Old Dec 13, 2011, 09:38 AM
jwjohnson is offline
Find More Posts by jwjohnson
Hit Me! Please!
jwjohnson's Avatar
Provo, UT
Joined Jan 2005
You guys are all like my corner drug dealer. Only difference is you don't give away the first sample of crack for free.
jwjohnson is offline Find More Posts by jwjohnson
Old Dec 13, 2011, 09:39 AM
JONBOYLEMON is offline
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
Yeah, but we show you how to use it properly!!!!!
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
Old Dec 13, 2011, 09:49 AM
extremewing is offline
Find More Posts by extremewing
A different attitude to RC
extremewing's Avatar
Draper, Utah
Joined Sep 2008
If you want your free sample, I can help you put it together!
extremewing is offline Find More Posts by extremewing
Old Dec 13, 2011, 10:09 AM
Joined May 2002
Not just a dealer, but a distributer....
Old Dec 13, 2011, 07:14 PM
JetPack Ninja Jr is offline
Find More Posts by JetPack Ninja Jr
Jakie fetch plane?!
JetPack Ninja Jr's Avatar
Stuck in the basement, Utah
Joined Aug 2010
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me." -Hunter S. Thompson.
DLG-er's frame of mind!
JetPack Ninja Jr is offline Find More Posts by JetPack Ninja Jr
Old Jan 22, 2012, 11:26 PM
kpjkl4 is offline
Find More Posts by kpjkl4
United States, UT, Riverton
Joined Sep 2011
I followed Extremewings building guides. I'm very excited to fly my Alula but have also seen a few additional mods I'm hoping you guys will comment on. Should I use extreme tape or other to reinforce leading edge. I have installed the wing removal kit and have seen a thread that indicates to move the servos to the center of the wing to better control the elevons. Is this something you would recommend.
kpjkl4 is offline Find More Posts by kpjkl4
Old Jan 23, 2012, 10:38 AM
Draper, Utah
Joined Sep 2008
I can suggest that putting tape on the leading edge is not a good idea - it will not stop it getting damages and just add weight. (Just my personal opinion )
I would not move the servo's either! You want them to be near the center of the fuse so as much weight as possible is close to the center line... We have never had a problem as they are.
There are also those that put the push rods on top of the wing. I have done it both ways and found no benefit to the push rods on top... Simpler and easier to do it as designed!
The wings can be removed without the wing removal kit. Just cut (rather than removing) the tape where they join and pull off! Then, use some normal narrow clear tape to re-attach. This is assuming you followed the instructions on the first post
Also, one more thing that is really worth doing, is to cover the extreme tape with colored "zagi" tape. This is well worth it to prevent the sun from damaging the extreme tape over time...
Old Mar 15, 2012, 09:28 PM
thecirque is offline
Find More Posts by thecirque
thecirque's Avatar
Cottonwood Heights
Joined Jul 2005
I'm a little late to the party..... What's the servo of choice you guys are running? And where's the least expensive place to pick up
A set.
I just ordered my first Alula.
thecirque is offline Find More Posts by thecirque
Old Mar 16, 2012, 11:09 AM
Draper, Utah
Joined Sep 2008
The best servo's for the Alula (IMHO) are HS-45HB. They have carbonite gears and will slip instead of stripping, therefore lasting a long time.
You do not need the digital version (analog version can be $10 or less). The digital version (if you had more money than sense or just like high end!) is an HS-5045HB and can be $20 or more.
Get them from the local hobby store or online.
Old Mar 16, 2012, 11:53 AM
eosglider is offline
Find More Posts by eosglider
Addicted to lift
eosglider's Avatar
United States, FL, Miami
Joined Jul 2010
HXT500's have served me well, fit like a glove in the slot, and if they strip (which I have not done yet after probably 1000 launches on my first Alula EVO), who cares, they're super cheap.
eosglider is offline Find More Posts by eosglider
Old Mar 16, 2012, 12:19 PM
like.2.fly is offline
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
Pick a servo that has good centering and resolution. Super cheap ones don't! You won't notice the difference on most planes. But accurate pitch control is critical for the Alula elevons, and it will be a major battle to get a good consistent repeatable hands off glide without it. I would go with nothing less than the analog HS-45HB, with digitals being even better.
like.2.fly is offline Find More Posts by like.2.fly
Old Mar 16, 2012, 02:22 PM
thecirque's Avatar
Cottonwood Heights
Joined Jul 2005
Perfect, thx for the responses.
Can I ask about the Battery thing too?
I saw the soldered up 4 cell recommended In the 1st post build log ( awesome, by the way, thanks!!) Why don't I want to just use the same Lipo's I'm flying in my B2? Seems easier to just keep the same chemistry rather than a "step back" to old tech. Is it just a balance/weight thing?
Thx
Old Mar 16, 2012, 02:34 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
balance/weight - expense thing
It is a happy coincidence that the 4 aaa cells balance the Alula almost perfectly so you no longer add weight to the nose.
The 4 little aaa nimh batteries give lonnnnng times between charges.
Easy to charge too. I use the same 4 button charger that I use to charge up all of my lipos (and my transmitter)
jetpackninja is offline Find More Posts by jetpackninja
Old Mar 16, 2012, 02:35 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Nice to see some action on this thread!
It's been silent for a long time
Old Mar 16, 2012, 03:54 PM
Joined May 2002
Yep the 4 cell pack is not only perfect size and weight, its also cheap in tough!
Discussion Utah flyers?? Indoor and parkflying in Utah? biphfyt Scratchbuilt Indoor and Micro Models 2 Dec 20, 2006 09:44 PM
Utah Unicorn Flyers (Part III) Darren Hintze Foamies (Kits) 323 Nov 26, 2004 02:12 PM
Any indoor flyers in SLC Utah? SchylarB Scratchbuilt Indoor and Micro Models 1 Sep 02, 2004 08:57 PM
Any Electric zagi Flyers from Utah? Bob The Podder Foamies (Kits) 0 Apr 01, 2003 06:59 PM
Logo flyers in Utah ku7s Electric Heli Talk 1 Jul 24, 2002 08:27 AM
