Old Apr 05, 2011, 02:09 PM
choppersrule is offline
Find More Posts by choppersrule
Got Helis
choppersrule's Avatar
United States, IN, Greenwood
Joined Mar 2010
Help!
Phoenix Sim / Idle up
Hi Fellas,
I'm not new to flying helis, or planks, or sims. However, I've been banging my head against the wall to get the Idle-up switch to work.
I'm on the latest version of Phoenix, using a DX6i TX. Right stick works perfectly. Left stick works perfect in normal mode. I do have stunt mode programmed in the TX. My problem comes in when I flip to Idle up (with any heli). The motor spins up fine, but I have no collective authority. The heli keeps climbing no matter where the throttle stick is.
I can go into the profile and edit idle up and make it work using one of the keys on the keyboard. But I prefer using the switch on the TX. I know it's gotta be something simple I'm overlooking.
Any help is certainly appreciated..
Dave
choppersrule is offline Find More Posts by choppersrule
Old Apr 05, 2011, 06:41 PM
Sea Monkey is offline
Find More Posts by Sea Monkey
United States, NJ, Mt Holly
Joined Mar 2009
I was wonering the same thing. Until you figure it out you can use the "3" button on the keyboard to switch to idle up. You can also use the "1" for throttle hold.
Sea Monkey is offline Find More Posts by Sea Monkey
Old Apr 05, 2011, 07:09 PM
Got Helis
Joined Mar 2010
Thanks for the tips..
This is just something that bugs me, I gotta get it figured out. Lol!
Old Apr 05, 2011, 09:49 PM
slowone096 is offline
Find More Posts by slowone096
Joined Mar 2011
Go into the transmitter set up in the sim and make sure collective is set to channel 6. I think it is set to channel 1 by default. If it is channel 1 the collective pitch just matched the throttle curve, which matches the problem you are describing.
slowone096 is offline Find More Posts by slowone096
Old Apr 06, 2011, 01:39 PM
Got Helis
Joined Mar 2010
Slowone,
Yahooo!
That fixed my problem. Now Idle-up works perfectly, with the idle-up switch on the TX. And you were right, collective is set to channel 1 by default.
Thanks alot, I appreciate it....
Dave
Old Apr 06, 2011, 02:16 PM
cbinfl is offline
Find More Posts by cbinfl
United States, FL, Clearwater
Joined Jun 2009
I have just purchased X-Plane 9 and it works great with my Macbook and a 15 year old joystick. I'd like to get a controller to use with it. I see Horizon Hobby has one for $30 and wonder if anyone has any experience with it, or any other kind.
Thanks, Charlie
cbinfl is offline Find More Posts by cbinfl
Old Apr 06, 2011, 02:29 PM
Got Helis
Joined Mar 2010
Thanks, Charlie
Charlie,
You may want to try some of the X-Plane forums, I think you'd get better results.
Check it out..
http://www.google.com/#sclient=psy&n...b1cd05180a8c22
Old Apr 06, 2011, 02:39 PM
cbinfl is offline
Joined Jun 2009
Thanks for the link. I'll do that now.
charlie
Question Landing in Stunt mode/Idle up? Torch8 Beginner Training Area (Heli-Electric) 26 Apr 19, 2011 11:01 AM
Discussion idle up prop bender Mini Helis 5 Mar 10, 2011 12:40 PM
Discussion Help. No idle ups in Phoenix RC sim? rowdypc247 Simulators 2 Jun 25, 2010 11:06 AM
Discussion Idle-up on Clearview Sim? helinut2 Simulators 9 Mar 03, 2009 01:46 PM
Discussion Using CP2 and "audio cable" for sim. Always in Idle Up mode! nickbuol Micro Helis 4 Apr 02, 2007 03:11 PM
