Old Apr 05, 2011, 10:55 AM
igotit is online now
Find More Posts by igotit
United States, LA, Houma
Joined Jun 2008
ep-1 project (with working power trim)youtube first run vid on pg 3!
i aquired a sv27 glass hull awhile back,been planning to run 1-2 ep-1 outboards.
ill try with one ep-1 first.
sofar all i did was remove the hardware,stickers and mock-up of the ep-1.
the hull is empty,no radio box,no frame rails.....nothing.
not sure if im staying brushed or going brushless at the moment.
may fabricate a nice jack-up plate/standoff,better bigger prop and surface drive the ep-1 with a hotter brushed motor.
im not really into fast things anymore,i like scale stuff.
ill be happy with 20 mph tops.
igotit is online now Find More Posts by igotit
Old Apr 17, 2012, 02:20 PM
Joined Jun 2008
time to raise the dead.
started gutting the old rotten transom,building a new transom with the addition of a added motor jack plate.
im tieing the jack plate into the transom for strength.if i go brushless....the transom should hold up fine.
the brass gears in the ep-1's lower unit....may not hold up.
i used 1/4 birch ply.
Old Apr 17, 2012, 02:27 PM
SARCFAN is offline
Find More Posts by SARCFAN
Joined Dec 2010
I like the look of outboards. Its just too back heavy for my liking. Much too much weight at the back. But then again, you could just place the batteries in the front.
SARCFAN is offline Find More Posts by SARCFAN
Old Apr 17, 2012, 02:33 PM
Joined Jun 2008
thats what i had in mind,batteries up front.
eventually ill build my own deck to look more like a ski/bass boat.
Old Apr 17, 2012, 04:28 PM
Joined Jun 2008
new transom glassed in,held with temporary screws.
Old Apr 17, 2012, 09:13 PM
Joined Jun 2008
motor mounted.......float test.
Old Apr 17, 2012, 10:19 PM
Joined Jun 2008
before i finish boxing in the jack plate....im gonna build a remote power trim unit....gonna try anyway.
prepare to be amazed....my ideas usually work.
ill be using a small steel hinge,a 150:1 micro gear motor and some all thread.
Old Apr 17, 2012, 11:20 PM
gpzy is online now
Find More Posts by gpzy
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
There was a brushless conversion done here on RC Groups for the EP-1
http://www.rcgroups.com/forums/showt...s+ep+1+convers
gpzy is online now Find More Posts by gpzy
Old Apr 18, 2012, 01:09 PM
Joined Jun 2008
thanx for that link.
Old Apr 18, 2012, 01:10 PM
Joined Jun 2008
got the power trim concept sorted out.
just gotta power it with a high torque servo or gear box.
i went a different route with the idea,used the existing motor mounting brackets,axial 3rd upper link,long screw,threaded peice of plastic.
ill have a test vid comming soon.
Old Apr 18, 2012, 01:24 PM
Joined Jun 2008
click the pic for vid
looks jumpy in the vid....but its pretty smooth
Old Apr 21, 2012, 10:37 PM
Joined Jun 2008
built the trim bracket,installed a thrust bearing.
just have to cut the shaft down,attach a powerful servo....make a mechanial seal on the outside to keep water out.
motor is free to pop up in the event that i hit something.
the downward force of the prop wash will push against the thrust bearing,that rides on the back side of the stainless plate.
this way i dont transfer any foward load on my servo.
Old Apr 21, 2012, 11:34 PM
Joined Jun 2008
quick vid powered by a small weak cordless screw driver.
i like this setup,but will build a better version later.
its a simple screw drive setup,similar to screw drives built to similate hydraulics on rc construction equipment.
Old Apr 22, 2012, 12:37 AM
scorpion1 is online now
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
This is a neat idea!!
scorpion1 is online now Find More Posts by scorpion1
Old Apr 22, 2012, 12:46 AM
Joined Jun 2008
thanx bro!
i enjoy doing things i havent seen done before.
hopefully it works out in the end.
Sold 1/8 Ofna GTP ep RTR Brand New reddyrightnow Cars - Cars and Parts (FS/W) 2 Apr 03, 2011 10:53 PM
Discussion My latest building project is a 1.20 size Texan AA5BY East Texas Aeromodelers 0 Mar 31, 2011 12:04 PM
Question Pro boat Miss Elam 1/12 Ep Airman69 Racing Boats - Electric 1 Mar 17, 2011 06:01 PM
Discussion My latest project - GP Reactor 3-D (EP) Flying Fast 3D Flying 0 Jun 12, 2010 07:24 PM
Discussion My 1st Big EP Plane Project tIANcI Giant Electric Planes 4 Apr 19, 2007 02:59 AM
