Old Apr 23, 2012, 04:44 PM
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
You gonna have a third channel and a motor to it?
scorpion1 is offline Find More Posts by scorpion1
Old Apr 23, 2012, 06:08 PM
gulf coast,south louisiana
Joined Jun 2008
sure will......controlled by the radio if i can.
working on it now,ive built the bearing housing already,installed the bearing....working the kinks out now.
heres a pic of the system,and the order its put together.
igotit is offline Find More Posts by igotit
Old Apr 23, 2012, 10:17 PM
Joined Jun 2008
the inside thrust bearings are dont,now i gotta build the outside seal assembly.
works beautiful by hand,but if i apply load.....hard to turn.
example....if the motor puts out 6lbs of thrust,and the boat weights in at 4 lbs fully loaded....i need a motor/gearbox that can handle atleast 12lbs of rotation.
gonna have to brain storm this one.
Old Apr 24, 2012, 12:37 AM
Joined Jun 2008
heres a working vid!
driven by a servo.
photo bucket drags on my computer,making the trim look twitchy.
but its pretty smooth on my end.
servo has enough power to lift the entire boat.
Old Apr 24, 2012, 07:22 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
If you put thrust bearings on both sides of the metal bracket you should be able to stop the forces from making it to the motor.
wparsons is offline Find More Posts by wparsons
Old Apr 24, 2012, 12:21 PM
Joined Jun 2008
the way its designed....a front thrust bearing isnt needed.
the load only transfers forawd during trim up.
during trim down,the load is again pushing foward.
the screw drive isnt connected to the motor in anyway.
no pull back on the system.
the motor is free floating,in the event that i hit something....i dont rip my trim system up....just kicks the motor up.
Old Apr 24, 2012, 02:12 PM
Joined Jun 2008
the outside shaft seal assembly.
made another aluminium cup,cut and installed 2 soft foam inserts from a cheap,common paint ball squeegie.also used a spacer from the squeegie.
as i tighten the screws to the transom,the yellow tube compresses the foam tighter around the shaft.
making a tighter seal.
ill lube with silicone lube,water should do the rest.
should be ready for a float trim water test in a few hours.
Old Apr 24, 2012, 04:43 PM
Joined Jun 2008
just pool tested with throttle and trim only....im impressed.
at full throttle thr trim works just fine.after about 8 cycles of the trim,the servo starts to heat up.
guess a stronger servo is in the future.
the boat looks great in the water,no leaks.
Old Apr 25, 2012, 03:45 AM
Joined Jun 2008
made and glued the trim servo mount,cut down the driveshaft,installed universal....ect.
worked on the transom alittle too.
next is steering.
Old Apr 25, 2012, 04:24 PM
Joined Jun 2008
built the servo and reciever mount.
installed a traxxas waterproof servo,ill run a xl-5 esc for now.
i hate the double tap brake before reverse option though.
difficult on a stick radio.
hopefully i can continue on her,possibly ride her this afternoon.
Old Apr 25, 2012, 04:29 PM
catchthis's Avatar
USA, NY, Laurel
Joined Aug 2010
shaping up!
catchthis is offline Find More Posts by catchthis
Old Apr 25, 2012, 07:48 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Looks good, i think direct drive may be too much for the servo................no?
Old Apr 25, 2012, 07:52 PM
Joined Jun 2008
Originally Posted by catchthis View Post
shaping up!
thanx catchthis
for this servo....maybe.
its a weak stock axial servo.
somewhere i have a hitec 645mg.....ill swap that one in once i find it.
if i have too ill go 1/4 scale.
the thrust bearing takes the load,the servo just needs to provide the power.
i was looking for some gear to add a inline 2:1 ....but couldnt find anything.
Old Apr 25, 2012, 07:57 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
How about a high voltage servo and run it on the same voltage as a standard servo so it has less rpms, but still has torque?
Old Apr 25, 2012, 08:05 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Here's a whopper with huge torque and slooooooooooow speed..............
http://www.hobbyking.com/hobbyking/s..._20s_30kg.html
Sold 1/8 Ofna GTP ep RTR Brand New reddyrightnow Cars - Cars and Parts (FS/W) 2 Apr 03, 2011 10:53 PM
Discussion My latest building project is a 1.20 size Texan AA5BY East Texas Aeromodelers 0 Mar 31, 2011 12:04 PM
Question Pro boat Miss Elam 1/12 Ep Airman69 Racing Boats - Electric 1 Mar 17, 2011 06:01 PM
Discussion My latest project - GP Reactor 3-D (EP) Flying Fast 3D Flying 0 Jun 12, 2010 07:24 PM
Discussion My 1st Big EP Plane Project tIANcI Giant Electric Planes 4 Apr 19, 2007 02:59 AM
