Old Apr 05, 2011, 02:33 PM
mikes68charger is online now
Find More Posts by mikes68charger
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, IL, Rock Island
Joined Jul 2010
RC Lander Large Scale Electric Retracts
Ok I got a few questions, Im tring to find a set of all electric retracts for my 120 size Spitfire. 12pounds.
The RC Landers Look stronger than the EFlights
But Im don't understand the option below, the EFlights are 90 or 85 degree mains, What degree do these come out to?
So for my apication I will need to pick the option of "None" Correct?
Also what is the wire diam? are these 4 or 5mm struts?
Thanks Iron Mike
http://parkrcmodels.com/product_info...roducts_id=877
Available Options: Main Rotation Choice:
None
90 degree Rotating Mains (+$10.00)
45 degree Rotating Mains (+$10.00)
Rotating Retract Options:
None
Standard - 2 Rotating Mains with Std Nose Gear Base
Deluxe - 2 Rotating Mains with Rotating Nose Gear Base (+$5.00)
Mains Only - No Nose Gear Unit (-$52.00)
mikes68charger is online now Find More Posts by mikes68charger
Old Apr 06, 2011, 07:40 PM
Parkflying is offline
Find More Posts by Parkflying
United States, MI, Auburn Hills
Joined Dec 2008
Thanks Iron Mike
None
None
We have the base units with 4mm wire shaft that goes into the strut. The units with the struts included are 5mm wire shaft. We can get the base units in 5mm shaft if you like.
When our retracts extend to the down locked position, the lock at 90 degrees from the horizonal plane of the base of the unit. If you look at video on the link you provided above, the strut comes directly up to the base without rotation. We have base units that can rotate the shaft to accommidate wheel wells not in normal direct line with the centerline of the strut.
Here is a link to our page with the 90 degree rotation feature on the smaller retracts that we also apply to the Large retracts.
http://parkrcmodels.com/product_info...roducts_id=813
Yes, these retracts are factory rated at 15 pound plane or less.
Hope that helps
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Discussion The +'s and -'s of electric retracts on large jets Ron101 Electric Ducted Fan Jet Talk 36 Jan 23, 2015 06:17 AM
Wanted Large scale rc Sportbike fetish636 Cars - Motorcycles (FS/W) 6 Apr 14, 2011 01:13 AM
Wanted RC Lander Retracts 4 T45 CMP josephcharles Aircraft - General - Miscellaneous (FS/W) 0 Mar 03, 2011 12:35 PM
Discussion Magnum RC will stock large scale Lado electric retracts Madmax1965 Electric Ducted Fan Jet Talk 15 Feb 23, 2011 07:58 PM
Sold New RC LANDER retracts with scale HC struts pajlotmato Aircraft - Electric - Jets (FS/W) 0 Jan 22, 2011 10:40 AM
