Products_view_9.html
Grey Version - http://dynam-rc.cn/Products_view_108.html
Owner's Manual Part #1 - http://dynam-rc.cn/uploadfiles/dlm/DY8940-manual-01.pdf
Owner's Manual Part #2 - http://dynam-rc.cn/uploadfiles/dlm/DY8940-manual-02.pdf
Stock Motor - http://dynam-rc.cn/Products_view_120.html
Stock 30A ESC - http://dynam-rc.cn/Products_view_48.html
Stock Prop - http://dynam-rc.cn/Products_view_99.html
Stock Servo - http://dynam-rc.cn/Products_view_36.html
Nose Retract Landing Gear - http://dynam-rc.cn/Products_view_57.html
Main Retract Landing Gear - http://dynam-rc.cn/Products_view_107.html
Other Related T-28 Web Links
The Real "710 T-28 Trojan" or "Fennec" - http://www.rcgroups.com/forums/showp...postcount=7288
Commonly Asked Questions
1.) How do I hook up the LED lights?
Answer - The supplied LED lights are disappointingly dim. It is recommended to replace the LED's with aftermarket ones either hook them up with required resistors to a power source or better yet, to get an aftermarket lighting kit (see links further below).
2.) What size of battery can I fit in this plane? Answer - Although the recommended 2200mah battery is fine, consensus is that a 3000 to 3300mah (3s or 4s) battery is a good balance between flight time and weight. Beyond 4000mah is pushing it.
3.) Why aren't my retracts working? Answer - these retracts can sometimes hang due to poor servo plug connectors or kinked wire connections. Another common issue is that the retracts don't like the cold weather. When the temps drop below 40-45 degrees F, they stop working.
4.) Are there any weak links with this plane? Answer - the nose gear is prone to bending on hard landings and even over time on good landings. Many of users in this thread are either adding an aftermarket oleo strut to the landing gear stem, replacing the landing gear stem with a similar sized motor shaft, replacing the entire landing stem with an aftermarket spring stem (Dubro 1/2A), or replacing the entire nose retract/landing gear assembly with an aftermarket unit.
5.) The plane doesn't seem to have much power, is this normal? On a 3s battery with stock power system/prop, it is lacking power. To increase performance on 3s, it is recommended to replace the prop with a two blade MAS 12x6 prop or an APC 12x8 prop. This will give you a nice increase in performance while not having to change anything else. On a 4s battery, it is required to replace the ESC with a 40A or higher continuous rated unit. The stock prop works well on a 4s battery, but the MAS 11x7x3 and MAS 11x8x3 are also user favorites.
6.) What is the supplied glue and should I use it? Answer - the supplied bigger white tubes are rubber cement and the smaller tube is canopy glue. You can use them as required in the directions, but you can also use epoxy, gorilla glue, etc to ensure more holding power.
7.) I want to add flaps, what do I need? Answer - Two 9g servos, two linkage quick connects, servo Y-adapter (if only using 1 channel), and servo extensions as required to reach your receiver. One of the servos will need to be reversed. You can reverse the servo yourself by cracking open the servo and reversing the leads on the motor and the pots, install a servo reverser, or plug the flap servos into separate receiver channels and reverse accordingly. See links below for flap
8.) My plane wants to balloon when power is applied, how do I fix this? Answer - the thrust angle is commonly not enough on this model. By simply adding small 3mm washers to the back of the motor mount or between the mount and the motor, you can increase the thrust angle which should be slightly down and towards the right wing. A good example of this performed along with an illustration from the real plane can be found here... http://www.rcgroups.com/forums/showp...postcount=6169
9.) Is cooling an issue with this plane? Answer - it is generally recommended to add some vent holes to the front cowling and also an exit hole towards the bottom rear of the plane. If you do a search within the thread for just the attachments, there are many good examples (pictures) that can be located for illustration.
10.) Where should I place the battery and receiver? Answer - refer to post #140 http://www.rcgroups.com/forums/showp...&postcount=140
11.) How can a prevent my canopy ejecting during flight? Answer - add a latching mechanism or more rare earth magnets.
12.) How do I access the motor and ESC? Answer - remove the prop and simply pull the cowl off (held on by magnets) to access the motor. To access the ESC, remove the 4 screws that hold the motor mount to the firewall and simply pull the motor/mount and ESC out together.
13.) My landing gear mains droop when retracted. How can I keep them tight on the wheel wells? Answer - Add some magnets to hold them in place (cobieg) - http://www.rcgroups.com/forums/showp...postcount=6735
Thread Links and Popular Add on Products
Build Videos (jim12) - http://www.rcgroups.com/forums/showp...postcount=3618
Nose Gear Oleo Strut Mod (spyro37) - http://www.rcgroups.com/forums/showp...postcount=1672
Flap Mod Video (jim12) - http://www.rcgroups.com/forums/showp...postcount=1351
Flap Mod Pictures (kman24) - http://www.rcgroups.com/forums/showp...&postcount=403
Popular Servo Regulator for Reversing and Controlling the Speed of Flap Servos - http://www.hobbyking.com/hobbyking/s...Regulator.html
How To Reverse a Servo for Flaps (cheap way) - http://www.rcgroups.com/forums/showp...&postcount=321
Popular Lighting Kit - http://hobbyking.com/hobbyking/store...ng_System.html (Please note that you will need some extension wires to extend the lights to the absolute tips of the wings). Here is another source for the same kit under different brand/package - http://www.hobbypartz.com/41p-flight-led-system.html Here is a picture of the kit installed - http://static.rcgroups.net/forums/at...0-IMAG0370.jpg
Alternative Retracts that Work in Colder Conditions and with Airtronic Radios (rrobbins) - http://www.rcgroups.com/forums/showp...postcount=1307
http://www.hobbypartz.com/pz-15090-retract.html
Fuselage Replacement/Turnigy Retracts Install (SweetieinSF) - http://www.rcgroups.com/forums/showp...postcount=6091
Custom Nose Gear Door (Grantham Kid) - video http://www.rcgroups.com/forums/showp...postcount=8218 and pics http://www.rcgroups.com/forums/showp...postcount=8230
Micro Switch for Landing Lights (Fei Hu) - http://www.rcgroups.com/forums/showp...postcount=4797
More to come...
