Old Apr 13, 2012, 05:06 PM
extremewing is offline
Find More Posts by extremewing
A different attitude to RC
extremewing's Avatar
Draper, Utah
Joined Sep 2008
It does look fine. I would just charge the pack at around 200ma and see how much it takes.
extremewing is offline Find More Posts by extremewing
Old Apr 13, 2012, 11:59 PM
thecirque is offline
Find More Posts by thecirque
thecirque's Avatar
Cottonwood Heights
Joined Jul 2005
I put the battery pack back on the charger @ .2A rate. It accepted just over 200mah after 65 mins or so according to the charger.
Something isn't adding up.
Do I just go with it?
I thought about doing a discharge/charge cycle just to see what goes back in. What's an acceptable discharge rate on the charger?
Not sure what to do. Not feeling to confident in my home made
Pack.
thecirque is offline Find More Posts by thecirque
Old Apr 14, 2012, 01:03 AM
JONBOYLEMON is offline
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
Until you post the voltage its hard to tell whats up.
But 200 into the pack in 1 hour @ .2A charge sounds just fine.
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
Old Apr 14, 2012, 01:15 AM
thecirque's Avatar
Cottonwood Heights
Joined Jul 2005
If I check each battery individually. I show like 1.3xx volts which I believe is right. If I check the lead coming from the complete pack, I get 5.28
Just not getting why newly made pack would go dead in an hour and then only take 200 on charge.
Old Apr 14, 2012, 01:40 AM
Joined May 2002
Chicken dinner. All is well. Those voltages sound ok.
If one cell was way different that would indicate you cooked it in the soldering process. Also, did you sand the battery where you soldered it? If no, sand it ever so slightly so that the solder joint has a better grip. You dont want a solder joint to fail on something that has wings.
Old Apr 14, 2012, 03:53 PM
thecirque's Avatar
Cottonwood Heights
Joined Jul 2005
Well, here she is. I threw it in the rain till my Tx was sufficiently wet.... Still not understanding the battery issues, but... I'll keep charging and flying till she quits I guess.
Thanks for everyone's help and input.
Old Apr 14, 2012, 04:03 PM
Joined May 2002
She looks great! Just keep charging it and posting what is happening, but I suspect everything is just fine.
Old Apr 15, 2012, 10:58 AM
Draper, Utah
Joined Sep 2008
One more tip that is not in the build images: use colored tape over the extreme tape wherever it is exposed to protect from UV exposure. This prevents the extreme tape from yellowing and drying out over time.
Old Aug 27, 2012, 10:22 PM
pjschae is offline
Find More Posts by pjschae
United States, UT, Salt Lake City
Joined Aug 2012
Will a Hitec Superslim Rx fit in the Alula. If not, suggestions for a suitable 72mhz Rx. And what to do with the long antenna?
pjschae is offline Find More Posts by pjschae
Old Aug 31, 2012, 11:11 PM
Plane Insane RC is offline
Find More Posts by Plane Insane RC
BUZZ KILL
Plane Insane RC's Avatar
Utah
Joined Aug 2010
Just cut the antenna off. That will give you and excuse to get a 2.4 system.
Plane Insane RC is offline Find More Posts by Plane Insane RC
Old Sep 04, 2012, 06:00 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
You're so funny.
Remind me to smash my airplane into you at the sWARm.
You are showing up this time?
jetpackninja is offline Find More Posts by jetpackninja
Discussion Utah flyers?? Indoor and parkflying in Utah? biphfyt Scratchbuilt Indoor and Micro Models 2 Dec 20, 2006 09:44 PM
Utah Unicorn Flyers (Part III) Darren Hintze Foamies (Kits) 323 Nov 26, 2004 02:12 PM
Any indoor flyers in SLC Utah? SchylarB Scratchbuilt Indoor and Micro Models 1 Sep 02, 2004 08:57 PM
Any Electric zagi Flyers from Utah? Bob The Podder Foamies (Kits) 0 Apr 01, 2003 06:59 PM
Logo flyers in Utah ku7s Electric Heli Talk 1 Jul 24, 2002 08:27 AM
