Old Apr 04, 2011, 06:18 PM
Cuddles is offline
Find More Posts by Cuddles
Be afraid!
Cuddles's Avatar
Milano
Joined Dec 2003
Pr.705 Lira in 1/200
Hello lads,
I've always liked the idea of a small zippy Alfa so...here it is
Cuddles is offline Find More Posts by Cuddles
Old Apr 04, 2011, 06:43 PM
asd9000 is offline
Find More Posts by asd9000
United States, FL, Tampa
Joined Nov 2009
Amazing work! is that an xcelorin motor too?
asd9000 is offline Find More Posts by asd9000
Old Apr 04, 2011, 06:56 PM
Cuddles is offline
Be afraid!
Cuddles's Avatar
Milano
Joined Dec 2003
That's all a scratch built: a foam cylinder with a hardwood dowel in the middle turned on a wood lathe with sail built with depron. All glassed and sanded.
Motor is a Graupner Inline 220 (5250kv) mounted with a heat sink.
Wtc dimension is 19cmx4cm, quite small indeed!
Old Apr 05, 2011, 04:00 AM
redboat219 is offline
Find More Posts by redboat219
Philippines
Joined Jan 2005
Hello cuddles,
Great little project you got going there. When I first read the title I thought this was about another conversion of the CNModels Alfa. Then I saw the caption "lost foam" under the first photo. Wish you started the post with how you made the hull.
Anyway, Can you post more images of the hull.
I'm a bit curious why you chose to build in 1/200 scale and not something bigger like 1/144? Would make fabricating the stern linkages easier.
I'll be keeping my eyes on this thread.
redboat219 is offline Find More Posts by redboat219
Old Apr 05, 2011, 01:50 PM
Cuddles is offline
Be afraid!
Cuddles's Avatar
Milano
Joined Dec 2003
Well redboat, I was looking for Cn Alfa but, since was not avail....
The fact is that, although I know that a larger sub both runs better and is easier to make, I love dealing with problems related to miniaturize things.
By the way this sub is going to see lots of action because it will be my lunch time sub as there is a suitable basin near my workplace.
You can see some photos of an Alfa hull being built here:
http://s181686668.onlinehome.us/phpB...396&hilit=alfa
All is very similar except that I've used a wood lathe.
Old Apr 08, 2011, 02:16 PM
Cuddles is offline
Be afraid!
Cuddles's Avatar
Milano
Joined Dec 2003
Hi lads,
I've some hull photos and a question.
I'm thinking to go easy and operate just the lower rudder. If so, should I make it all moving?
Stilla lot of work to do...
Old Apr 08, 2011, 03:55 PM
Brooks is offline
Find More Posts by Brooks
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Very nice, following your build with great interest.
Brooks is offline Find More Posts by Brooks
Old Apr 09, 2011, 03:29 AM
Philippines
Joined Jan 2005
Yes you can get away with just using the lower rudder. If turning is sluggish you can extend the rudder using clear plastic sheet or fabricate a whole new larger rudder using clear plastic sheet just paint in the original rudder area to maintain scale appearance. The clear plastic will be practically invisible once it's in the water.
Old Apr 11, 2011, 05:55 PM
Cuddles is offline
Be afraid!
Cuddles's Avatar
Milano
Joined Dec 2003
Hi lads,
I've decided to bite the bullet and to go scale with the friggin rudder
Should be hard but not impossible.
But before I must fit the prop shaft bushing in its stern cone extension
Old Apr 11, 2011, 08:39 PM
Philippines
Joined Jan 2005
What material are you using for the stern planes?
Just an idea. Instead of squeezing the stern plane and rudder linkages in the narrow confines of the tiny stern cone why not just make the bow planes movable instead to control pitch.
Old May 31, 2011, 10:40 AM
Philippines
Joined Jan 2005
Any updates?
Old Jul 27, 2011, 08:17 AM
Cuddles is offline
Be afraid!
Cuddles's Avatar
Milano
Joined Dec 2003
Hello lads,
finally got some inspiration and time to go ahead.
Things left to do are:
-install yokes and pushrods (half done)
-create a saddle for WTC
-install some more indexing lips
-create a micro scale prop
-scribe and open details
-balance and test.
Video of working rudder is here:
http://www.rcgroups.com/forums/showt...7#post18876298
@redboat: I'm simply using 2mm evergreen plasticard.
P.S. Got sidetracked with a RCABS Trumpeter Seawolf done as LSV-1 Kokanee
http://www.navsource.org/archives/08/08356.htm
Old Jul 27, 2011, 11:25 AM
tsenecal is offline
Find More Posts by tsenecal
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
does that mean that you built a 1/36 scale LSV-1?
tsenecal is offline Find More Posts by tsenecal
Old Jul 28, 2011, 10:39 AM
Cuddles is offline
Be afraid!
Cuddles's Avatar
Milano
Joined Dec 2003
Ok lads,
all is connected and running
Please, see new video:
http://www.rcgroups.com/forums/showp...95&postcount=2
Rudder and planes were tacked with cyano and faired with tamiya epoxy putty quick type.
Hull was puttied to fill some minor cracks n' dings and all the panels to be scribed are penciled.
Some tests in the bathroom showed good control response and some roll instability but not so much.
Still must scribe and open all the panels and make front planes. New indexing lips were installed but are not enough; I must devise some kind of locking system.
Old Jul 28, 2011, 09:03 PM
Cuddles is offline
Be afraid!
Cuddles's Avatar
Milano
Joined Dec 2003
Look at my prop, I'm very proud of it!
Looks scale enought to me...
Scribing work looks a bit poor but I still have to add some details like torp doors, sonar windows, bottom and sail vents.
Tomorrow will add fwd planes and a magnet lock for hull halves.
Must find some 1,5mm i.d. silicon tube to use as a coupler and she will be ready to launch.
After a shakedown cruise I'm planning to add creeper pods, water scoops etc.
Sold 1/10 AX10 Scorpion Rock Crawler $180 Shipped (Reduced) mooneypilot Cars - Cars and Parts (FS/W) 4 May 21, 2011 11:52 PM
Question Graf Zeppelin 1/200 (any news from Lindberg?) polisman1941 Scale Boats 5 Apr 07, 2011 12:49 AM
Sold Seagull Laser 200 - 1.20 ARF RTF rickj12 Aircraft - Fuel - Airplanes (FS/W) 0 Mar 17, 2011 01:18 PM
Wanted phoenix sim, 3 in 1 for cp pro, or 2 in 1 and gyro bigdogrod Aircraft - General - Miscellaneous (FS/W) 2 Mar 15, 2011 12:35 PM