KMan
kman24 is online now Find More Posts by kman24
Old Apr 05, 2011, 09:31 PM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Looks pretty good..but is "Dynam" Chinese for "Parkzone?"
First the Meteor/Habu....now this!
Apparently the quality is decent though.
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Apr 05, 2011, 09:39 PM
matthew954 is offline
Find More Posts by matthew954
matthew954's Avatar
Joined Oct 2005
I just got Dynams C-47 Skytrain or as they call it the Skystrain lol. Good looking kit. It goes together fast and simple. And if this Trojan is made out of EPO it should be sturdy too.
matthew954 is offline Find More Posts by matthew954
Old Apr 05, 2011, 09:45 PM
Joined Jun 2005
Skystrain?! Too funny!
Old Apr 05, 2011, 09:57 PM
kman24's Avatar
Joined Jan 2010
Up until a year or so ago, all of Dynams products seemed a little "off". But, they have really come around with their recent products. I bought their SR-22 plane back in December and have been impressed with it so far. Yeah, they do lack some originality, but they do have some nice touches like their flap systems.
Old Apr 05, 2011, 11:08 PM
kman24's Avatar
Joined Jan 2010
Looks like Nitroplanes is going to start stocking the Dynam P-51 soon.
http://www.rcgroups.com/forums/showt...ght=dynam+p+51
Hopefully, this the T-28 follows soon after and they offer it in an ARF version. I am surprised that they didn't offer this plane first since there are only a bajillion Mustangs out there
Old Apr 06, 2011, 04:00 AM
b.boris52 is offline
Find More Posts by b.boris52
Joined Apr 2011
Looks pretty good.
b.boris52 is offline Find More Posts by b.boris52
Reply With Quote  (Disabled)
Old Apr 25, 2011, 10:10 PM
kman24's Avatar
Joined Jan 2010
Doesn't look as nice and detailed as the Airfield/FMS T-28 that just got released, but I am sure it will be priced accordingly. Looks like in this video that it comes with the retracts, too
New Dynam 1200mm T-28 Flight Preview (2 min 11 sec)
Old Apr 26, 2011, 10:30 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Looks like Dynam is trying to keep up with Airfield/FMS
Melnic is offline Find More Posts by Melnic
Old Apr 26, 2011, 11:30 PM
matthew954's Avatar
Joined Oct 2005
I'd say they are doing a pretty good job of it too. I have my Dynam C-47 almost complete. I just need to have cooperative weather to do my taxi tests before I close up the tail. Having totaled my Parkzone T-28 I wouldn't mind replacing it with either this Trojan or the P51, or Cessna 310. Man I'm starting to be a convert from the wonderful world of Horizon Hobby. I can't wait to fly my Airfield F-16 and Skytrain. Bring on the sunshine and clear skies I want to fly!
Old Apr 27, 2011, 06:55 AM
rorrock is offline
Find More Posts by rorrock
Global Hobby Store
rorrock's Avatar
Brisbane
Joined Jan 2007
We just ordered our first stock of the Trojan from Dynam.. Both colors and will come with all the servos installed except the flap servo (we will supply that in the box) and the electronic Retracts installed.. All you need to add is your rx and battery.. The mustang is next..
Rob
rorrock is offline Find More Posts by rorrock
Old Apr 27, 2011, 07:52 AM
kman24's Avatar
Joined Jan 2010
Rob
So, the electric retracts don't come with this plane from the factory? They have to be purchased separately and installed?
TIA - KMan
Old Apr 27, 2011, 07:56 AM
Anda Inc. is offline
Find More Posts by Anda Inc.
Rc Fan From Belgium
Belgium, Flanders, Antwerp
Joined Feb 2011
I will go for the fms / airfield trojan then as it comes fully equipped.
Might be a tad more expensive but its a better looking plane anyway then the one from Dynam.
Anda Inc. is offline Find More Posts by Anda Inc.
Old Apr 27, 2011, 02:08 PM
rorrock is offline
Global Hobby Store
rorrock's Avatar
Brisbane
Joined Jan 2007
Kman,
They are coming installed at the factory..
Rob
Old Apr 27, 2011, 06:39 PM
kman24's Avatar
Joined Jan 2010
Kman,
Rob
Cool, thanks for the clarification
KMan
Video Parkzone trojan t-28 first flight afther crash Anda Inc. Electric Plane Talk 2 Dec 06, 2012 10:09 PM
Sold Parkzone T-28 Trojan Navy PNP stock set-up (local pick-up SoCal) T-CAT Aircraft - Electric - Airplanes (FS/W) 4 Apr 08, 2011 12:52 PM
Sold NIB Parkzone Ultra Micro Trojan T-28 RTF with LOTS of extras MJB9 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Apr 04, 2011 01:20 PM
Sold T-28 Trojan onio condor Aircraft - Electric - Airplanes (FS/W) 5 Apr 04, 2011 05:51 AM
Download New ParkZone Micro T-28 Trojan for CV, FMS, RCDP ggunners Simulators 2 Mar 26, 2011 09:10 AM
