Joined Aug 2002
2. Incorrect firmware match between Spectra Module (fixed into rear Eclipse Pro) and Transceiver 3. Link not established between Eclipse and that transceiver. 4. When updating Spectra RF module, also check if there is an update for the Eclipse Pro under "Transmitter" on HPP-22 screen - two separate processes] None available to date. Current Firmware Versions for optimum performance: Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to Install & Use (with screenshots). with more under AFHSS section: Hitec USA Support Forum Sticky: AFHSS Spectra Modules, Optima Transceivers, Minima Receivers & Telemetry - FAQ & Undocumented Features - Mixes, Setups, Tips. Alan T. Alan's Hobby, Model & RC FAQ Web Links |
Joined Aug 2002
Post #2 this thread. Eclipse 7 Pro - pdf full Manual Alan T. |
Joined Aug 2002
Original 3506kb and that published online and linked above at 5569kb. Both have exactly the same page 2 as pictured. Perhaps you have only looked at a pdf reader page such as adobe, which rarely have the same page structure/numbering as the actual manual and as printed at the foot of each page as clearly pictured previous post. Again, if you would simply refer to the picture attached to Post #4 of this thread you would have seen the highlighted copy of Eclipse 7 Pro Manual page 2 article 3, which answers your question "Switch Assignments". (Link under Post 24 was correct despite typo showing 2 in lieu of 4) Alan T. Alan's Hobby, Model & RC FAQ Web Links |
Joined Aug 2002
Manual page 14 (copy attached) shows "Mode 2" Auto switch assignments. Some functions do not activate until automatically assigned during mixing as model is programmed. To personalise auto assignments, e.g. so as to have both D/R combined on one switch, use "FLT.C - Flight Condition Menu" as outlined manual page 33.. Following may assist: . Hitec Eclipse 7 Pro Mini-Review by a new owner. . Hitec Eclipse & Eclipse 7 Pro - All Manuals, Addenda, Quick Setup, CCPM and Additional Programming FAQ Alan T. Alan's Hobby, Model & RC FAQ Web Links |
| Thread Tools | |
| Sold 2 NEW FrSky 2.4 ghz V8R4 Receivers - $27 shipped | shawn595 | Aircraft - General - Radio Equipment (FS/W) | 2 | Apr 06, 2011 07:05 PM |
| For Sale sharon pro 3.7 with 2.4 Installed | orbitone | Aircraft - Sailplanes (FS/W) | 3 | Apr 01, 2011 02:14 AM |
| Sold A Pair Of New Thunder Power 4 Cell 3850mAh Pro Power 30C Li-Poly Battery Packs $140 S | FlyBoyTha1 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Mar 29, 2011 06:03 PM |
| Sold Hitec Eclipse 7 with 2.4 mod NEW | soaringcam | Aircraft - General - Radio Equipment (FS/W) | 0 | Apr 17, 2010 04:39 PM |
| New Product NEW PCM-PRO Dualsky Xpower Battery Balancer..2-4 Cells! | 2dogrc | Batteries and Chargers | 0 | Jun 10, 2006 08:31 PM |
